Question about RCA L32WD12 32 in. LCD HDTV
Can not get green power light to come on. Takes 30 minutes
Can not get green power light to come on. Takes 30 to 45 minutes to finally get the green light to stay on. It will flash red and then flicker green. RCA # L32WD12
Adolph
  • 137 Answers
SOURCE: Flickering/pixelating screen on LTV-27w6 HD after 30 minutes.
Sound like dry goint on Power Supply bord. I had the same problem and resolder most of the parts of the power supply and TV was ok.
Posted on Dec 22, 2007
SOURCE: RCA TV flickering problem
Help! I have an RCA 40 inch HDTV (Model# D40W20). I've had it since 2005. Recently, the picture will flicker when I turn it on, but will stop flickering after a few minutes. My brother has the 52 inch model and his tv did the same thing before it broke down completely. Does anyone know what the problem could be?
Posted on Jul 24, 2008
SOURCE: RCA L32WD12 32in. HGTV LCD Television
I had the same problem happen this afternoon, so I took it apart, and the source of the problem is the key controller panel (behind the buttons). It's held in place by 2 screws, if you take the case apart, which is literally only 15 or 20 screws, and then loosen the 2 screws holding the key controller panel on, and then use a small screwdriver to space it out from the button caps. Tighten the screws, and put it back together. Just be careful not to let it go too far to the other side, or you'll have a problem with the menu going on and off at random, which is just as annoying.
Posted on Aug 01, 2008
SOURCE: POWER WON'T COME ON
I have the same problem with RCA L32WD12
THIS TV IS ONLY A FEW MONTHS OLD HOW DO I GET SERVICE
JERRY
Posted on Sep 15, 2008
budmrtn
  • 11361 Answers
SOURCE: I have a RCA L32WD12 that suddenly turned off and
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Posted on Nov 14, 2009
Green light flashing. no Internet access
Hi and welcome to FixYa!
We are going to reset your router as a first step, but this may just solve your issue in one shot if you are getting a green light already!
Turn router around;
Find the small pinhole usually located by the power cord;
Stick something like a paperclip in it and press down firmly for 1 minute;
wait until you see the lights blink and then go out;
Then; unplug the power cord from router for about half a minute;
Then, plug it back in.
This is the only way it will finalize resetting and it takes away your encryption;
resets your network name back to Linksys.
Let me know how this worked out for you. If my solution helped you, please rate this solution!
It doesn't cost anything and only takes a second, but it is greatly appreciated.
KittyTech
Feb 06, 2011 | Linksys Wireless-G WRT54G Router
I just bought a combo 18V Ryobi blower P2102 and trimmer P2002 which also came with a charger P113 and Ryobi lithium battery. I charged the 18V lithium P104 battery 48WH till light turned solid green on...
The battery will power your equipment for 30 to 45 minutes, that is normal. What you're thinking of is the lifespan of a lithium battery. It with your battery will last 10 times longer than a regular NiCad battery. So you will be able to charge the battery and use it Hundreds of times before the Battery Life is depleted. Sounds like it's working as designed
May 05, 2017 | Ryobi Two 18V Lithium-Ion Batteries +...
Monitor won't turn on
in the output section of smps some condensors are faulty
Dec 12, 2009 | Computers & Internet
My tv takes like ten minutes untill it's turning on,why?
Replace any swollen capacitors in power supply.
Apr 24, 2009 | Televison & Video
Rca projection tv
Capacitor on Deflection board cp150 2200uf 16v if it is puffed up on top it is bad 2 more caps cp114 cp120 220uf 35v replace them if cp150 is bad.they are green with gold writing on them.
Dec 27, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W20 tv
3 capacitors On Deflection board cp150 2200uf 16v see if it is puffed up on top if so it is bad also replace 2 more caps in same circuit cp114 cp120 both are 220uf 35v they are green with gold writing.For Parts 1-800-223-3205. www.electronix.com
Tv will not come on immediately...
3 capacitors cp150 2200uf 16v if it is puffrd up on top then it is bad ,other 2 caps cp114 cp120 220uf 35v they are green with gold wring on them located on Deflection board . Resolder all pinns on FBT on same board.
Dec 26, 2008 | RCA D52W19 52" Rear Projection Television
Problems powering up
These sets have alot of problems with poor solder connections resolder all pins on flyback transfomer, check 3 capacitors on power/deflection board cp(150) 2200uf 16v (cp120) 220uf 35v (cp114)220uf 35v they are green with gold writing.Also it is better to fix it Now because the longer you keep trying to play set it can cause more damage to it.
Dec 13, 2008 | RCA D52W19 52" Rear Projection Television
The red power light stays on
You may need to replace your Tvs convergence board. Go to www.partstore.com and type in your Tv model #. It is a simple swap procedure with no soldering. It costs about $80 or more. It takes 30 to 45 minutes to replace.
Dec 11, 2008 | Hitachi 43UWX10B 43" Rear Projection...
TV takes 5 minutes to come on.
"The bulb"?? Yes I guess it could be the bulb. Or a million other things. Probably some small part on a circuit board. Call a repair shop... TVs are dangerous to work on so don't try it.
Feb 26, 2007 | Sony KDF-E42A10 42 in. LCD Television
RCA L32WD12 32 in. LCD HDTV Logo
46 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
