Question about Brother IntelliFax-2820 Laser Fax
We have taken delivery of a fax from within our business but need to change the header/business name that recipients see when receiving faxes from us
    President:
  • 405 Answers
Press the Menu/set key, then down arrow untill initial setup, then press, menu/set, then down arrow to station ID, then menu/set. From here you can change the info you need to change.
Posted on May 08, 2010
HOW TO FAX
  1. Make sure the fax machine is plugged into a power source and also plugged into a working phone jack.
  2. Turn the fax machine on.
  3. Obtain the fax number of the destination fax machine.
  4. Gather the documents you want to send and put them in the order you want them to be received.
  5. Fill out a separate piece of paper called a coversheet with the recipient's name, fax number/phone number, your name, your phone number, a short message and number of pages (including coversheet).
  6. Lay the documents face-up in the fax machine feeder tray with the coversheet on top
  7. Dial the recipient's fax number - put 9 before the number and area code
  8. Press the "fax" or "send" button, depending on the particular fax machine model
Nov 17, 2014 | Office Equipment & Supplies
We have a FAX-2820. this is a dumb question, but does the fax header line come from the sender when we are receiving the fax? Does a header go out on any fax we would send out?
Yes, The fax header should show you who sent the fax to you. Every fax is supposed to have a terminal ID (senders fax number and Name)
Andrew
Sep 22, 2011 | Brother IntelliFax-2820 Laser Fax
I didn't receive a confirmation from a fax I sent using Windows 7 Fax and Scan. I does however say the fax went through successfully. Why would I not receive a confirmation
Even it shows sent successfully. But you have to check the Mail delivery sub-sysmtem, there will be display of - Delivery to the following recipient failed permanently or some notification will be there.: This may due to technical reasons. Please check and try.
Mar 03, 2011 | Compaq Computers & Internet
How do I remove the name that shows on top of a fax?
You may remove it by using the software.
The labellings you referred to is the header and footer.
You may remove them
Mar 10, 2010 | Office Equipment & Supplies
We are not able to receive any faxes from other recipients. What steps can be taken to resolve this issue.
Connect your fax to a working line then install fax film and plain receiving paper and make sure its on.Report any other problem you will get after this.
Sep 25, 2009 | Brother IntelliFAX 4100 Laser Fax
How can I remove the sending fax number on my transmissions on HP
Check the HP Officejet Pro L7300/L7500/ L7600/L7700 All-in-One series
User Guide
(page 83):
"Configure the fax header:
The fax header prints your name and fax number on the top of every fax you send. HP
recommends that you set up the fax header by using the software that you installed with the device. You can also set up the fax header from the control panel, as described here.
NOTE: In some countries/regions, the fax header information is a legal
requirement.
To set or change the fax header
1. Press Setup.
2. Press Basic Fax Setup, and then press Fax Header.
3. Enter your personal or company name using the numeric keypad, and then press OK.
4. Enter your fax number by using the numeric keypad, and then press OK.
To set or change the fax header via the embedded Web server
▲ Select the Settings tab, select Fax from the left pane, select the Basic sub-tab,
and then enter the Fax Header Name and Fax Number. Click the Apply button."
Sep 18, 2009 | HP OfficeJet K80 All-In-One InkJet Printer
How do i change my fax number
Changing the Fax Configuration
1 Click Start/Programs or All Programs/Accessories/ Communications/ Fax, and then click Fax Console.
2 In Fax Console, click Configure Fax on the Tools menu to start the Fax Configuration
Wizard.
3. On the Transmitting Subscriber Identification (TSID) screen, type the identification information (usually your fax number and your name or business name) in the TSID box. This information will appear in the header area of the faxes you send and identifies your
fax machine to the person who receives your faxes.
Aug 16, 2009 | Dell 942 All-In-One InkJet Printer
Change name that appears at the top of outgoing faxes
press Menu
press 5 then 2
select the "fax header" option
when your name appears, enter your name using the keyboard.
the keyboard is similar to cell phone keyboard.
press enter
enter the fx number when your are prompted
press enter when finish.
if you still haev problem, please click on the following link for HP Officejet6110 users' manual.
Feb 23, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Incorrect Fax Number showing on sent Faxes
the solution given is correct. happy faxing OMNIPRESENT
Oct 01, 2007 | HP LaserJet 3050 All-In-One Printer
Header
change the prefrence setting
Sep 13, 2007 | HP Photosmart 2610 All-In-One InkJet...
Brother IntelliFax-2820 Laser Fax Logo
103 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
