Question about Maytag Neptune MDG5500AW Gas Dryer
Running but taling a very long time to dry - Maytag Neptune MDG5500AW Gas Dryer
  • 10,319 Answers
The moister sensor is keep the burner to ignite to dry your clothes. First check the entire exhaust vent tubing for a blokage. The sensor will detect this and keep the burner off for fire hazzards. If very clear inside the tubing and inside the dryer as well the moister sensor is faulty instead providing you hear the spark ignitor making the clicking noise to ignote the burner when first started up
Posted on May 08, 2010
I have ahoovernextra7.5kg condender tumbledryer not drying. no heat
Check for lint build up in your exhaust.Flex hosing builds up due to condesate you are exhausting. Otherwise check continuity on limit switch on exhaust tube .Some models let motor run even though elements get shut down. Simple either open or closed. Electrical meter tells the tale.
Nov 20, 2014 | Dryers
What make the tale pipe get red hot
Engine running way too hot means that there's not enough fuel mixing with air from the carb to the engine find the pilot screw in the carb and let it out a 1/4 of a turn at a time and keep going till it's right
Oct 10, 2014 | Motorcycles
Well, I was told that Acura Vigors have an inherent problem with the power steering boots drying up and then leaking and that more and more fluid would leak out till it would just burn out the power...
Someone is telling you "fairy tales". They don't go bad that often, and when they do, they can be rebuilt and/or replaced. And NO the engine does NOT have to come out. I would be talking to another shop or technician and avoid the "Teller of Tales"
Mar 07, 2011 | 1994 Acura Vigor
I have a toyota hilux 2.7 3rzfe engine.On start up it stumbles runs rough untill i hold revs up for a while. Have changed s/plugs,fuel filter.air filter, cleaned throttle body.Any ideas on fixing this...
This was the first symptom that the head gasket was going on my hilux 2.7 3rzfe. Soon afterward I started getting the tell tale white smoke in the exhaust until the engine had warmed up and a noticable coolant loss... That can cause rough running until the 'leaky' cylinder has warmed up and dried out...
Nov 01, 2010 | 1998 Toyota 4Runner
Cant run Dust: A tale of the wired west on windows xp
It works perfectly under winXP but it takes A LOT OF TIME!!!!! to complete the installation.
You have to be VERY!! VERY!! PATIENT, and not stop, cancel or abort the installation until it finishes.
Sep 11, 2010 | Cyberflix Dust: A Tale of the Wired West...
The dryer heats up & drum tumbles but clothes aren't drying. What's wrong?
If your dryer IS heating, but you are experiencing longer dry times and/or poor drying efficiency, the following link can give you some items to check before you assume there is a malfunction with your dryer:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
The number one cause of dryer heat related problems is poor exhaust ventilation. If not vented properly, a dryer will not dry efficiently, will take longer than required to dry, and will cause the heating circuits to overheat to the point of failure. The dryer will actually seem hotter as the heating circuits begin to overheat. This is also the source of many fire hazards if not resolved. Read through the link provided and review some of the potential causes.
If you have any questions, please post back and let me know. Please include your MODEL NUMBER, so I can determine how your dryer is configured. I hope you find this information is helpful.
NOTE: Condensation inside the dryer ventilation ducting, or on the inside of the dryer door can also be a tale-tell sign of a clog, excessive duct length and/or a kinked hose.
Jan 21, 2010 | Dryers
Dryer does not dry
Problem is likely:
- heating element, or
- one of several thermal limit switches in the electrical circuitry
If you want to further pursue, let me know.
Apr 28, 2009 | Kenmore 73952 Gas Dryer
How to see the lyrics along wid hearing the song in transcend 840
U need to get the LRC lyrics file for the same.
This is nothing but lyrics after the time whne it starts.Save this with the same name as the mp3 file, in the same folder. and enable the lyrics sync.
For eg: For the song Jai Ho from movie Slumdog Millionaire: Copy paste:
[ar:Slumdog Millionaire]
[ti:Jai Ho]
[al:Slumdog Millionaire]
[00:16.13]Jai Ho Jai Ho
[00:22.64]Jai Ho Jai Ho
[00:27.45]
[00:29.83]Aaja Aaja Jind Shamiyane Ke Tale
[00:33.77]Aaja Jariwale Nile Aasman Ke Tale
[00:36.77]Jai Ho Jai Ho
[00:44.08]Aaja Aaja Jind Shamiyane Ke Tale
[00:47.58]Aaja Jariwale Nile Aasman Ke Tale
[00:50.64]Jai Ho Jai Ho
[00:56.02]
[00:58.58]Jai Ho
[01:00.83]Jai Ho
[01:04.52]Jai Ho
[01:07.52]Jai Ho
[01:12.33]Ratti Ratti Sachi Maine Jaan Gavayi Hai
[01:15.45]Nach Nach Koylo Pe Raat Bitayi Hai
[01:18.97]Akhiyon Ki Neend Maine Phoonko Se Uda Di
[01:22.52]Neele Tare Se Maine Ungli Jalayi Hai
[01:26.02]
[01:26.34]Aaja Aaja Jind Shamiyane Ke Tale
[01:32.34]Aaja Jariwale Nile Aasman Ke Tale
[01:36.66]Jai Ho Jai Ho
[01:39.78]Jai Ho Jai Ho
[01:45.84]
[01:49.90]
[02:08.15]Jai Ho Jai Ho
[02:13.34]
[02:14.53]Jai Ho Jai Ho
[02:22.33]Chakh Le Ho Chakh Le Ye Raat Shahad Hai Chakh Le
[02:29.52]Rakh Le Haan Dil Hai Dil Aakhri Had Hai Rakh Le
[02:38.90]Kala Kala Kajal Tera
[02:42.17]Koi Kala Jadoo Hai Na
[02:47.79]
[02:49.41]Kala Kala Kajal Tera
[02:52.59]Koi Kala Jadoo Hai Na
[02:55.96]Aaja Aaja Jind Shamiyane Ke Tale
[03:04.23]Aaja Jariwale Nile Aasman Ke Tale,
[03:05.92]Jai Ho,
[03:06.61]Jai Ho
[03:10.24]
[03:14.99]
[03:18.49]Jai Ho Jai Ho
[03:24.99]
[03:25.49]Jai Ho Jai Ho
[03:32.48]Kab Se Ha Kab Se Tu Lab Pe Ruki Hai Keh De
[03:40.93]Keh De Ha Keh De Ab Aankh Jhuki Hai.. Keh De
[03:49.07]Aisi Aisi Roshan Aankhe Roshan Dono Bhi Hai Hai Kya
[03:55.24]Aaja Aaja Jind Shamiyane Ke Tale
[03:58.80]Aaja Jariwale Nile Aasman Ke Tale
[04:02.74]Jai Ho Jai Ho
[04:06.62]Jai Ho Jai Ho
Apr 20, 2009 | Transcend T-Sonic 840 MP3 Player
Small seepage underneath hotwater heater.
soetimes its gaskets around flanges and heater element fixings that fail
have a good look round after drying the area with tissue etc.
leave a dry tissue round the based so you will see tell tale trace stains where its perhaps leaking from
Nov 29, 2008 | Water Heaters
Maytag Neptune MDG5500AW Gas Dryer Logo
70 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
