Question about SkyGolf SkyCaddie SGX GPS Receiver
Upgraded to the SGX and now the Caddy Sync won't work.
Upgraded to the SGX and now the Caddy Sync software isn't working properly on my computer. My SG5 worked fine with it. I removed the software and reinstalled it prompting the SGX as my GPS, but it habitually crashes and "windows searches for the problem". I am using vista with it... Anyone know the problem?
I upgraded membership to eagle but i can't get interactive holevue only i get basic green information.
what can i do ?
Posted on Apr 09, 2011
Had the same problem when i first tried to sync on 2 different OS (XP and 7) as soon as I put skygolf.com into my antivirus software as a trusted site, it worked like a charm. Hope this helps someone as this is a great gps.
Posted on Jul 09, 2010
My device will not turn on nor will it sync
This is a problem sometimes with software and with devices that have been exposed to magnetic waves. Try removing all batteries from your device. Replace the battery (ies) turn on your computer and bring up the latest software for skycaddie. Plug the device into your computer and then turn on your GPS device. Your computer should discover your device and either reinstall the needed software or inform you of what the issues are and what you should do about it. If all else fails, send the skycaddie GPS device back to the manufacture so they can "fix" your issue with software.
Best regards
Jun 03, 2014 | SkyGolf SkyCaddie SGX GPS Receiver
Axim x51v won't sync
Guys it's probably down other sync software on your system like phone sync, I had the same problem yesterday, sometime ago I had installed software for my HTC phone, check in add/remove programs & uninstall anything that sync with your computer, then reinstall activesync.
welshcob
Jan 03, 2013 | Dell Axim X51 Pocket PC
My sgx is locked up and won't do anything - won't
Remove the battery and the unit will shut down. Wait 1 minute, install battery and the unit should power up and work as normal.
Sep 18, 2011 | SkyGolf SkyCaddie Handheld GPS Unit
How do I download golf courses to my sg5.
To download courses:
  1. Launch CaddieSync and sync your SkyCaddie.
  2. Select COURSES from the upper navigation bar of the CaddieSync desktop.
  3. Select the Favorites link next to Course Search.
  4. Check the box at the left of each course you want to download to your SkyCaddie.
  5. If you want to remove a downloaded course, uncheck the course in this step.
  6. Click the Download to My SkyCaddie >> button above the Favorites list.
  7. Checked courses will be downloaded to your SkyCaddie.
  8. Unchecked courses will be removed from your SkyCaddie.
  9. Click the Disconnect button in the lower navigation bar and close CaddieSync.
If you experience problems downloading courses:
  1. Turn off the SkyCaddie and disconnect the USB cable.
  2. Close the CaddieSync application.
  3. Reconnect the USB cable from the computer to your SkyCaddie.
  4. Launch CaddieSync.
  5. Click the Sync button in the lower navigation bar to resync the SkyCaddie.
Sep 01, 2011 | SkyGolf SkyCaddie SG5 Accessory Bundle Sky...
Sir, How can i solve astro office 2000 "Out of Memory" problems, please answer.I have a problem with "Astro Office 2000" Software. It's kind of Astrology (kundali making / match making) software. I have...
I will assume all other software functions. You replaced and upgraded memory. Did all memory chips used have matching clock speeds? ( if clock speed not matching memory can either not work or be sporadic) You should check your computer settings and verify the memory value (1 qb) is showing.
Did you in place memory in proper location (slots)? Did you fill all slots with 250 GB (assuming 4 slots)?
did you try removing and reinstalling software "Astro"?
Oct 26, 2010 | Computers & Internet
I RECENTLY PURCHASED A NEW COMPUTER ( WINDOWS 7 ) AND IT WILL NOT ALLOW ME TO SYNC MY SG-2 SKY CADDY. MY NAME IS BRUCE ALLACHER - ballacher@cox.net user name platteview 1 password riverwild
If your SkyGolf came with software, you should install it first. If you installed it and it does not work, go to the software and check for updates.
If that fails to work, UNINSTALL the program, and re-install it.
Make sure you DO NOT connect the device to the computer until the software is fully installed.
Check for updates after installation, and the reboot.
Then attach your device to the computer, and it should recognize it.
Good luck
Oct 13, 2010 | SkyGolf SkyCaddie SG2 GPS Receiver
Registration
Where do I find Caddiesync>
May 28, 2010 | SkyGolf SkyCaddie SGX GPS Receiver
Trouble sync'ing with two computers
Hiya, I manage to sync with both home and work, I upgraded to a Treo 650, and sync'd at home, then deleted my work user, and sync'd at work... and it's worked fine. I'm able to add tasks, events, apps etc either at home or work, and they successfully sync with the other machine. The only issue I've had is once or twice, my photos have doubled up, but that hasn't happened often. hth David
Sep 11, 2005 | Palm Treo 650 Handheld
SkyGolf SkyCaddie SGX GPS Receiver Logo
980 people viewed this question
Top SkyGolf GPS Experts
Oloyede Monsuru
Are you a SkyGolf GPS Expert? Answer questions, earn points and help others
