Not recognizing dvd says ''err'' - Televison & Video
Alba DVCR-2 Err:03, Err:02, Err: 01 problems
you have a faulty SYSCON MICROCONTROLLER.+faulty associates circuits, like CLKS, RESET.
you must go to the repair shop TV for fix it.
However you can try as the last thing before to go the repair shopt, Clean tHE VHS+DVD, with tape cleaner+disc cleaner too.and Proof
God bless you.
Aug 02, 2012 | Broksonic DVCR-810 DVD Player/VCR
Bluetooth err
this bluetooth have search option or" connect dvd to dvd for transfer.
May 30, 2012 | Durabrand Televison & Video
Portable DVD player will not recognize a disc. no matter what disc I put into the player I always get ERR No Disc. there are no troubleshooting codes in manual that came wtih player for this problem. I...
Your laser in the player is most likely out of alignment therefore it will not recognize a disc if its in there. There might be a possibility that the laser can be adjusted but I can't be sure since I do not know what type of player it is.
Dec 22, 2010 | Video Game Consoles & Games
Err Disc
did you try another dvd? if yes, and still having issues, sounds like you got a defect product.
Oct 16, 2009 | Jwin JD-VD149 DVD Player
2004 Honda Odyssey DVD ERR message
sound like the dvd player need to be change if not under warranty easly get one from a junk yard for a fraction of the cost.
Aug 22, 2009 | 2004 Honda Odyssey
Does not recognize DVD, err
it is because it only supports MP3, WMA, and JPEG playback.
Jul 18, 2009 | RCA DRC618N Portable DVD Player with...
Dolby portable dvd player has no disc or disc err
You will have to get the laser replaced.
Thanks, Frank Z.
http://www.attechcomputers.co.cc
3868607368
Jun 24, 2009 | Initial IDM-1731 Portable DVD Player with...
Dsc-363 displays code " oc err 1 "
It's output power amplifier ic problem. change ur output ic
Mar 08, 2009 | Pioneer DV-363 DVD Player
DVD appears to not be reading or recognizing discs
Unfortunately your DVD drive mechanism looks to have bit the big one.
You can try taking it apart, removing the top of the drive and cleaning the lense. Work it up and down. Use a q-tip with a little squirt of windex on it.
Reassemble and try it again. If you get the same results, it's time for a new DVD player.
Dec 27, 2007 | Toshiba SD-V392 DVD Player/VCR
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
