Question about Grilling
I press the button, I don't get the click. The
I press the button, I don't get the click. The battery is fresh and all the connectors are connected
    Problem Solver:
  • 16 Answers
If the ignitor is in a Jenn-Air and/or located on the front control panel beside the gas valves, the body of the ignitor and/or the wire is melted. Inspect the body of the ignitor. If it is melted, you have more problems with the flame being where is should not be.
Posted on Aug 25, 2010
Hello ! I have a problem with my apc smart ups SUA 1500VA. It changed to battery use from AC line altough the AC line was working just fine. I don't know what happend. I found it like that when i came...
Battery not connected properly. Check that the battery connector (rear panel) is fully engaged.
Press the on/test button once to power the UPS and the connected equipment.
Make sure UPS has nothing connected to it. Check the Fuses for the battery inside in the back of the UPS
Unplug UPS and batteries. Push the on button to clear the logic. It may or may not flash the LED's Once the fuses are checked, check the logic boards for any burn or discoloration.
Sep 25, 2011 | APC Smart-UPS 1000VA UPS System
HI, i have a IBM thinkcentre S50 8086-21G and after resinstall on my hard drive the XP SP2 version , i don't have access about the USB connector and can you help me about this? i don't find the...
What exactly are you trying to connect to the computer via usb? If your talking about generic devices such as usb mice and keyboard then you will need to reinstall windows again. Devices like these use a generic usb driver that is installed during windows xp installation. There isn't really anyway to install this driver that I am aware of other then a clean install of windows
You could attempt to repair the windows system files, but I can't guarantee it will help.
You will need a windows xp disc. -Insert the disc. -Press the "Start" button -Click on run -Type "cmd" and press enter -Type "sfc /SCANNOW" and press enter
This will check for problems with your system files. Hope this helps
Clean install of windows (Delete all partitions and re install fresh) would be the easiest way to fix the driver problem. I did also find this article on how to manually install the usb driver. Best of luck http://support.microsoft.com/kb/329632
Jul 10, 2011 | Computers & Internet
How do i connect a wireless x box 360 controller to my x box
  1. Turn on your console.
  2. Press and hold the Guide button on the controller until the controller turns on.
  3. Press and release the connect button on the console.
  4. Within 20 seconds, press and release the connect button on the controller.
  5. When the lights surrounding the power button on the console stop flashing, the controller is connected
Each connected controller is assigned to one of four positions. Each position corresponds to a lighted section around the console power button and the controller Guide button.
If the controller does not turn on, check the batteries. Insert fresh AA batteries, making sure they are correctly positioned in the battery case.
Jul 04, 2011 | Video Game Consoles & Games
Controller will not stay connected. continuously stops game and says "please reconnect controller
How to connect a wireless controller
  1. Press and hold the Guide button on the controller until the controller and the console turn on.Press and release the connect button on the console.Within 20 seconds, press and release the connect button on the controller.When the lights surrounding the power button on the console stop flashing, the controller is connected.
    • If the controller does not turn on, check the batteries. Insert fresh AA batteries, making sure they are correctly positioned in the battery case.
Dec 28, 2010 | Microsoft Xbox 360 Wireless Controller
It's been sittting for quite a whils with the battery out. With a freshly-charged battery, it won't start up now, pressing and hlding buttons gets only a second of display.
Insert freshly charged batteries, Turn camera "ON" then remove batteries. While batteries removed, press and hold the shutter button for about 30 seconds. Insert batteries, turn "ON" then press the reset button on the bottom of the camera.
Dec 15, 2010 | Nikon D70 Digital Camera
Can't make the player turn on. What do I do?
First try and reset the player.
1. Press and hold the Power/Menu button for approximately 20 seconds.
2. Release the Power/Menu button.
3. Press the Power/Menu button again to turn on the player.
If that does not work try this,
Remove the battery - Power cycle the player
1. Connect the device to the PC.
2. Leave the device connected for about 2 minutes.
Turn on the device
1. Disconnect the player from the PC.
2. Insert a fresh AAA battery into the player.
3. Turn on the player.
STEP 1 - Connect the device to the computer
1. Remove the battery from the player's battery compartment.
2. Put the hold/lock switch to lock.
3. Plug in your device to the computer.
STEP 2 - Format the device
1. Double-click My Computer.
2. Right-click on the player, which might show up as a Removable Drive, select Format.
3. Click Start.
4. Click OK when a "Format Complete" dialog appears.
5. Click Close.
Nov 12, 2010 | SanDisk Sansa m240 MP3 Player
Controller problem
This normally happens when the battery,s in your Wii remote are low. Try a new (fresh) set of battery's. The alkaline type works best!!
Dec 28, 2008 | Nintendo Wii Console
I have a logitech wireless mouse, i don't have the manuel or anything that came with it and i'm trying to connect it to my home desktop computer.. the piece that connects to the computer works the lights...
Click on the connect button on the remote (part connected to the PC) and click on the connect button on the mouse. Move the mouse around after you press that button. It should connect.
Also make sure your batteries are fresh.
Once working, I've found that Microsoft's Intelli mouse driver does a better job then Logitech drivers.
Jul 25, 2008 | Computers & Internet
MICROSOFT WIRELESS MOUSE FOR LAPTOP DOESN'T WORK
There's also a connect button on the USB connector. Plug the connector in and press the connect button underneath until the light flashes. Release the button and click the connect button on the mouse until the USB light is steady.
May 16, 2008 | Targus PAKP003U Keyboard
DVD player remote is dead
It's quite possible that something got spilled into the remote. I've had this happen a bunch of times, & the remote goes dead! What I did was to take the remote apart by first separating the two halves with a knife & a lot of patience. The two halves are connected together by little clips of plastic all around the perimeter of the remote. Once you start to pry at it, you'll see little indentations ~1/8" - 1/4" wide, every here & there...these are the clip locations. Try to separate them without breaking them. Once you have the remote apart, there's four parts to it; the two halves that you just fought with, the circuit board, (PCB), & the rubber matt that contains the buttons. What you'll need to do is to clean the PCB thuroughly with rubbing alchohol, making sure to dry it completely. Do the same to the other parts, being carfull not to break anything but at the same time being sure to get them clean! Check that there aren't any broken wires or components, resolder anything that may need it. Once you're sure that everything is connected, clean & dry, reassemble the unit by first placing the rubber matt over the PCB, (line up the buttons & make sure it's in the right orientation. Then press the front cover onto the PCB/matt while holding the whole thing aligned, then put on the back cover & click it all together with the little clips. Be extra carefull that the battery connectors go into their proper slots. You may also want to bend the battery connectors alittle bit, in such a way as to make sure that the battery makes a good contact, don't go crazy, you don't want to break them! Once you have it all back together, put in some fresh batteries & try it out! If it still doesn't work....go buy a universal remote!!! Don't worry....be happy!! Good luck!!!
Don
Jun 01, 2007 | GE DGE100N DVD Player
Grilling Logo
29 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
