Question about Whirlpool Dryers
The dryer spins but does not dry clothes,and the timer does not work with it ? this a whirlpool dryer Model # mso404416.Type ELE-2406028-fm54
    President:
  • 1,430 Answers
It could be several things but most likely the heating element should be around 9-13 ohms. If that checks good check the thermal cut out, thermal fuse. Most of these parts are very inexpensive and all are easy to replace. There is a video at www.appliancehelponline.com/servicemanual.html that can walk you thru the troubleshooting of your problem. It may be a different model but the troubleshooting will be the same. You can also get diagrams and illustrations of your specific model by entering your model #. All parts come with installation instructions. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles.
Posted on May 08, 2010
What is the capacity of a Kenmore dryer model 110 62622100
The dryer should hold what the washer will hold especially if there a matched set this one looks like a super cap. hope this helps
Feb 18, 2015 | Kenmore Dryers
My whirlpool dryer model ler3624jq1 type d433-ele-2406028-fm54 isnt drying my clothes completely
This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes, or the heating element has gone bad, burnt in half and is making contact with the case to provide it just enough power to barely heat. The second thing is a very rare occurance. I would turn the dryer on, find out where the air vents out to, and with the dryer running, go to where it vents and check to see if there is a strong flow of air. 9 times out of 10 that is going to be your problem. Another way to check air flow is to just pull the vent off the back and let the dryer run and see if your clothes dry faster. If you do it that way and they still take a long time to dry, then you'll probably need to replace the heating element
Jun 17, 2012 | Dryers
We have an estate by whirlpool dryer that quit working. During last cycle it made a loud bang noise that ended the dry cycle and the clothes inside were dry. When we tried to restart it, it wouldn't...
The fuse is tied into the door switch circuit and looks like this:
Unplug the dryer and remove the rear cover. All the heater components is back there.
Service manual and more info are HERE at my FixYa tip.
Jul 17, 2011 | Estate TEDX640JQ Electric Dryer
I have a whirlpool Dryer type: D433-ELE-2406028-FM54, Model: LER463JQO. It takes atleast 2 cycles to dry the whole load completely, and I'm wondering what I can do to fix this problem?
You may have a clogged vent pipe. I would take it apart and clean it all out.If that doesn't help then you may have other problems.Could be thermostat or one bad element. Hope this helped.
May 05, 2011 | Kenmore 600 6965 Electric Dryer
Dryer will not start whirlpool model #LER4634EQ2 SERIAL #MK0296464 TYPE#D433-ELE-2406028-FM54
It might be the fuse.3727d80.jpg Be sure you do a bit of cleaning before you replace the fuse or it might just blow again.a611954.jpgca0922b.jpg Look for lint. I looked up your model. I once did a write up about what goes wrong, how to get into the machine, a training manual and videos. HERE
Bonus stuff
Helpful? Rate please.
Sep 19, 2010 | Whirlpool Dryers
Whirlpool Electric dryer type-DWJR-ELE-2406028-FM54. model LER7646JQO the heating element get very hot. the dryer does not turn on. the drum does not turn either.
If the heating element is getting very hot that means there is no air flow across it. If the drum doesn't turn then the blower is not turning causing the element to get very hot. Could be drum belt, drum rollers, or motor.
Mar 17, 2010 | Whirlpool Dryers
Wont dry
WHAT BRAND IS ( LG WP KENMOOR OR MAY TAG) I NEED TO KNOW THANKS
Apr 04, 2008 | Dryers
Dryers Logo
148 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
