Question about GE Spacemaker JVM1640SJ Microwave Oven
I have a Ge microwave model#je1860bh002 when i turn it on sparks acure after 5-10 secounds from inside a plastic cover on top of the microwave along with an electrical smell.
    Brigadier General:
  • 4,090 Answers
Behind this cover is usually a small metal blade fan that causes downdraught to circulate the air and electrons. It sound like it has a short circuit and should not be used. FIRE can be the result of persisting in turning it on. It should be repaired Replacement part is about $55 plus fitting so around $130 should be average.
Please rate my help++++Thanks for using FIXYA
Posted on May 08, 2010
GE Spacemaker XL1800 sparking from behind wave stirrer cover
Microwaves use a magnetron to generate microwave energy and direct it a rotating blade wheel to spread them around the inside of the oven. If there is any metal in the area to be heated, or any of the blades are bent, even a bit, the microwave energy can be reflected back up to the magnetron area. In this area there is now too much power and it sparks away, so it does not heat the item in the oven.
Because it is sparking it is now a safety hazard the sparks may melt and set fire to plastic parts in it. This is serious it could burn your house down. Bin this microwave and cut the cable off it to make sure no one else ever uses it.
Dec 20, 2013 | GE Profile Spacemaker JVM1871 Microwave...
GE JE2160 31/2 years when it is turned on sparks fly from the cover plate located on the right inner wall. If it can be repaired is there an estimate of cost. Thanks gm.eiland@gmail.com
All you need is a new WaveGuide Cover. It is fitted with usually a screw or plastic clip and is fitted from inside of the cavity, where you place your food to be cooked. No taking anything to bits, just the cover.
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Jan 05, 2011 | GE JE2160 Microwave Oven
When you turn the microwave on it runs for a few secounds makes a sparking noise.
look for dirt inside the cavity or the wave guide cover it's arcing... make sure you have something in the microwave, don't run it empty
Apr 03, 2010 | Kenmore 80599 Microwave Oven
GE Profie JE1860SH 04 microwave sparks
Our JE1860SH was also sparking after a few seconds. The GE tech pulled the upper round disk and found the problem. The plastic was burned and the round metal which is behind the plastic dome was arching with the frame. Lasted seven years expected more especially from a GE product. So my suggestion is to remove the dome and check it out.
Jan 03, 2010 | GE Profile Spacemaker Over-the-Range...
Electrical discharge/sparking under round plastic cover on inside of micro top
Quite often this is due to grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover.
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
Your owner's manual may cover this.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart or Lowe's.
If your waveguide cover is burned, it will need to be replaced.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Oct 29, 2009 | GE JVM3670 Microwave Oven
GE microwave -crackles and sparks as if metal inside
The problem you are having is that the magnetron that does the heating is shorting out and it needs to be replaced before it damages the inside covering of the microwave. www.mwoparts.com is a good source for magnetrons or other similar sites. To replace is easy enough. Taking the cover off with the power off, you will find it behind and on the top right side of the control panel. It is held in place normally with just 4 screws and two wires with terminals attached to it. So removing and replacing is pretty straightforward. Just be sure all the power is off until you have everything back in place. Good luck.
Jan 23, 2009 | GE JES738 Microwave Oven
Microwave ovens
The Magnetron has failed, causing the waveguide to become damaged. If the waveguide is damaged/burned the microwave can not be repaired and should be replaced.
Dec 25, 2008 | GE Advantium 120 Convection/Microwave Oven
GE Spacemaker appears to be sparking inside/top
1.Needs to remove that disk and clean the grease under it.
2. With sand paper clean dark burn spots.
3. Apply touch paint on open metal spots.
4.Put everything back.
Nov 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave is arcing inside
The waveguide cover is usually about the size of a playing card and often held in place by a plastic rivet.
In some models it is the plastic ceiling.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If you need more specific help, please reply back with your brand and full model number.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Nov 13, 2008 | GE JES1384SF Microwave Oven
GE JVM1860SF001
Be sure the oven is unplugged.
There are two Phillips head screws on the very top of the outside of the cabinet above the vent.
When they're removed the vent grille just snaps out.
Sep 12, 2008 | GE JVM1860 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
142 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
