Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
My ryobi trimmer wont start. i cleaned the carburater and it will only run if i pour gas in the carburater and it will run for a sec ,it is a old one
  • 198 Answers
Make sure the float valve is not getting hung up---it has to move up and down very freely
Posted on May 11, 2010
Fuel mixture ratio for Ryobi SS300 weed eater
Are you sure about the model number? I see several 30CC engine string trimmers by Ryobi. Two are the Ryobi RY30040B (SS30) and a RY30544 (SS30).
For both of these models, mix a high quality 2-cycle engine oil at 2.6 oz. per gallon of gasoline to pour into the gas tank. This ratio is used in several other Ryobi string trimmer models. Many Ryobi product manuals are available here: https://www.ryobitools.com/power-tools/support/manuals . Most Ryobi gas powered and 40V battery-powered tools will have a model number that starts with RY. The 18 V battery powered models often start with a P.
I hope this helps. If you add a comment with the actual model number, I may be able to provide more information.
May 20, 2016 | Ryobi Garden
My ryobi cs30 gas trimmer (3 years old) has been difficult to start this year, has been getting worse all year and now wont start. What's up?
Most likely it is the spark plug, but could be a dirty fuel system. I'd start with the spark plug then go from there. you can also use a good quality fuel injector cleaner in your gas to help keep all your small engine carbs clean. If the problem persists there is a fuel filter inside the gas tank that plugs onto the end of the fuel pick up line that could be clogged. Worst case a carb kit can be gotten for them for about $20 bucks. Hope this helps. Please vote yes, thank you.
Nov 01, 2010 | Ryobi Gas Hedge Trimmer
My 2 cycle gas trimmer will not start? It's only 2 years old
Have you cleaned the spark plug , replaced it, or the carberation system?
If not, then this could be the problem.
Plug builds up corrosion over a period of time and cleaning is requird. also resetting the gap.
GAs goes stale too to flush out the old gas and put new gas.
Jul 12, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Trimmer won't stay running without starter fluid
drain any old gas/fuel mixture out of unit.
purchase new gas and mix with oil as recommended for your engine.
clean the air filter on the unit.
pull the spark plug and clean with carb spray and reinstall...
you also may need to remove the carb and clean any jets with carb spray... old gas can turn into a shellac'ish type goo and foul up the works...
I recommend draining all fuel after usage...
May 29, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi gas trimmer
I don't mean to over simplify this, but are you using fresh gas? Gas string trimmers are extremely ticky when it comes to gas. They like it SUPER fresh. And while the gas and oil mixture should be right, it can be off a little bit and still run. Try draining all of the gas out, and then filling up with fresh mix. This is ALWAYS my first step with string trimmers, and it fixes the problem 75% of the time.
Hope this helps!!
chad
Oct 03, 2008 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi gas
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. also check the primer bulb for pin holes and proper seating/seal. if that doesn't work have the carb repaired at a service center or replaced.
Jul 05, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi string trimmer 32.1 what do mix gas and oil or just gas?
Ryobi trimmers I have had use a 32:1 oil mix. Just pick up a little bottle of Ryobi 2-cycle oil and read it to see that it will give a 32:1 mix in a gallon of gas. Pour it into a gallon of gas, and maybe a little fuel stabilizer too, shake it up and you should be good for the season.
May 28, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
492 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
