I have a WD-52628. I just had some parts replaced because I couldn't turn it on. Now I can't get to the device menu to setup the components. All I see is either a completely blue screen or a static screen.
  • noma10 May 08, 2010
    I can't get the service manual to open.
    I still need to know if there is some kind of command that will allow me to use the device options so I can set up the components for my Mitsubishi WD52628 TV
  • 666 Answers
This problem sounds like its linked to the repair technician not fully connecting or jossling the inputs loose and will likely need to be opened again
hope this helps
Robb
Posted on May 08, 2010
  • 12,061 Answers
Http://www.eserviceinfo.com/index.php?what=search2&searchstring=DLP
www.915p026010.com/manuals/Mitsubishi-WD52628-915p026010-manual.pdf
www.segaarcade.com/pdfs/hod4/V29-V30-V31_Service_Manual.pdf -
OK, please go to this link(s) above, there you will find a Service and repair manual, above that is your user manual and above that is another link for a service manual, if the other's don't work, Now, inside these manuals, is everything you will need to troubleshoot and repair your set. This is the manual, that engineers use to repair these units.
Mitsubishi wd 52628 input issue, blue screen and input error
there are no analog channels, they are all digital now, be sure your antenna is facing proper direction before scanning for digital channels
Apr 20, 2013 | Mitsubishi WD-52628 52" Projection HDTV
I replaced the lamp in my Mitsubishi WD 52628 and the tv will still not come on and the lamp light still blinks
"Initialize" a "factory reset". Power on the tv, on the original remote, enter "MENU 1,2,3 ENTER". This will get you to the factory reset window. Initialize the default reset and you are fixed. Try this before ditching the set or tearing it apart. Good luck and post your results for everyone here with the blinking green timer light issue. Thanks.
Apr 25, 2012 | Mitsubishi WD-52628 52" Projection HDTV
Wd-52628 flashing blinking light
Using your original remote, power on the tv, enter "menu 1,2,3, enter" to "Initialize" the "factory reset" once the window comes up choose to reset to default. That should fix the blinking green timer light.
Jan 16, 2012 | Mitsubishi WD-52628 52" Projection HDTV
I have a Mitsubishi WD 52628. I replaced the tv
try turning it on hold the menu button for eight seconds menu pops up try reseting the settings again as before you had the problem
Jan 23, 2010 | Mitsubishi WD-52628 52" Projection HDTV
Green blinking light
needs to be reinitialized press menu 8970 to reset
Oct 15, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Timer light blinks constantly
Is it Mitsubishi WD-52628 TV? please confirm model number.
Unplug TV from AC outlet for couple of minutes, replug back in, turn power ON and check, still same problem?
Lets read error code in TV, press Device and Menu buttons on front of TV at same time for 6 seconds that will activate error code read process. Led will flash in 2 sequence with half second pause. count it and let me know the error code to proceed.
Thanks.
Jun 29, 2009 | Mitsubishi WD-52628 52" Projection HDTV
Mitsubishi wd-52628 flashing green timer light
If the power/timer led is the one blinking constantly
the most likely problem is two 3300 mfd caps and 1 to 8 1000mfd caps on the power board.
could be the DM board or caps on it as well.
Jun 17, 2008 | Mitsubishi WD-52628 52" Projection HDTV
Mitsubishi WD-52628 52" Inputs look like old cable scrambled channels
Change the 1000uf @16v capacitors on the FMT board that should solve your problem. You will most likely found that they have swelled. Let me know if you need further info.
Apr 04, 2008 | Mitsubishi WD-52628 52" Projection HDTV
WD-52628 Mitsubishi - change inputs
We had the same problem. Luckily, we had a service contract, so it was serviced yesterday. The fix involved the service guy going through a "service menu" and resetting the TV that way. He was not "allowed" to tell me how I can access the service menu, however. I do plan to research this on the internet in case it happens in the future. It is basically a software/computer problem, and unplugging the TV isn't enough to clear it unless the TV is unplugged for "a long time." The technician said the length of time depends on the condition of your capacitors. Anyway, as a temporary fix, he showed me that you can go into the PIP mode. The device toggle for PIP apparently did still work with mine, so I was able to switch the device on the secondary picture and then switch it to primary, then toggle the PIP off. Good luck!
Jan 05, 2008 | Mitsubishi WD-52628 52" Projection HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
