Question about Brother DCP-110C All-In-One InkJet Printer
Error A1 Can anyone tell me what is error A1? Printer can't print black and yellow, inks changed but still nothing. When I print 77 report it shows A1 error. It shows machine error 0000. Thanx
  • banemil Apr 02, 2008
    Thank you, must be the ph and yes generic inks were used.
  • 832 Answers
This is no error! It indicates that the scanner is open (what you have done to replace the carts or when there is a paperjam).
It might be that the ph is clogged (mostly due to generic ink).
Run the manual cleaning procedure 3 times!
If there is no more bk /y you need a new ph.
Posted on Mar 28, 2008
Brother MFC-J6510DW maintenance mode report
unless you see anything in the report that says, "incompatible ink" then there's nothing else to worry.
Feb 13, 2018 | Office Equipment & Supplies
Hi i have a hp officejet 4355 all in one printer at my place. i m having problem fixing with the cartridge as it is showing error. pls guide
Problems with Hewlett Packard Officejet 4355 printing can often be due to issues with the cartridges. The printer has two cartridges, one black and white, and one color. Both can be physically inspected for problems. The printer also has a self-test report to determine if there is a non-obvious problem with the cartridge. The report can provide valuable information, including status.
  • 1
    Take the black ink cartridge out of the slot on the right. Be careful not to touch the ink nozzles or the copper contacts.
  • 2
    Look at the cartridge and make sure that the plastic shipping tape isn't still attached. There shouldn't be any tape covering the ink nozzles.
  • 3
    Replace the black cartridge and then perform Steps 1 and 2 on the color cartridge. The color cartridge is the one on the left side.
  • 4
    Print a self-test report. Load paper in the tray and press "Setup." Press "2" and then "4." The HP Officejet 4355 will print a report. Make sure the lines of color extend across the page. Missing, faded or streaky lines can indicate a cartridge failure. If the color bars don't show as black, cyan, magenta and yellow, you should clean the cartridges.
  • 5
    Press "Setup" and then press "6" and then "1." The print cycle will commence. Allow it to complete and then print another test report. If the test still shows errors, replace the cartridges.
  • Feb 01, 2011 | HP Officejet 4355 All-In-One InkJet...
    Bought new ink and not all the colors are printing black ink works good but colors red and yellow not showing up
    Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached.
    To reattach the cartridge check the following steps :
    turn on the lid of the printer and then remove the cartridge from the printer head.
    Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report.
    Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
    Nov 16, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
    Windows Ink Cartridge Empty false error message.
    slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
    Oct 28, 2009 | HP C6280 All-in-One Printer
    I changed ink cartridge and now nothing is printing
    Did you pull the plastic tab off the ink cartridge?
    Oct 26, 2009 | Dell A940 All-In-One InkJet Printer
    0xc05d1281 HP-C7280 Ink System Failed -- tried clearing the error status still same problem, also noise from the print head sounds like plastic gears sliping, print head moves back and forth gears slip and...
    printer did not tell about empty cartrigde it just showed that the black was low but not empty -- decided to replace the cartridge early and that ficed the problem!! ?????
    Oct 19, 2009 | HP Photosmart C7280 Laser Printer
    Prints photos with yellow horizontal stripes.Hv downloaded HP printing diagnostic utility and no errors were reported. If just using scanner to copy photos, prints fine but copying photos in library p
    go into the printer and do a test print. start>printer & faxes>right click on the printer in question>properties>printer preference button> test print ... try the printer's own test print. This is usually caused by a poor print head, low ink, poor cartridge or the need for calibration. Look in the maintenance tab in the printer properties for head cleaner, jet cleaner etc. This also happens with refill ink cartridges.
    Apr 28, 2009 | Office Equipment & Supplies
    Have changed Ink Black and Colour... Stil getting error Message.
    Make sure the tape covering the hole on the bottom of the black cartridge is removed. and then go into the printers folder and right click on your printer icon and go into the properties of that printer and there should be something in there to tell it that you changed cartridges and you can also print a test page as well.
    Feb 06, 2009 | Canon PIXMA MP160 All-In-One InkJet...
    Epson C48 inkjet printer flashing lights
    I can tell you how to fix this if anyone is interested - report back if so.
    Jan 13, 2008 | Epson Stylus C48 InkJet Printer
    Ink replaced, but sows nothing
    A yellow exclamation mark in any application means the attatched item to it is usually in error state, but you say the printer works fine. Most people would tell you to not touch what is working!!! But leaving anything showing error risks further confusion and problems. I think that you problem is probably very simple. Do you know hao to reset your ink levels. Read your manual that came with disk or go to the onscreen help. You may find this will remove the issue. If it does not, then you may have a corrupted driver etc, and may need to uninstall the printer, and reinstall it again. Good luck.
    Aug 30, 2007 | HP Photosmart C3180 All-In-One InkJet...
    Brother DCP-110C All-In-One InkJet Printer Logo
    300 people viewed this question
    James Cagle
    James Cagle
    Samyfam
    Samyfam
    Jim Keysor
