Question about Kenmore 64892 Electric Dryer
Our dryer stopped working in the middle of a load. Now when I press the start button the timer does nothing but click. I am not sure but I thought it might be the push start button was faulty. Any ideas?
    President:
  • 1,382 Answers
  • Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
  • If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
  • Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Hope this will fix your problem for sure.
Posted on May 08, 2010
My whirlpool dryer wed9400sw2 is over a year old, but has stopped running. The last load was left damp. When I tried to restart the load, I pressed Power, Start. I hear a brief click from the start...
Hello Cdewlodge, we sincerely regret to hear this. If resetting the Dryer did not help then we would recommend scheduling service. If you would like for us to schedule service for you, please email us your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com.
May 28, 2017 | Whirlpool GEW9250 Electric Dryer
Dryer was working fine. Finished one load. Second load, pressed the start button, it wouldn't start. Thought door didn't close all the way so I opened/shut it, pressed start. Nothing. Is it time to spend...
a simple solution could be take a pencil and push the door switch in and out if it clicks its probably wrking if not replace also check your breaker hope it helped and make sure your timer is on a cycle
Feb 27, 2011 | Roper Dryers
Whirlpool estate teds840jq2 dryer just stopped working. I can hear a clicking sound from the timer when the timer is turned to a setting but when I press the start button, nothing happens
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 16, 2010 | Estate TEDS840JQ Electric Dryer
My Roper dryer suddenly won't start. Was running
Is it gas or elec?
Have you checked the breakers?
Does the outlet have power?
Model# ?
Try setting timer in a different cycle.
Make sure door is completely closed.
Push door switch in manually does it click?
Please update lat me know what else I can do to help.
Ken
Mar 17, 2010 | Roper Dryers
My Dryer just stopped working in the missle of a
with your door open have some one try and turn the dryer on while you hold the button in and turn the drum by hand to get it started.
if it starts the your motor may just have lint build up around it causing the contacts to be dirty.
there is a couple of other things that might have gone wrong the main control board has gone bad or the door switch, motor has gone out
Jan 30, 2010 | Kenmore Elite HE4 Electric Dryer
Whirpool LGR7646DQ0 dryer won't start -can hear timer running, timer stops when door switch is pushed, but dryer will not start.
there is a white fuse in back of machine.take back panel off and check for continuity to fuse.you can also put the two wires together and plug your machine in and make sure nothing is touching,and hit start button.UNPLUG FIRST.the fuse sits on blower housing.it will be white with a black strip down the middle and only two wires.
Mar 06, 2009 | Dryers
I ahve a Roper dryer that won't start. It started acting up a few
HI thanks for the question Thts a sure sign of a bad motor, stopping In the middle of a cycle. and then starting again, and now no start replace the motor
Nov 24, 2008 | Roper REX3614KW Electric Dryer
Kenmore dryer stopped working, start button does nothing
hi thanks for the question i would check the thermal fuse at the back remove back panel . by the air duct theres a small thermal fuse with 2 smaller blue wires to it check that it does cause this thanks appliance doc
Sep 13, 2008 | Maytag PYE2300AY Electric Dryer
Dryer stopping in middle of cycle but timer continues to run.
oK " It's your timer, it has to be replaced
it's not going threw all it cycles, will start but will not finish
not a big job, unscrew plate on back at the top you will see
timer , take it out and replace it
( can not stress enough that you have to unplug the electrical cord from the wall socket before working on a dryer or any appliance )
Jan 24, 2008 | Whirlpool LER3624JQ Electric Dryer
need the model # from the unit should be where the door closes to the CYE4000AWW is not a Kenmore Model
Jan 21, 2008 | Magic Chef CYE4000AWW Electric Dryer
Kenmore 64892 Electric Dryer Logo
123 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
