Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
John Deere 310 A Hydralic problems
I have a John deere 310A back hoe loader, I do not seem to be getting enough hydralic fluid through the pump form the transmision valave, I do not get any return to the cooler from the transmision valve I took the valave apart and am going to replace all of the gaskets in the valave, Do I need to replace the transmision pump that feeds the transmision valve several pepole have told me that there is an internal pump in the transmision that needs to be repalced is it the transmision pump.
I also know that the main pump works fine when I feed the return line from the cooler to the pump with fluid everything works great. Do I need to replace transmision pump? to fix the hydralic problem also is it easier to do by removing the cover on the transmision?
Jd 310 A, boom down to dig then back off stick alittle and circut loses power.
Posted on Sep 03, 2010
J deere 310 leaks between the hydraulic filters there is silonoid between them
Wipe down and clean the filter, filter housing and hydralic lines, run your jd until you see hydraulic fluid, stop the machine and look to see where it originated from... If it's from the filter, change the filter, make sure the old oil rings are no stuck on the housing, and there's a o ring that comes on the new filter, pre lube the filter o-ring and install,,, if it the hydralic housing or pump, check for hair line cracks, check the threads on the filter head on the housing for cross threading, and last but not least and the greatest possibility... The hydraulic line connections to the filter housings and pump... The will most likely be the issue... Spray brake cleaner all over the connections to clean them run the machine and look to see which one is leaking... When replacing the hose connections, replace with a quick connect hose end to save on value time and efforts in the future.
Oct 13, 2013 | John Deere 420,1020,2010,2020,2510,2520...
I want to know why my hydralic mower deck lift won,t work
Did you use ATF or hydraulic fluid? Possibility it is air bound?
Apr 12, 2012 | John Deere Garden
4020 john deere compact diesel. Lost hydraulics and do not know how to check fluid level. Worked good and just quit. Can not see any leaks??
I doubt that it is the fluid level...it's been a few years... but I seem to remember there being a couple at the front of the motor that ran the hydralic pump...I am wondering if your problem is not there...tthe hydralic pump sits under the fuel tank at the front of the tractor... check there to see if everything is working right there...of course it could be the pump its self that has gone bad...
heatman101
Aug 24, 2010 | John Deere 4020 Gas & Diesel Tractor...
My father in law has a 1980 410d john deere
did they rebuild the hydralic pump and if so they need to do it again and check the valves in it
Sep 18, 2009 | John Deere 420,1020,2010,2020,2510,2520...
I NEED INJECTOR PUMP SCHEMATIC FOR JD 400 PUMP
I'm getting hydralic fluid in my engine oil. I was told that it's coming from my power steering unit. It's a JD 400 tractor/backhoe. Would this be correct?
Jun 04, 2009 | John Deere 420,1020,2010,2020,2510,2520...
I just purchased a 2440 john deere tractor it was outside for some time so there was H2O in the hydraulic fluid. I changed fluid but I get very little movement from the tractor when I release the clutch. I...
would say that your variable displacement pump has rust or other on/inside, it.
Are you using hydralic fluid (not eng oil) in her?
Can you let it run on blocks for a bit - drain and re-fill transmission?
Apr 11, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Problem with plowing with my john deer 4440 tractor
check you air cleaner and fuel filters if they are dirty it will rob horsepower
Mar 31, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
1,130 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
