Question about Toshiba Satellite A135-S2276 Notebook
They wont let me put a v-neck on - Toshiba Satellite A135-S2276 Notebook
    Brigadier General:
  • 4,090 Answers
Can you explain the question clearly This does not make any sense at present what does Vneck have to do with a laptop
Posted on May 08, 2010
When adding gas in the Jimmy gas is pouring out from line.
You best replace the filler neck so it wont leak, and operate properly. I do not think a vacuum, vapor lock has occurred.
May 24, 2016 | Cars & Trucks
Shower and bath sink wont drain.
Bath sink will be on what is called a "wet vent" for the shower.
That means they are on the same drain.
There should be a cleanout on the sink drain below where the drain enters the wall. That would be your "last resort" access to put a snake in to break up the obstruction.
I would try using a plumbers suction plunger on the shower drain.
Show no mercy!
Cheers.
Reply as a comment to this post.
I'm a retired plumbing inspector so should be able to coach you.
Oct 24, 2015 | Dishwashers
Gas Overflow
Sounds to me like a bend/kink in your filler neck, or someone stuffed a rag down there.
Remove the fuel filler cap and run a long, rigid wire down your filler neck - if you encounter significant resistance, remove the filler neck from the tank and investigate further.
Feb 10, 2014 | 2000 Cadillac DeVille DTS
Gas wont go into 2003 chevy 2500 HD truck how to fix
Something is blocking your Filler Neck (People who you got upset may have done this)...
Remove the VENT TUBE and FILLER NECK from the tank, remove the 3 Torx Screws and the Ground Strap, Wiggle the Filler Neck and once you have it out, you should see the Blockage or look into the TANK HOLE... There is something there
Apr 10, 2013 | 2003 Chevrolet Silverado 2500HD
Neck pain
Swap sides with passenger and driver My 98 did that
Nov 01, 2012 | 2011 Nissan Altima 2.5
Buzz at the e6 string 11th fret
Have you changed strings on it? Old strings get worn spots in them from rubbing on the frets that will cause these type of symptoms. If you put new strings on and get the same issue, check your neck relief (the amount of bow in the neck) to do this, hold your low E string at the first fret, and at the 12th or 14th fret. The neck should have a slight bow in the middle that puts it between 1/16" and 1/8" or so away from your string. If it does not have enough bow in it, you can adjust the truss rod. Most guitars use an allen wrench for this, it will be inside the soundhole on an acoustic usually, and on an electric it is normally on the headstock under a cover. There are many how-to's online about adjusting a truss rod, the key is to do it very slowly, only do about a 1/2 turn a day, retune, check it again the next day. Loosen the truss rod to put more neck relief, tighten to straighten the neck. If this still doesn't fix you up, let me know, and I'll tell you where to go from there.
Apr 24, 2010 | Washburn D10sbc Acoustic Guitar
Toshiba Satellite A135-S2276 Notebook Logo
15 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
