Question about Belkin (F5D8231-4) Wireless Router (F5D82314)
Belkin N1 MIMO Wireless Router dropping it's wireless signal.
Hey there,
My Belkin N1 wireless router has developed this habit of dropping it's wireless signal.
I recently moved my computer from one room, back to another and after plugging my Router back in, as the instructions asked, I noticed that night, the signal from the Router kept dropping for no reason. (The light on the front of the unit, also turns off -- go figure. : P )
My net connection is fine during each episode, and the Router isn't losing power. Every time I press the Reset button at the back of the wireless unit, my Wireless signal stays for a bit then it drops out again. It will continue doing this until it just decides to stop.
I called Belkin and the guy who 'helped' me, spoke so fast, I wasn't able to catch the 'update' I needed to download and seemed intent on kicking me off the line ASAP.
I took a punt and downloaded one of the updates for my router. Why they had more than one, is beyond me but anyway.
I tried to implement it through the software but it didn't recognise it and I couldn't use it.
Then I checked if my router even needed and update and the Belkin website said there were no new updates for my unit. So. I don't know who to believe at the moment.
Any ideas on why my router is dropping it's signal?
Thanks for your time,
- Vanessa.
  • Anonymous Mar 29, 2008
    Hi Observer Zen.
    I'm not sure what you mean by 'Configure 802.11 n'.
    Nor do I understand why one would need to change my WEP / WPA? I'm not very knowledgeable of Wireless routers and most of it's functions, so you'll have to go easy on me.
    However I do know for a fact that I don't have any other signals around my house, other than my Wireless router. I managed one time to pick someone else's Wireless router on my laptop but the signal was weak and kept dropping.
    As for routers and channels I don't know how that works. That's outside my knowledge and I'll need someone to walk me step by step. --- Unless you mean the channels on the back of the unit.
    I'm going to try changing channels at the back of the unit, next time it drops out and see if that works.
    Thanks for your time, hope to hear some more ideas.
    - Vanessa
  • Anonymous Apr 22, 2008
    hey, my wireless router has the same problem, its been around a day now that the wireless icon on the route isn't lit, and its done that in the past...im really pissed off cause now i can't use my ps3, and my internet just got really slow because of it...so what do i do now? I tried calling Belkin costomer service, but no help there...I just got this router and its already having problems..someone please help
Hi , you need more support, and I need for information:
1 - I need your topology, like the model all router, pcs and notebooks wireless, because this is important for my solved.
2 - The channel is frequency your wireless, it is many frequency and you can set up the best frequency when other channel is weak. This is a parameters for configuration in your router. Do you have the manual this router ? If yes, look this configuration router default, normally the default is not the best choose, but do you need know show this parameters in your router. check correct model router and write for me.
3 - Other part important this questions is the wireless interfaces in hers notebooks and pc. Both interfaces need same frequency 802.11n, if not same so they are 802.11g and throughput this are small.Or your interface same 802.11n forget this question.
I try help you solved this problem.
So sorry my english.
Good Day.
Posted on Mar 31, 2008
    Problem Solver:
  • 7 Answers
You can try configure only 802.11 n. Change wep or wpa, test again.
This issue no solved, turn off your wireless router, and search other signal around your room with his pc´s or notebooks wireless. If you see many networks wireless, check the channel less network and put your router this channel.
Test again and see solved this issue.
Good Luck!
Posted on Mar 28, 2008
SOURCE:
I have a Belkin N1 MIMO wireless modem router with a deactivated security. How do I re-activate the security?
you need to enter on the admistrator of your router to reconfigure it or to activate the security.just connect to router then go to iexplorer and type the ip of your router.the ip of your router is the default gateway of your computer ip.
Jul 13, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
My internet is greatly reduced with Belkin N1 vision wireless (before the hook-up it was 15mbps now only 5mbps), I have tested by hooking directly from the modem to the computer and got 15mbps. Before N1,...
When you only get 5 mbps are you connecting to the new router wirelessly or via the ethernet cable? If it is wirelessly then try connecting with an ethernet cable and see if you still get 5 mbps. If so then try resetting the router (the procedures for this will be explained in the manual) and re-test. Wireless connections can slow down due to obstacles such as thick walls or other obstacles of that type. If all else fails return the unit and try another.
Mar 08, 2011 | Belkin N1 Vision Wireless Router
How do I attach a better aerial to my wireless G plus MIMO router?
You cannot attach any extra aerial to the Belkin router, even if you attach it will not help you to increase the wireless signal strength. Its of no use in adding extra serial.
Thanks in Advance!
With regards,
Prema.
Jan 10, 2011 | Belkin Wireless-G Plus MIMO Router
I am trying to do a wireless connection to a windows98 computer to a belkin Wireless G Plus MIMO router. Is this possible?
YES, but you've got to make sure the router is setup for a mixed signal (B and G).
I don't believe when Win98 was around there was a "G" signal released yet ;)
Oct 29, 2010 | Belkin Wireless-G Plus MIMO Router
Signal problem
Step 1: Connect Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer (You can use any Web browser )
Step 3:On the left, under wireless click on channel and SSID (leave the password Blank and click submit )
Step 4: Change the Wireless Channel to 6 ( If its already 6 change it to 11)
Step 5: Click apply changes
Step 6: unplug the Router
Step 7: Restart the Computer
Step 8: Plug the power Cable back to the Belkin
Step 9: Connect to your wireless network
Jul 31, 2010 | Belkin N1 Vision Wireless Router
Will not transmit wireless signal
can try to reset your router.?let m know .If u not try to reset then press reset button for 15 seconds .
Reset button is in back side of router.
Apr 27, 2009 | Belkin (F5D7231-4) Wireless Router
Problems with Belkin Wireless G Plus MIMO Router
- Nope, it is not possible, you may need an Access Point to do it.
Mar 11, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Lost password into router need reset
Use the reset button near where the AC adapter plugs in. Hold it in for at least ten seconds. This should set it back to factory, allowing you to set another password.
Jan 25, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I just got a Belkin N1 wireless router and it will not work no matter what i do!
i took it back to where i bought it and got it exchanged as it was faulty!
Aug 30, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Help
Replace the router.
Aug 04, 2007 | Belkin (F5D7231UK4) Wireless Router
Belkin (F5D8231-4) Wireless Router (F5D82314) Logo
291 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Ekse
Pamela Bates
Pamela Bates
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
