Question about Porter Cable Cable 135 PSI, 15 Gal. Oil - Free Horizontal Compressor CPF4515
It runs non stop - Porter Cable Cable 135 PSI, 15 Gal. Oil - Free Horizontal Compressor CPF4515
    Brigadier General:
  • 4,090 Answers
If it is constantly running check that the drain plug in the cylinder is not loose and allow air to escape. It turns off when the pressure reaches the set level, but if there is a leak in hose or drain plug it will continue to run.
Please rate my help++++Thanks for using FIXYA
Posted on May 08, 2010
Machine runs non-stop
sounds like a blown capacitor in your foot pedal. What make and model machine have you?
Feb 15, 2014 | Sewing Machines
My shredder runs non stop, when I insert paper to shred , it stops... I push reverse, it works , pull paper out and runs non stop.......
Sounds like a bad or stuck sensor, acting as if it is always seeing a peice of paper in it. Check if you can find it and maybe it is just stuck to the on position..
Nov 07, 2013 | Omnitech 10-Sheet Micro-Cut Shredder
Radiator fun running non stop
sounds like the fan motor relay switch its attached to the fan housing unit, or your thermostat is stuck open. refer to you car bible for instructions on how to test your termostat to see if it functioning properly. Hope this was helpful.
Mar 20, 2013 | 1998 Toyota Corolla
You think it can handle 5 days non stop running?
Most computers can run non-stop unless it runs into a problem and it depends upon what processors it is running.
Oct 16, 2010 | Dell Inspiron 1501 Notebook
GE TFX20R runs non-stop.
Have you sat and watched it constantly? Or just notice it running every time you take notice? I ask because a lot of people say it runs all the time when it doesn't really. Is it staying cold? or getting too cold? Or is the temp normal?
Jan 02, 2010 | GE Refrigerators
WATER RUNS NON STOP EVEN WHEN MACHINE IS OFF
Yes. on Maytag usually runs fro left rear of tub to the control panel. You will have to pop the lid up to get to it. It may have pulled off the lower nipple or rubbed a hole in it somewhere.
May 24, 2009 | Maytag Washing Machines
Laptop fan running non stop
you need to go into the bios and disable the always on setting for the fan
Dec 16, 2008 | Computers & Internet
Kenmore 106.53542300 is running non-stop
I supect a stuck thermostat. its the only thing to make it run non-stop also check the door seals wipe them down if they look dirty
Oct 02, 2008 | Kenmore 73503 Stainless Steel Bottom...
Drive runs almost continually - very hot as a result
You can download the data lifeguard diagnostic utility off WD's website.
Sep 07, 2008 | Western Digital Elements powered by WD 320...
Porter Cable Cable 135 PSI, 15 Gal. Oil - Free Horizontal Compressor CPF4515 Logo
76 people viewed this question
Top Porter Cable Air Tools & Compressors Experts
John Trevino
elunsford
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
