Question about GE Caf? 25.4 Cu. Ft. Side-by-Side Refrigerator w/Thru-the-Door Ice and Water - Stainless-Steel
Compressor doesnt kick on .temp will not reset on control pad
Any solutions
  • 555 Answers
Do you hear a "Click" trying to start the compressor?
If so, Sounds like the compressor relay is broken. It is a small back box (about 1 sqr inch size), that may need to be replaced.
You may need to provide more info about the failure.
Posted on May 08, 2010
Have power but compressor no work
Tried unplug,replug it back in half or an hour later.Most of the time the the compressor will reset and kick in than it work again.This is a temp solution only,because most of the compressors in frig have this intermittent problems will died again because of over heat the design 24/7 plugin doesn't help especially continue of power to it.Replaced the frig if it more than ten years or replaced the compressor if less.
Sep 04, 2013 | KitchenAid KSCS25IN Side by Side...
Ess25lgmb freezer fan doesnt shut off
Most fans only run when the compressor runs, it must be wired wrong, OR if the unit has a computer control (LED digital display) it may be the main board has shorted, you can try unplugging it and let it sit for 10 minutes, then replug it. ALSO sometimes there are sensors that sense the temurature and will kick on a fan if they are out of parameter, changing sensors if they are malfuntioning can fix this as well...
Feb 08, 2013 | Kenmore Refrigerators
Rooftop RV Air Conditioner: temp outside 90 or above. compressor kicks off ....
It sounds like maybe an overload for the compressor is tripping and resetting once the compressor cools. Possibly due to a low charge.
May 03, 2010 | Heating & Cooling
I changed the air compressor and the dashboard control panel last year and it has done ok. Now the temp. fan and the compressor fan won't kick in and the air compressor won't kick in also. Checked all...
You say temp fan?If you mean the cooling fans,then the ac is out of freon most likely,the freon has to be in the system,and enough to kick the compressor on,therefore turning the cooling fan on.
Apr 06, 2010 | 1996 Chevrolet Monte Carlo
The ac compressor runs and cools properly when temp is cool,but on warmer days it will run then kick out and will not kick back in for several hours later.All pressures are good...the freon charge is...
What year is the vehicle ? The A/C button on the control panel is a direct input to the PCM /ECM - engine computer . The PCM/ECM energizes the compressor clutch relay to engage the compressor .
Apr 13, 2017 | Oldsmobile Cutlass Supreme Cars & Trucks
Deforst mechanism
you need to have a defrost or the freezer will not work unplugging the time clock then the compressor will not work. Tom
Jun 18, 2009 | Freezers
No power..doesn't turn on
you may have a faulty temp control or there is a wire off around the compressor area cheak the relay on the compressor if it is burned or a wire is shorted out.Hope this helps o and try to give the temp control a tap with somthing some time it will kick on that for sure would be a bad temp control Hope i helped:)
May 20, 2009 | Heating & Cooling
Refrigerator freezes everything even on the lowest setting
Is everything really frozen or just the top shelf stuff? You may have a thermistor (temp sensor) problem if the compressor just runs and runs and runs all the time. Take a glass of water and place a thermometer in it for about 3 hours then take a temp. reading. That will let you know what the real temps are. See if you can cause the compressor to kick off and on by changing the temp settings (go to real low for about 5 minutes then back up to high). Let us know what happens.
Dec 24, 2006 | Sanyo SR-3620 Compact Refrigerator
GE Caf? 25.4 Cu. Ft. Side-by-Side Refrigerator w/Thru-the-Door Ice and Water - Stainless-Steel Logo
89 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
