Question about Frigidaire FSC23F7D Side by Side Refrigerator
Frigidaire side by side circuit board issues i think
Frigidaire side by side fridge. We had a circuit board replaced because if you tap the plastic part around it, it would kick the fridge on and cool like it should. What could it be? Wiring harness going to circuit board maybe or circuit board bad again. This was replaced and the next day same problem. The fridge is only 5 years old. It makes a electrical zapping sound as it kicks on after tapping on plastic.
22yooper
  • 828 Answers
SOURCE: Frigidaire Gallery Side by Side - Fridge not cooling
Locate the defrost timer and rotate the dial a small amount clockwise. If the compressor starts the timer should be replaced. If the compressor does not start check the temperature control. It may be bad, if it is bad try jumpering the thermostat wires. If it starts and runs the thermostat is bad. Replace the thermostat.
Posted on May 26, 2008
SOURCE: comperssor kicks on but quickly cuts off
Freezer defrosted everything fan continues to run but will not freeze. Compressor is cycling enough to keep refigerator section cold. 106 Series Kenmore. Turned up thermostat to keep fridge cold and a shorter intermittent compressor cycle run
Posted on Jun 06, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Frigidaire FRS26R4AW5 buzzing sound not cooling
Something has stopped your compressor. The part could be the start relay, start capacitor, overload or the defrost control board. where are the buzzing sounds coming from ? Sea Breeze
Posted on Dec 20, 2009
  • 35 Answers
SOURCE: Frigidaire FRT17G4BW9 16.5 cubic foot. The
direct short compressor. replace
Posted on Jan 02, 2010
SOURCE: New defrost timer on fridge keeps tripping circuit breaker
The problem is the defrost timer you just replace on your refrigerator, you will need to check the ratings on the broken defrost timer to ensure it matches the ratings on the present defrost heater on your refrigerator, beside, you will need to test the continuity on your present defrost heater to see if the voltage rating is ok, because, if it can be tripping the breaker off while it kicks into defrost mode signify that the present defrost heater is not compatible with your refrigerator, it is either it is not well wired or fixed, and if it is, then, it means the defrost timer voltage rating is low compare to the former, you will need to get exact specification as the the broken one.
Take care.
Posted on Jul 10, 2010
How to fix error code H1
Frigidaire Refrigerator Error Code = SY CE
Condition = Communications error at power up
Repair or Check = Check wiring between control board and user interface
Parts Needed = Control board or User interface
Frigidaire Refrigerator Error Code = 4
Condition = Fridge and the control board goes through cycles but does not detect a damper connection
Repair or Check = Check air damper
Parts Needed = Air damper
Frigidaire Refrigerator Error Code = 5Y EF
Condition = Evaporator fan circuit failure
Repair or Check = Check wiring between evaporator fan and control board
Parts Needed = Evaporator fan or control board
Frigidaire Refrigerator Error Code = EF
Frigidaire Refrigerator Error Code = dF
Condition = No defrost circuit
Repair or Check = Check wiring between defrost circuit and control board
Parts Needed = Main control board or Wiring harness
Frigidaire Refrigerator Error Code = H1
Condition = Freezer sensor shorted in freezer display
Repair or Check = Check wiring between thermistor and board. If correct, replace thermistor
Parts Needed = Thermistor (temp sensor)
Frigidaire Refrigerator Error Code = 5y CF
Condition = Communications failure at power up
Parts Needed = Control board or user interface
Sep 28, 2016 | Refrigerators
My frigidaire refrigerator side by side if flash a number 4 on the fridge side as it is not cooling
Good Morning John, thank you for your post!
Generally, error code 4 means that the refrigerator is experiencing an issue with the damper. The damper is either not opening or closing properly causing the fridge compartment to not cool. One of the best ways to determine if this is a false error code is to reset the power to your refrigerator by either unplugging it or flipping off the breaker for about 30 seconds. If the error code persists, the wiring between the damper and Main Control Board will need to be diagnosed by a professional. Depending on the results, either the damper or Main Control Board will need replacing.
Best regards!
Jan 28, 2014 | Frigidaire Refrigerators
Frigidaire fridge code 4
Hello j280connolly - Typically error code 4 means that there is a communication failure with the main control board and damper. Base on the intensity of the issue; a certified technician would have to check the wiring between the two. If problem still exist, might have to replace the main control board.
Oct 12, 2012 | Frigidaire FRS3R5EMB Side by Side...
I have a samsung side by side srs537nw. both side are not working properly. the fridge wont cool and the freezer turn into a fridge.
Had exactly the same problem. Found the cooling coils are not defrosting, everything was iced up inside the back panels. The drain was blocked, water pooling underneath also.
Remove all the plastic panels in the back of the freezer, including the temp. sensor (unplug) and fan (unplug). Defrost everything with a hair drier.
Make sure that the drain at the bottom is free, a small plastic tube which takes water down into a pan where it is evaporated by the compressor etc.
Replace the defrost sensor - the most likely faulty part. This costs about $Au 20.00 from Samsung (just ask for a defrost sensor for the model of fridge). This sensor fits in a plastic cage attached to the top of the cooling coils, has wires which plug into a socket. Reassemble the fridge and see if this has solved the problem.
If the fridge still does not defrost automatically, you may need to replace the circuit board ($Au 80.00 from Samsung). This board is found from the back of the fridge, in a plastic box behind a back panel at the bottom of the back of the fridge. Lots of wires to unplug!
There may be other problems, like a faulty thermostat on the valve which controls circulation of cold air into the fridge from the freezer, I have no experience of solving this.
Samsung mechanics are HOPELESS in my experience, replacing the two parts above will be less expensive than a call to them. Good luck!
Feb 10, 2011 | Samsung RS2534 Side by Side Refrigerator
Loud ticking noise when i close freezer and lights on icemaker flash like a stobe light. fridge and freezer wont hold temp. ice amker and water dispenser dont work?
if your lights burned out recently and the digital temp read-out is now dark also,burned out lights will cause a power surge and will destroy the main-board circuit trace(mother-board), it is located in the back side of the refrigerator, in a small plastic case,when you remove it you will see a burned spot on the circuit board and the loud clicking sound is a relay on the board trying to latch to light the bulbs and operate the unit
Feb 21, 2010 | Frigidaire FRS3R5EMB Side by Side...
Flashing #4 on temperature display
flashing #4 is a communication error between the control board and the damper assy, usually it is the fault ogf the damper assy but if it is under mfg warranty, replace both, if you need to pay for the parts yourself get the damper first.
Oct 24, 2009 | Frigidaire GLHS36EESB Side by Side...
Freezer is cold but the frig side is not???
Hi Gotzd,  If you open the fresh food side (not the freezer), and look to the upper left side you will see a plastic shroud or cover. Behind that cover is a printed circuit board (p.c. board)   and a damper motor. That motor brings cold air from the freezer to the fresh food side. The whole damper assembly may need to be replaced. That also includes the cold controls for both sides of the "fridge".  Home Depot Parts and Accessories has the part available. 800.378.5830. Call, give them your model number, and the description, they will locate the part number for you. This MAY be the solution for you, it was for me. Hope this helps, better yet, Hope you've fixed already.
Steve D.,  Owner Handy Home Repair
Jan 17, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire refrigerator does not seem to be cooling or freezing
MY HOTPOINT HAS A SIMULAR PROBLEM......IT SOUNDS LIKE YOUR CIRCUIT BOARD IS BROKEN...THERE ARE NOT THAT MANT PARTS TO A FRIDGE/FREEZER SO THE LIKELY HOOD IS CIRCUIT BOARD OR MOTOR.....HOPE THIS HELPS
Dec 20, 2008 | Frigidaire FRS3R5EMB Side by Side...
Interior walls cracking...
i don;t think there would be a health issue involve.
the old fiber glass has been replaced with polyurethane foam now a days to replace the more dangerous fiber glass insulation.
if you can replace the plastic part that cracked open, that would much better.
tnx 4 using fixya,
drcool
Sep 28, 2008 | Frigidaire FRS3R5EMB Side by Side...
Whirlpool gold refridgerator light not working and is making funny noise
Had the identical symptoms with my Whirlpool Gold GS6SHEXNB00 side-by-side refrigerator. Had a technician come on site, indicated it was the "circuit board/ timer" (Whirlpool part # 1394052). Board is accessible from behind fridge (lower left side in a white plastic housing to left of compressor).
Swapped the board out (noticed a scorched circuit on the old circuit board). Lightbulbs now work, temperature readouts also good to go.
Mar 03, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Frigidaire FSC23F7D Side by Side Refrigerator Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
