Question about Sony Cyber-shot DSC-W35 Digital Camera
When i turn the camera on the lens wouldnt go in and out, now it does and i thought it would work again but it still comes up with access turn power off and on
SOURCE: Cyber Shot DSC W35-W55
I just had the same problem. I checked my lems as it went in and out and lo and behold there was a baby fingerprint. Cleaned using a q tip and it stopped immeadiatley and works fine now! Thank goodness!
Posted on May 17, 2008
SOURCE: Sony Camera DSC-W30
same hear but the problem started after about one year of use was intermitant but now more often than not
Posted on Jun 23, 2008
pauman
  • 248 Answers
SOURCE: sony dscw130 lens wont come out
This seems to happen when something (water, sand, dust) gets trapped in the lens mechanism. Has the camera been somewhere filthy before?
The recommended methods include taping on the bottom of the camera, rapping it on a table, and pressing hard on the lens. If the lens moves when you turn the camera on, try keeping your hand on it so that it's forced back into the camera body. A can of compressed air squirted around the lens is also a possible fix... but be super careful with that stuff, a good hard blow of breath might be safer.
I'm not recommending that you do crazy stuff to your camera, but if you're careful you may be able to get it working again without having to get it serviced.
Posted on Jul 06, 2009
  • 3 Answers
SOURCE: Cyber Shot DSC-W55 " Will not Access "
smack it on something, i dropped mine after 30 minutes of frustration and it started working. the next time that it happened i hit it on my table on purpose and it worked. i dont know why but this worked.
Posted on Aug 29, 2009
BillB-SA
  • 2761 Answers
SOURCE: When turned on, Access comes up, and lens goes in
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
If this response helps, please take a moment to post a rating for me. "Very Helpful" would be appreciated.
Posted on Nov 28, 2009
PowerShot G5 Digital Camera: Cannon power shot will not turn on and lens were n...
there is a switch inside the battery cap, when it open, the switch is turning off, then switched on when it closed. the camera wouldnt turnd on, when the swich not working normally
May 18, 2010 | Canon PowerShot G5 Digital Camera
Turn the power off and on again message
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settigs 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa
Feb 15, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
I Turned on my samsung l730 camera and the lens got stuck and the screen just went black and the lens wont retreat and the only way i can turn the camera off is to take the battery out
what i did was i took off the front cover of it, turned it on while twisting the lens, and it came free. i used a screwdriver from a tech deck :)
Nov 22, 2009 | Samsung Digimax L730 Digital Camera
Today, I was using it. Turned it off for a whle, went to ues it again & it wouldnt turn on, the power light was on & three beeps came out of my camera! It wont turn off until I take the battery...
Most probably the lens problem, it got stuck or it's damaged. Try to gently pull out the lens to see is it only got stuck or take it to service
Jun 23, 2009 | Samsung L100 Digital Camera
SONY CYBER SHOT NOT WORKING
Hello samtx930, "turn off the power and on again" its a very commen problem and occurs when the lens block assembly start malfunctioning. Actually the slide motor not work properly and until the lens not come out completely the camera will not work, that's why the error message appears "Access" and then screen shows "turn off the power and on again". In this situation you have to replace lens block assembly.And the part No. is with description is given below: 1-788-363-11 OPTICS UNIT (ED13A) Thanks for using fixya.
Jun 14, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
When the camera turns on the screen stays black and the lens will not come out.
Hello, "turn off the power and on again" its a very comman problem and occurs when the lens block assembly start malfunctioning. Actually the slide motor not work properly and until the lens not come out completely the camera will not work, that's why the error message appears "Access" and then screen shows "turn off the power and on again". In this situation you have to replace lens block assembly.And the part No. is with description is given below: A-1512-913-A LSV-1250A Thanks for using fixya.
Jun 14, 2009 | Sony Cyber-shot DSC-W120 Digital Camera
Camera shutter not working
Lens is sticking / stuck.
try gentle pressure to help pull out - if that does not work then try pushing lens in and powering on /off a few times.
keep trying!
I had the same problem - eventually got round it.
Dec 19, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Problem with lens
throw it on the floor again
IT WORKS!!!!! YYYYEEEEEEEEEEAAAAAAAAAAA
Jul 10, 2008 | Sony Cyber-shot DSC-W30 Digital Camera
Sir,
The lens keeps coming in and out and it says access then it stops and says turn power on and off again. I can access my pictures but thats about it. Please help.
regards
prakash
Mar 05, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
My Sony DSC-W100 says "Turn the power off and on again" but still wont take any pictures! The screen just stays black. Anyone know what is wrong with it and how much it will be to get it fixed?
OMG - I had the same error, when I turned the camera on it said "Access" and then "Turn the power off and on again".
I have turned it on and off over and over again! THANKFULLY I took "Guest's" advice from September 12, 2007. After hitting it a few times on the carpet, I still received the error, BUT while the lens was retracting in and out I hit the top of the camera beside the power button with my knuckle and it WORKED!!! I can take a picture again. Thanks so much for the advice. Hope this helps others.
Aug 26, 2007 | Sony Cyber-shot DSC-W100 Digital Camera
Sony Cyber-shot  DSC-W35 Digital Camera Logo
22 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
