Question about Hoover F7220900 SteamVac V2 Upright Vacuum
Hoover Steam Vac Dual Rinse Model F7205-910
The clean water leaks profusely once placed on the machine. What part do I need to replace to fix this problem?
Thanks!
  • 2 more comments
  • amifeller Jul 12, 2008
    I'm having the same problem, Beachnfool, did you ever get it fixed?
  • Anonymous Jul 26, 2008
    I am having the same problem
  • bhfreeman817 Aug 15, 2008
    I have the same problem too....I really haven't used the steam cleaner a lot over the years....it is very irritating. I looked on the hoover website to see if I can replace the clean water tank and it is sold out, so Im guessing this is common problem.
  • Anonymous Dec 31, 2008
    I have had this problem twice with my Hoover Steam Vac and would not buy another one of this model because of it. My prior Hoover Steam vacs have been great but I am terribly disappointed with Hoover because of my difficulties (which I understand from the repair people are common) with this particular model.
    Hoover does not sell the part to fix it - Instead you must buy a whole new canister for around $50.00. Bummer - I spent the first $50 to fix it a couple of years ago and now it is broken again -!
Machine's on board Fluid containers have rubber stoppers with valves that open when it the container is put in place on the machine. The container may be broken around the rubber stopper. The container may need to be replaced.
Posted on May 16, 2008
  • 25 Answers
MOST COMMON PROBLEM IS THE ATTACHEMENT VALVE IS BROKEN WHERE YOU CONNECT FOR WATER ON SIDE OF MACHINE. THESE MODELS USE AN ELECRONIC SOLONOID TO ACTIVATE WATER TO NOZZLE IF IT IS COMING OUT THERE SOLONOID MAY BE BAD
Posted on Mar 27, 2008
SOURCE:
Hoover steam vac F6210 solution tank spring repair
Hi there. The spring on the clean water tank cannot be replaced. A replacement tank would be needed. Follow the link to order a replacement clean water tank for your cleaner. Search Results
The clean water tank does not include the handle but your original handle will fit the replacement tank as well. Hope this was helpful!
Jun 19, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
Repair hoover steam vac F7210
Fixya does not make servicing recommendations.
Jul 23, 2017 | Vacuums
I have a Hoover Steam Vac Dual Model # F7426-900. The nozzle and spring from the bottom of the soap dispenser popped out. Can this be fixed?
You will need a new valve assembly. ( part # 43513014, msrp $3.62 ) Place the rubber seal in first, then wet the valve and push it in with your thumb.
Jun 24, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
My Hoover steam vac dual v clean water and detergent tank leaks water before attached to the vac and during cleaning
This is a common problem with the earlier models which had a separate soap tank glued to the clean water tank. The plastic was too thin beneath the valve on the clean water side and would develop cracks. You most likely will need a new one piece tank. ( Part # 42272104)
May 21, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover steam vac dual v carpet cleaner has stopped dispensing soap. Water is still flowing fine
You probably have a solenoid valve which has failed and will not open. This will require replacement of the valve. For temporary use you can mix a soap solution and put it in the rinse tank. The correct mix is 5 ounces of Hoover shampoo to a gallon of hot water.
May 17, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
Using my hoover steam vac tonight and too much water coming out. once it's turned on, water and shampoo continuously come out underneath until tanks are empty. looks to be leaking from left side bottom as...
make sure that you have filled everthing properly and the hoover steam is in a good condition. or check else is there any loose coonections in the bottom of the hoover, which makes the tank empty.
if the problem persists take it to service.
Feb 25, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover Steam Vac V2 Deep Cleaner leaking clean water
Fill the tank and determine if the plastic is leaking, or if the valves are leaking. if the tank is cracked, it would need replaced. There is an improved design now available.
You may cycle the valves on the bottom with the eraser end of a pencil.
Sep 24, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Clean water tank leaks
Your going to have to replace it again, good thing is they completely remodeled the new one.
Aug 26, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
Automatic "shut off" not turning off
Check the filter in the tank, if a dual V model you will have a screen, if not a dual V move the foam filter down about 1/4" to help.The lid on either model needs to be securely in place, as well as locking the left and right latches. On the Dual V model, check the hose door on the front.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Feb 23, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover F7220900 SteamVac V2 Upright Vacuum Logo
711 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Kirk Thompson
Level 1 Expert
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
