There is no sound thru av
Im trying to connect my tv but there is no sound went i put it av
  • David Dunn
    David Dunn May 11, 2010
    Detials of the equipment, please.
  • 311 Answers
Is the home theater system attached to the TV through the audio out points or is it attached to the sky +/tivo/satalight box
i belive you have attached it to the satalight box
on the back of your tv look for a audio out jack and attach the home theater to that
Posted on May 08, 2010
Im trying to hook up my xbox 360 to my digital lifestyles flat screen and cannot figure it out :((
A USE HDMI CABLE FROM XBOX TO TV AND SELECT HDMI AS THE IN PUT ON THE TV OR USE A HDMI TO AV CONVERTER AND PLUG AV PLUGS IN TV AND SELECT AV IN PUT ON TV
Jun 08, 2014 | Video Game Consoles & Games
Does the JVC AV-56P776 have any kind of lock out on it went thru setup it plays dvd's but not regular tv
if plays DVDs via rear connections what have you got hooked to it for regular tv reception? Hooked to the coax fitting, using antenna or cable or sat with a box or not?
Good news is if it works with DVD set is likely ok and you have some other issue----just need some more information to decide what that issue is.
May 02, 2012 | JVC Televison & Video
I pressed the hd option in the set up menu and the screen went blank and a message no signal came up. any suggestions
First please excuse my english...I had the same problem and manage to fix it. Just remember that nothing is broken, the problem is you dont see what you are doing. First unplug your nbox and remove sd card or usb disk. then folow thease step. 1-plug the unit and press power. It is not possible to know if the unite is on... 2-press enter 3-press the down arrow 7 times 4-press enter 5- press left arrow 6- press enter. if it dont work try again and again. You have to undo what you did and put the unite back on the good setings. good luck
Jan 02, 2011 | AGPtek NBOX RM RMVB MP4 VOB MPG 3GP AVI...
I hooked hdmi to tv. i went thru ps3 settings for video n audio n swithch audio to the red n white output. now i have sound thru surround sound but my video is flickering n i cant c so i can undo it
Make sure the Component AV Cable is connected to the AV Multi Out port on the back of the PLAYSTATION 3 system. Connect the other end of the Component AV Cable into the video and audio RCA jacks of the TV or display monitor.
2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the ON/OFF button long enough to reset the Video Output Settings.
3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically be reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Jul 01, 2010 | Sony Playstation 3 (PS3) Console
PS3 hdmi connection works but not std rca AV
You must set it OFF HDMI while connected to the TV...
Feb 28, 2010 | Sony Playstation 3 (PS3) Console
Recorded play back is fuzzy
MOST LIKELY the RF out put signal is the same as a local tv chanel 1) try menue change rf output suggest rf 68! OR connect av leads (red white yellow)from the output of your vcr and connect the other end to an Av input eg AV1 on your TV use tv remote to select the AV input
Apr 21, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
Tv built-in dvd player wont play thru surround sound
goto your menue setings and slect sround sound and set up to external sound system.
Jan 10, 2009 | Toshiba LCDTV/DVD Player 19HLV87
use your t/v audio out with RCA cables to your reciever input like(vcr in, dvd in, dtv in)
Dec 20, 2008 | Yamaha HTR-5930 Receiver
No main menu or video shows on tv
u need to set the display output back to standard av cables. search online and there should be steps on how to do this.
Aug 03, 2008 | Sony Playstation 3 (PS3) Console
We have just brought a PDP-42XR8DA plasma tv, once set up and all tv stations working we went about trying to set our sanyo dvd player to the tv. Once all the inputs were in the right terminals and all...
Bad cable probably. As you are going through direct connection ie AV I would be looking at either the cable or more probably are you connect to the correct AV video out put from the DVD?
Jul 26, 2008 | Televison & Video
79 people viewed this question
 Grubhead
Grubhead
