Question about OKI B4250 Led Printer
Paper jam The printer jams after one page is printed.
  • Silkie Mar 31, 2008
    There isn't anything I can open in the back of the printer except where the computer chip is located and nothing is in there.
    Genius:
  • 1,913 Answers
Hi
open your back side of printer and check fuser aseembly that no any paper jam
Posted on Mar 27, 2008
SOURCE:
LOCATION OF PRINTER SENSOR
Jams
Clearing jams
CAUTION Do not use sharp objects, such as tweezers or needle nose pliers, to remove jams.
Damage caused by sharp objects will not be covered by the warranty.
CAUTION Always pull jammed media in the direction it would travel through the paper path.
Do not pull jammed media against the direction of travel through the paper path to avoid damage
to the printer.
To prevent damage to the printer when clearing jams, including jams in the output bin, always open the
print-cartridge door and remove the print cartridge. Keep the door open and the cartridge out until the
jam has been cleared. Opening the print-cartridge door and removing the print cartridge relieves tension
on the printer rollers, which prevents damage to the printer and makes the removal of jammed pages
easier.
Occasionally, media becomes jammed during a print job. You are notified of a media jam by an error
from the software and the printer control panel lights. See Control-panel lights (HP LaserJet 1010 series
printers) on page 102 or Control-panel lights (HP LaserJet 1020 printer) on page 106.
The following are some of the causes of media jams:
The input trays are loaded improperly or are too full. See Loading media on page 25.
NOTE When you add new media, always remove all of the media from the input tray and
straighten the stack of new media. This helps prevent multiple sheets of media from feeding
through the printer at one time, reducing media jams.
The media does not meet HP specifications. See Media specifications on page 21.
Typical media jam locations
Print cartridge area: See Removing a jammed page on page 43.
Input tray area: If the page is still sticking out of the input tray, gently try to remove it from the input
tray without tearing the page. If you feel resistance, see Removing a jammed page on page 43.
Output path: If the page is sticking out of the output bin, see Removing a jammed page
NOTE There might be loose toner in the printer after a media jam. This toner clears up after
a few sheets are printed.
Use the procedures in this section to remove a jam.
CAUTION Media jams might result in loose toner on the page. If you get any toner on your
clothes, wash them in cold water. Hot water will permanently set the toner into the fabric.
Partshere Troubleshooting
CAUTION To prevent damage to the printer when clearing jams, including jams in the output
bin, always open the print cartridge door and remove the print cartridge.
To prevent damage to the print cartridge, minimize its exposure to direct light. Cover the print
cartridge with a sheet of paper.
NOTE The following illustrations show the HP LaserJet 1020 printer. The same procedure is
used to remove a jam in the HP LaserJet 1010 series printers.
Open the print cartridge door, and remove the print cartridge.
Grasp the middle edge of the side of the media that is most visible, and carefully pull it free from
the printer.
jams. Damage caused by sharp objects will not be covered by the warranty.
Do not forcefully pull jammed media against the direction of travel through the paper path to
avoid damage to the printer.
When you have removed the jammed media, replace the print cartridge, and close the print cartridge
door.
After clearing a media jam, you might need to turn the printer off then on again.
NOTE When you add new media, remove all of the media from the input tray and straighten
Sep 25, 2011 | HP LaserJet 1020 Printer
Printer error shows paper jam at paper tray and printer stops after printing 3 or 4 pages. I open and close the top access and printing resumes for 3 or 4 more pages...stops and shows paper jam at feed...
Try two things:
Fan the paper before placing in the tray.
Raise the humidity in the room to at least 40% to avoid electrostatic sticking of the paper. Store paper in 40% humidity area.
Dec 16, 2009 | Konica Minolta magicolor 2400 Laser...
Message shows "Paper jam" but there is no paper jam
try turning off the printer for about 10 sec. to clear its memory and turn it back on.. then print again
Oct 19, 2009 | HP Photosmart C4250 Multifunction Photo...
HP laserjet 4L paper jam after printing one page.
You need the pick up rollers replaced. Call your service centre to replace pick rollers as these are feeding the pages crocked
Aug 31, 2009 | HP LaserJet 4L Printer
Error light keeps on flashing blue light at the
These are your possibilities based on your error.
Front cover is open
Close the front cover of the printer.
Fuser cover is open
Close the fuser cover located behind the back cover of the printer.
Paper jam
Clear the paper jam. See Paper jams and how to clear them on page 85. If the printer
does not start printing, press the Go button.
Memory full
The printer memory is full and the printer cannot print full pages of a document. See
Solving print problems on page 97.
Print overrun
A print overrun occurred and the printer cannot print full pages of a document. See
Jun 14, 2009 | Brother HL-2170W Laser Printer
Paper Jam
1. First, clean your printer. Get some spray-n-wipe cleaner and a clean cloth and clean the entire inside of the printer. Also ensure your paper isn't dirty. Now print a test page. Does the symptom persist?
2. Remove all jammed paper. Check the paper tray first. Look closely at the paper rollers nearest where the paper exits the printer; this is a common source of jams. If you’re trying to print labels, they will often jam just before exiting the printer.
3. Try to print a test page. Does the printer still jam? If you can find no source of the jamming, check the printer's message display window and refer to your user’s manual to look up the printer error code.
Sep 16, 2008 | HP LaserJet 4mv Printer
Copier canon mf4150 says it has a paper jam, but there is no paper jam.
Sep 16, 2008 | Office Equipment & Supplies
OKI B4250 Led Printer Logo
199 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Clive
Clive
Thomas F. Schneider
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
