Question about John Deere Garden
The lawnmower blades will not engage when the yellow pull switch on the dash is pulled.
  • 713 Answers
Hi,i think there is a loose connection with the blade wires that connect to the clutch,that's why the blade doesn't engage,if you are technically inclined,you can run a check on the wiring to connect back the connector wire to the clutch.
Thanks and take care
Posted on May 08, 2010
Cub cadet lt1045 pto dose not come when engaging switch,just stopped.
no pulled out wires check fuse behind dash but jump the ptio with the battery see if it will come on if not pulled wireing in pto
Sep 12, 2014 | Garden
Why my blade wont engage on my toro 74370 zeroturn mower
it has an electromagnetic clutch switch on it,that is more than likely bad. Try this,pull the pto switch out and start the engine,then disconnect the 2 wires coming from the switch and just tap them together and see if they will come on. If they do then you need to replace that switch.
Jul 27, 2014 | Toro Lawnmower 20099 Mower Mowers Lawn
Cant get the switch to acctavate the mower deck on a cub cadet lawnmower
Check the fuse, tan/blue wire coming off ig switch or tan coming off PTO sw.
If it keeps blowing, check wire going to PTO unit for shorts or defective connection to PTO.
Apr 16, 2014 | Cub Cadet Garden
I have a castelgarden ride on lawnmower when i engage the cutting blades the engine cuts out why is this?
sounds like you need to test the safety switches with a ohm meter start with the one on the seat then check the one on the clutch/brake pedal the look at the one in the reverse position
Jun 12, 2012 | Garden
I have an 18"hp MDT
Hi, there are two safety switches on your mower, one on the seat and one on the reverse position of the gear lever. One of these will be shorted and faulty. Locate these switches and bypass them one at a time by removing the wires from the spade connectors until your mower runs with the blades engaged. Then replace the faulty switch. Hope this helps, regards Phil.
May 22, 2011 | Garden
My lawnmower blade will not engage when i pull the lever, and the belt is not off.
Willy, you're going to have to narrow this down a bit before we can formulate an answer for you....how about Make, Model no., and type of "Lawnmower"... ;-D
Aug 11, 2010 | Garden
I have a craftsman riding lawnmower and the blade engagement is not starting the blades when i lift it. It feels loose when i lift it.
Sounds like you PTO cable is broken. Part # 175067. It goes from the lever on the dash down to a deck mount and hooks to the idler pulley. When you lift the lever, it should pull the pulley and idler arm towards the rear of the deck to tighten the belt to engage the blades.
Jul 29, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Blades will not engage when you pull up on the button
When you pull switch to turn on blades do you here a click sound ? If so clutch is most likely ok,did you check your belt to make sure its ok ?Seat switch is just a saftey feature it cuts all power to the clutch so thats why blades turn off,thats why I asked you if you here a click when pulling switch that will tell you if there is power to switch.there is also most likely a fuse in the line that goes from the clutch switch to clutch.
May 09, 2009 | Garden
Garden Logo
142 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
