Question about Canon MX300 Office All-In-One Printer
Printing streaks on all faxes I recieve
When I recieve a fax on my Canon MX300 Multifunction Printer it prints streaks down the paper. However if i printer frrom my PC to the printer it prints out perfectly. i have doen ALL the maintenance cleaning and i use genuine Canon Ink. Any help would be appreciated. thanks
    Brigadier General:
  • 4,090 Answers
Clean the rollers in the paper path
Please rate my help++++Thanks for using FIXYA
Posted on May 08, 2010
Testimonial: "Thanks for your help and it was very quick too"
Streak along edge of paper, Canon MF8380Cdw
Print quality issues on these models is usually if not always down to the cartridges used. I bet you are using compatible cartridges. If so just buy a set of genuine ones and I bet the quality will be perfect again.
Jun 01, 2016 | Canon imageClass MF8380Cdw Wireless Color...
How do I cancel received fax jobs on an MFP when at the device it will not let me ?
Power off machine.
Hold down 2&6, this will put you in config mode.
Scroll down to Format Fax Storage. Select this and answer Yes.
This will clear the stored faxes.
Update the firmware on the printer. Most of our firmware updates contains fax fixes.
Feb 17, 2015 | Lexmark X792DE Laser Multifunction Printer...
How do i retreive and receive faxes? My machine has recieved material in memory, yet when i try to print them, the alarm rings after first page and display reads "CHECK PAGE SIZE, press OK" It will re
If you are able to print normally from this model, despite the 'stuck' faxes, then it could be that you have been sent a document that is not the same size as that in your tray. Try cutting A4, if that is what you have, down to 'legal' and see if will move on to next page. If this works, cut some more and print job till finished.
If the above makes no difference, you may have to do a memory reset to clear a corrupt fax record. Caution! this would clear all faxes queued in your machine.
Dec 16, 2014 | Canon PIXMA MX340 Inkjet Multifunction...
How to remove streaks on the canon d1300
Hello, That is either your toner or your fuzing unit. Or you need a maint. kit.
Oct 02, 2014 | Canon imageCLASS D1300 D1370 Laser...
Canon PIXMA MX330 multifunction printer. I get a lot of faxes. Is there a way to save ink & paper by having all faxes come in without printing them & just putting them to memory & review them...
unfortunatly not!The m/c will print each and every fax!I can suggest getting a fax to email nr and recieve the faxes on your pc and then printing what u need!Memory does keep about 258 pages depending on the coverage on the pages!
Feb 22, 2010 | Canon PIXMA MX330 Multifunction InkJet...
On my Canon MX310, the display says "Waiting for Report". Fax Memory is clear, but the In Use/Memory light stays on.
Try this step ... found it on Canon's website
Issue: ERROR LCD: WAITING FOR REPORT
Solution: Set [AUTO PRINT RX] to ON (MX300 / MX310)
AUTO PRINT RX When [AUTO PRINT RX] is set to [OFF], incoming received faxes will be temporarily stored to memory and transaction reports (TX, RX and Activity) remain in memory. The default setting is [ON], which means incoming received faxes and transaction reports will automatically print. The fax machine will not automatically print a received fax and will store it in memory in the following conditions.
  • Ink is low or has run out
  • The paper size and type is not set correctly
  • Paper has run out
  • The Output Tray is closed
To set AUTO PRINT to ON, please follow these steps.
  1. Press the <FAX> button to enter the Fax menu.
  2. Press the <Menu> button. [FAX SETTINGS] is displayed
  3. Press the left or right arrow button to select [RX SETTINGS] , then press <OK> two times.
  4. Press the left arrow to select [ON], then press <OK>.
    Note: When AUTO PRINT RX is set ON, a sub-menu will appear to PRINT WHEN NO INK.
  5. At sub-menu PRINT WHEN NO INK, decide if you'd like the machine to continue to print incoming received faxes if ink is low.
    CAUTION: When this option is set ON, the fax machine will not monitor the ink level of the ink cartridges. If ink is low or out, received faxes will print with streaks or blank. Furthermore, once the fax is printed, it will be deleted from memory.
    1. To print received faxes when ink is low or out, press the left or right arrow to select [ON] and then press <OK>.
    2. To store received faxes in memory when ink is low or out, press the left or right arrow to select [OFF] and then press <OK>.
  6. Press the <Stop/Reset> repeatedly to return to Fax standby mode.
Nov 17, 2009 | Canon PIXMA MX310 All-In-One Printer
We are getting a message "waiting on report" when trying to fax
I experienced this problem when "Fax Setting -> TX Setting -> Print Report" is configured before you send out the fax.
After your Fax was sent, and the message "Waiting for report" appear forever and does not leave.
It is because your INK Level is Low and your have set "Fax Setting -> RX Setting -> Auto Print ON -> Print when no ink OFF", and so the report will not be printed out due to ink level is low.
Solution:
Configure "Fax Setting -> RX Setting -> Auto Print ON -> Print when no ink to ON", and the report will be printed out immediately, the message disappear.
May 29, 2009 | Canon PIXMA MX300 All-in-One Printer
Printer keeps defaulting to fax option
You have set the default printer to the Fax option.
Firstly, you could use the drop down menu where the Printer is displayed (when you go to print), and select the "regular" printer as opposed to the 'fax printer".
To set the default permanently to the laser printer....go to "printers and faxes" in 'control panel'. You will see a "check mark" next to the 'Canon MX 300 Fax' (or whatever it is called) identifying it as default. You want to put the 'check' next to the "regular printer" (whatever it is called)....'right click' on it, then "left click' on "set as default". Now when you go to print anything, it will just print.
Please rate me:)
May 01, 2009 | Canon PIXMA MX300 All-in-One Printer
I don't want fax receiving confirmation report it waste my paper.
Go to menu (wrench)
Arrow down to Reports - OK
Arrow down to Fax Reports - Ok
Hit Ok at Fax Confirmation
Select Never and hit OK
Hit Cancel when done and it should now not print confirmations.
Dec 05, 2008 | HP LaserJet M1522nf Multifunction Printer...
Canon MX300 Office All-In-One Printer Logo
73 people viewed this question
old marine
old marine
