Question about HP Photosmart 3210 Printer
The door hinges on my 3210 have broken. can i get replacement hinges
Me 2 I was changing the yellow and went o close the door and POW the hinge on the right side broke. Wondering if you got a hold of hp? If not I'll buy you good hinge?:) they appear to be inter changeable right or left.:)
or to any one else reading this I'll buy your god hinges.
Posted on May 12, 2010
  • cleancotton May 16, 2010
    Normal
    0
    false
    false
    false
    MicrosoftInternetExplorer4
    st1\:*{behavior:url(#ieooui) }
    /* Style Definitions */
    table.MsoNormalTable
    {mso-style-name:"Table Normal";
    mso-tstyle-rowband-size:0;
    mso-tstyle-colband-size:0;
    mso-style-noshow:yes;
    mso-style-parent:"";
    mso-padding-alt:0in 5.4pt 0in 5.4pt;
    mso-para-margin:0in;
    mso-para-margin-bottom:.0001pt;
    mso-pagination:widow-orphan;
    font-size:10.0pt;
    font-family:"Times New Roman";
    mso-ansi-language:#0400;
    mso-fareast-language:#0400;
    mso-bidi-language:#0400;}
    I ended up making my own from steel. Used a set of calipers
    to get all measurements and pulled the other hinge out to insure it was a very
    close match. Took about 3 hrs to get the rough shape then about another 3 to 4
    for clean up and paint. Used an air saw to cut the basic shape and bend the cut.
    Cleaned it up with a 90 degree die grinder using 120 grit wheel. Used a belt
    sander to make sure all cuts were 90s. I drilled all holes using a drill press.
    The only part most can’t do is weld the bottom. It cost me about 6 bucks
    for the metal. I happen to have all the fun toys so I did it and proud to say
    its 1,000,000% MADE IN THE U.S.A.
    P.S. there is a clip holding the bezel to the USB car slot behind
    the camera image. Use a pick or tiny screwdriver to pop the oval thing out and
    then pry down and out on the little front cover.
    Pre weld
    And yes it does work save me fom spending anothe $300 on new Like printer.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 121 Answers
Hinges seprately cannot be replaced . for support needs you can call hp tech support team 1800-474-6836 ask for printers and ask for the same. if its under factory warranty the entire printer can be replaced//
Posted on May 08, 2010
2 Suggested Answers
  • 6 Answers
SOURCE: the plastic hinges on my 3210 that hold the top on
Is it just stuck? Because if it is just use WD40 on the hinges. If it's broken, then sorry. Can't help you.
Posted on Mar 12, 2010
Have a Xerox 3210 workcentre serial no: 5294298012 but the top flap is broken looking for a replacement?
The hinges are available, the part number is 003N01051. http://www.iteminconline.com/itemdesc.asp?ic=003N01051&eq=&Tp=
Aug 28, 2014 | Xerox Office Equipment & Supplies
Both hinges broke after opening the door. Are there any replacement hinges available? thank you,
By checking with your local HP dealer you can either get used replacement parts or they can order a new part for your printer. They can also do an assessment to see what it will cost to replace the part. Sometimes it is cheaper to replace the printer than ordering new parts. You can also try your local rycle place and see if they have the same model that recently came in to be recycled.
May 28, 2010 | HP Photosmart 3210 Printer
The plastic hinge on the cover of my HP 3210 printer cover is broken and a nearby electrical connector has been disconnected. can you fix the problem or suggest someone who can.
Me 2 I was changing a the yellow cartridge and try to close the lid and POW the hinge on the right side broke. I got the printer opened and had to disconnect three ribbon cables the 3.5 mm jack and one 6 pin connector plug.
Apr 28, 2010 | HP Photosmart 3210 Printer
The plastic hinges on my 3210 that hold the top on
Jan 18, 2010 | HP Photosmart 3210 Printer
Broken hinge....where do i get it and how do i put back together
hi,you can try contacting hp about this.they may send you a new one.as far as fixing this it would be more costly than the printer is worth sry.
Mar 04, 2009 | HP Photosmart 3210 Printer
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. Neff are sending replacement hinges but as a temporary repair I intend to swop the hinges around...
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. As a temporary repair I intend to swop the hinges around -replacing the top hinge with the middle one but can't see how to remove the hinges. Can anyone help?
May 02, 2008 | Refrigerators
HP Photosmart 3210 Printer Logo
437 people viewed this question
Seeker5211
Seeker5211
