Question about Refrigerators
Freezer compartment of fridge freezer working ok but fridge section not cooling
  • Anonymous Mar 27, 2008
    sane fridge not cooling
    Novelist:
  • 184 Answers
ON ALMOST ALL REFRIGERATORS, THE FRESH FOOD SECTION GETS ITS COOLING FROM THE FREEZER BY AIR CIRCULATION. IF THE AIR ISN'T CIRCULATING, FINDING THE CAUSE WILL REMEDY THE PROBLEM. THE MOST FREQUENT FAILURE IS THE DEFROST CYCLE AND IS EASILY DIAGNOSED BY LOOKING IN THE FREEZER SECTION. IF FROST IS PRESENT ON THE BACK WALL, (OR FLOOR OF OLD MAGIC CHEF TOP MOUNT), THEN A DEFROST FAILURE HAS OCCURED. THERE ARE THREE COMPONENTS IN THE DEFROST CIRCUIT. THE CONTROL, THE HEATER, AND THE BI-METAL. FIND THE DEFROST CONTROL AND SET TO DEFROST. IF THE HEATER COMES ON, THE CONTROL IS BAD. IF THE HEATER DOES NOT COME ON, EITHER THE HEATER OR THE BI-METAL IS BAD.
TO FIND THE BI-METAL, FOLLOW ONE SIDE OF THE HEATER WIRE FROM THE HEATER TO A SMALL ROUND DISC WITH TWO WIRES COMING OUT OF IT. THAT IS THE BI-METAL.DETERMINE WHICH IS BAD WITH VOLTAGE OR RESISTANCE MEASUREMENTS.
Posted on Mar 27, 2008
SOURCE:
My RJ 523V-R refrigerator has worked perfectly for 8 years, but suddenly stopped cooling the fridge properly while the freezer seems ok. how can I fix this?
Often times their is a fan from the freezer section to the refrigerator section, of some brands of boxes. If the fan goes out, the refrigerator sections no longer cools.
May 23, 2014 | Electrolux Refrigerators
G.E. Bottom freezer evap drain keeps freezing up and ice build up stops fan so no cooling in fridge compartment. How can this be solved?
When the freezer section gets cold and reaches its required cooling temperature, after that the frost on freezer section starts defrosting and the cooling fan in the freezer section blows this cool air from freezer to fridge. But if the defrost cycle does not start then over ice will get collected on freezer ventilations and that will block the air passing section from freezer to fridge, so the freezer gets cool but fridge section does not cool.Its defrost problem. Try manual defrost by unplugging the refrigerator from main power outlet for 24 hours then reconnect it and check, if the same problem is noticed again,. If yes then its defrost board problem. The defrost board located in the back of fridge section. You can get required parts from www.repairclinic.com or from online sears part site. ------------- Thank you.
Feb 22, 2011 | Refrigerators
Fridge compatment not cooling
If freezer compartment is cold and fan is working, do a 12 hour defrost and all should be ok.
May 21, 2010 | Refrigerators
My Amana fridge #ARB2215CB seems to be cooling the
Your refrigerator probably has an issue with its "damper control assembly", which regulates cold air coming from the freezer compartment. Contact an appliance service company.
Apr 13, 2010 | Amana ARB2217C Bottom Freezer Refrigerator
Refrigerator Compartment not cooling properly: freezer compartment working properly
Check the freezer section for frost build up, there is probably a problem with the defrost cycle. 1 of 3 things defrost bi metal would be the likely problem.The back panel in the freezer should be removed to see if there is too much frost.
May 01, 2009 | Frigidaire FRT18S6AW Top Freezer...
Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Oct 29, 2008 | Amana ABB2227DE Bottom Freezer...
Top Freezer section working Bottom Refrigerator not getting cold
I have a side by side jenn-air refrigerator, the freezer compartment working fine and making ice like it should, however the refrigerator compartmant is not cooling, no cold air is felt, I need advise.
Sep 28, 2008 | LG LRTC19314ST Top Freezer Refrigerator
Samsung side by side
Check for snow on the back wall of the freezer compartment, Air to cool the refrigerator is supplied from the freezer section. If the coil is frozen over the air circulation becomes retarded and the refrigerator suffers. Snow on the back wall indicates a defrost problem.
May 15, 2008 | Refrigerators
FRIDGE NOT WORKING
Most side by side and other models of refrigerator freezer combinations are of one basic design. The freezer section does the cooling for both compartments. The refrigerator section gets it cold air from the freezer compartment. Therefore check for frost on the back wall of the freezer compartment. If frost is present there you have a defrost problem and it is cutting off the air that cools the refrigerator section.
I think this problem may already be resolved in some manor because of the date of post. Posts should expire after an unreasonable time period.
Mar 19, 2008 | Smeg FA561X Side by Side Refrigerator
Refrigerators Logo
157 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
