Hello my insignia ns pdp50 has running vertical lines all across the screen. It worked fine for the last week and this just happened when i turned it on, i removed the back of the tv last night and blew the dust out and put it bacx together and it worked fine until this morning and it did it again. Help please
  • 2,335 Answers
Are the lines evenly spaced like in this photo, or random:
If so, this may be more indicative of a signal noise problem rather than component failure. Either way, I recommend:
Try changing your video source to confirm if you get the lines on cable and on dvd for example.
Try changing your cable signal to a different input plug on your tv, like a front plug.
Try changing you cable signal type; switch from hdmi to component or vice versa.
This will give you more information regarding whether the source of your lines are specific to a particular cable, or source, or input circuitry.
I understand that blowing the dust helped for a day, but since it started up again right away, this tells me that unless all that dust has accumulated again, it might have had more to do with the power being off on the TV and connections being unplugged.
Try to confirm this by just unplugging the power again for as long as you did before.
Bottom line, if the problem isn't solved by simply a 'noisy' cable or source, your TV is suffering some component failure in its power or signal processing, and will need service.
I hope that helps.
Posted on May 08, 2010
My 27 inch Insignia flat screen tube TV goes blank
The vertical deflection has gone out. Put it in the shop.
Apr 24, 2010 | Insignia NS-27RTV 27" TV
Tip
Insignia NS-PDP50 Manual Download
Download Insignia NS-PDP50 Plasma HDTV Manual
Have you misplaced your Insignia NS-PDP50 Plasma HDTV Manual ?
Would you like a digital, searchable, pdf version of the Insignia NS-PDP50 Plasma HDTV Guide?
Follow this link (& click FREE) to download a pdf version of the Insignia NS-PDP50 Plasma HDTV documentation.
I hope that helps.
__________________________________
on May 08, 2010 | Televison & Video
Tip
I hope that helps.
on May 08, 2010 | Insignia 50 in. Flat-Panel Plasma HDTV
I purchased this hdtv new from Best Buy in February 2008. Last week a crackling sound began to develop and now the sound has gone completely, although the picture is fine.
Insignia T.V. 50" Model; NS-PDP50, Plasma T.V.
T.V. comes on, there is sound but no picture.
T.V. is les than 18 months old. We use the T.V. when we come to our Condo in Daytona Beach for vacation, so it hasn't been used very much.
Jan 10, 2010 | Insignia LCDTV26 26 in. Television
Insignia NS-PDP50 Plasma TV - Remote Sensor failure
Change batteries.Reboot everythings.Tv unplug,replug couple mins later.Ur Directv box,push off/on for new update software.After that sould work.Rate me after u done this.
Jan 02, 2010 | Insignia NSPDP50 50 in. HD-Ready Plasma TV
Insignia 27" lcd tv vertical colored lines across screen.
This television, appears to have had a failure in the mainboard. This is the board that controls the video functions and sound functions. The unit should be taken or sent in to a service center for testing and servicing. The service center will have all the correct service information to determine the problem for you. You can call Insignia customer support at this telephone number 1-877-467-4289. You can also got to the customer support website at www.insignia-products.com. Go to the support section and ask them for help on how to get service for your television. I hope this information helps you with your problem.
May 14, 2009 | Insignia IS-LCDTV32 32 in. Television
Insignia 32" TV Thin line across screen 1-2" from top
This is usually caused by bad capacitors in the vertical circuit. If you have an electronics background you should be able to find the defective ones with an ESR tester .
Dec 16, 2008 | Insignia NS- 27" TV27 TV
Can I please get a real solution?
Vertical Ic and capacitors alround 100uf 35V. Check for loose connections . questions? noetvs@embarqmail.com Thank you
Jul 24, 2008 | Insignia NS- 27" TV27 TV
Insignia 32" Tube TV NS-RTV32
The vertical output IC LA7847 is failing. It will likely fail permanately and you will have just the horizontal line. The set will require service. Just do not run the set very long in this state. That thin white line can likely burn into the crt phospher and will show all the time thus ruining the glass picture tube...
Jun 05, 2008 | Televison & Video
Problem with my insignia tube tv!!!!
if that look like horizontal line shuld be vertical problem. check vertical ic around it of resistor& capacitor. good luck!
May 26, 2008 | Insignia NS- 27" TV27 TV
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
