Question about Nespresso Essenza C100 Espresso Machine/Coffee Maker
When I push the "espresso" button of my nespresson essenza automatic, it just keeps running until the espresso cup overflows. It has never done that before.
  • 21 Answers
Did you shut your machine off? you just have to reset it. That has happened when I descaled machine. You need to hold the button for as long as you want the cup to fill. ex. hold the button down and count 15 secs. Next time you use the machine it should fill for the 15 secs. (use a used pod so you don't waste the good coffee). That has always worked for me. I had to set both sides (small cup and large cup, you my have to also). hope this helps!
Posted on May 08, 2010
Testimonial: "Thank you for this great. I love this site!!! Nespresso never replied and I had a reply from this site within a couple of hours. A million thanks."
Magimix Essenza M100 - purchase last week Is there a way of selecting cup size to adjust volume of water delivered? or Do I have to manually switch off the water flow?
It depends if you have a manual or an automatic machine. If you're not sure, the manual one has just one green button, whereas the automatic has two. The automatic one delivers a fixed amount of water, which you can vary but following the instructions. If you have a manual one then you need to press the button once to start the flow, and again to turn it off.
Hope this helps. :o)
Aug 18, 2011 | Magimix L'Expresso Espresso Machine
Lights blinking
A longer description will help people debug your problem. I had the problem that the lights on my essenza machine would blink fast and not stop blinking. Pressing the button would pour out luke warm water without any consideration for the fill level of the cup. Turns out that machine was in Descaling mode. See section 7 of the manual. To get out back to normal mode, hold down both the buttons for 3 secs.
Jun 19, 2011 | Nespresso Essenza C100 Espresso...
Machine stopped working and both buttons are flickering, if I push the left (small coffee) button then the machine starts to pump cold water. If I push the left (large coffee) button nothing happens. Not...
May be busted, but before you take it to the shop try these few things. 1. Unplug machine for 30 seconds 2. Then plug back in, (lights should still be blinking) Take silver handle that you lift when you put in coffee pods and gently push back handle as far as you can for 3 seconds. This should reset your machine,back to factory settings. To then reset coffee cup settings to your personal taste by: 3. You can adjust the fill of coffee by holding the large coffee cup down for as long as you want to fill it. Try holding the button down for 20secs., next cup of coffee should automatically fill for 20 seconds. Do the same for small coffee side. Hope this works,it has for me; just not sure because of the cold water pumping out issue. good luck
Nov 11, 2010 | Nespresso Essenza C100 Espresso...
When you press the button for a large cup of espresso (Nespresso Essenza) only small amount comes out
You can adjust the fill of coffee by holding the large coffee cup down for as long as you want to fill it. Try holding the button down for 20secs., next cup of coffee should automatically fill for 20 seconds. The small cup that you are currently getting was probably set at the factory. Good luck
Nov 19, 2009 | Nespresso Essenza C100 Espresso...
Does not draw water when tank is refilled.
Open the top (as if you want to insert a cup) and push back a bit more. This should get the air out of the system.
Sep 02, 2009 | Nespresso C100B Essenza Single-Serve...
My nespresso does not make a full cup any more
Another good solution, though the previous one was good, is that you can factory reset the cup sizes. All you have to do is switch the machine off, and then press and hold the large cup button. After about 10 seconds, keeping your finger on the large cup button, switch the machine on -- then let go of the large cup button after about two more seconds.
Aug 15, 2009 | Nespresso Essenza C100 Espresso...
The machine seems not to be working well
I had very similar problem and found the fix here.
Did you try the reset process? Place an empty cup, insert a coffe pod, press and keep pressing the "Lungo" button until the cup is filled as desired then release it. Next coffee, just press once, it should be now set at the desired level.
Jan 03, 2009 | Nespresso C100B Essenza Single-Serve...
Does not stop making coffee
The machine has a reset capability to set the amount of coffee. Just push and hold the button for as long as you want coffee. Then let go of the button and it's reset.
Jul 13, 2008 | Nespresso C100B Essenza Single-Serve...
Too little coffee
reset to factory default...
1. Power switch off
2. Press & hold coffee cup button while powering back ON
Mar 22, 2008 | Nespresso Essenza C100 Espresso...
Nespresso Essenza C100 Espresso Machine/Coffee Maker Logo
2,374 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
