Question about Danby DDR3009EE Dehumidifier
Ice is forming at the top of the bucket what can I do??
  • Danby Master
  • 43,501 Answers
Dehumidifiersice is forming at the top of the bucket what can I - 2_bing.gif freezing up can be causes by a few different problems.
Here is a tip that I wrote to help people with the freezing dehumidifier2_bing.gif problem....
Dehumidifier is Freezing up and not working
http://www.fixya.com/support/r4662033-dehumidifier_freezing_up_not_working
heatman101
Posted on May 08, 2010
How does it work
info???????????????????????????????????
http://home.howstuffworks.com/dehumidifier1.htm
Apr 04, 2015 | Dehumidifiers
AD 25G0 - the light keeps coming on to indicate that it needs to be emptied but there is barely any water in there and when the light is on, it shuts off.
It sounds as if the float valve in the top of the water collection bucket may be stuck in the UP position.
Remove the bucket and check the float valve. If it is stuck in the up position, jiggle the arm of the float valve to get it return to the DOWN position.
When reinstalling the bucket, be sure that it fits "squarely" into it's holder form top to bottom and that it makes firm contact with the bucket safety removal switch on the rear wall of the bucket holder.
Hope this helped you and thanks for choosing FixYa.
Sep 16, 2011 | Whirlpool AD40DSL Dehumidifier
Unit shows full bucket whe bucket is empty and shuts off
I beleive the model you have, has a float valve in the top of the water collection bucket. If it's stuck in the 'UP' position, it would cause the Bucket Full Light to glow. Remove the bucket form it's holder and determine if the bucket does have the float valve. If so, jiggle the float valve arm to get it to return to the Down position.
If the unit doesn't have a float valve, installing the bucket "squarely" into it's holder from top to bottom is very important. If the bucket does not make firm contact with the bucket removal safety switch (A trigger switch), it will cause the unit to think the bucket is full. After reinstalling the bucket, be sure that the bottom of the bucket is not tilted down in any way.
Hope this helped you to troubleshoot and solve the problem.
Jul 08, 2011 | Kenmore 53509 Dehumidifier
Does not collect water in bucket but runs all the time
Does it have a filter?
http://whirlpool.custhelp.com/app/answers/detail/a_id/953
also:
It may be that the humidity level or temperature in the room where your dehumidifier is located is too low.
When the outdoor temperature is below 50 F, the indoor air will be dry even when the air inside is warm, therefore when it's cold outside the dehumidifier may collect little or no water.
Air conditioners will also remove moisture from the room, even if it's hot and humid outside, resulting in little or no moisture collecting in the dehumidifier bucket.
Some dehumidifiers have a deicer which turns off the compressor but keeps the fan running. When the compressor is off, moisture is not removed from the air. The deicer turns off the compressor when the room temperature is cold.
Some dehumidifiers do not have a deicer. If the room temperature is low enough, ice may form on the evaporator coil. The ice prevents the dehumidifier from removing and collecting water. If ice forms on coils, unplug dehumidifier until ice melts and room temperature rises."
Jun 21, 2011 | Whirlpool AD25BBK Dehumidifier
Our dehumidifier has formed a sheet of ice amongst the coils and will no longer pull moisture from the air. The hole from which the water drips is completely iced over. It is 70degrees in the room and...
Turn the unit OFF and unplug it from the wall. Allow it to thoroughly thaw and remove the humidifiers cabinet to expose the cooling coils. Clean those thoroughly and coat with a very light coating of WD40. Reassemble the humidifier and turn it ON. Set your humidity control at 50% and allow the unit to run for at least one hour. Check for water collection in the bucket and for any signs of icing, after one hour. If water is in the collection bucket and no signs of icing, lower the humidity to 45% and continue. If you not any signs of icing, watch the unit, as you need to know if it automatically goes into defrost mode. The compressor should shut off, but the fan will continue to run until defrosting is completed. If it doesn't the auto defrost sensor has failed and will need to be replaced.
Hope this helps you to troubleshoot and solve the problem. Please let me know. Thanks.
May 08, 2011 | Dehumidifiers
Dehumdifier not collecting water.
The filter (on some models) may be dirty or clogged. If so, clean the filter. For instructions on cleaning the filter.
I hope this help to solve, if this answer solve it, remember to rate it. Good luck.
Oct 01, 2010 | Whirlpool AD50USL Dehumidifier
Bucket not filling - ice forming on lid.
You've developed a sealed system problem.
Apr 07, 2010 | LG LHD45EL Dehumidifier
Ice on dehumidifier
A dehumidifier works by cooling the metal pipes on the back of the unit to create condensation (water vapor in the air). This then drips into the collector bucket. If the unit runs too long the cooling tubes can get too cold and freeze the condesing water vapor. Unplug the dehumidifier and let the ice melt, when u turn it back on, turn it down, it may be up too high. If you find this solution helpful please rate it.
Thanks - Tech101
May 20, 2008 | LG DH404E Dehumidifier
Unit Runs (fan and condenser) but no water?
By condenser I assume you mean the compressor is running. Is there ice forming on the front coil?
Jan 08, 2008 | Comfort-Aire BHD-651 Dehumidifier
Danby DDR3009EE Dehumidifier Logo
82 people viewed this question
Top Danby Dehumidifiers Experts
Bill Long
Colin Stickland
Colin Stickland
Gil Shultz
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
