Question about Technics SL-1210MK5 Turntable
Iwant to use my Technics SL - 1210 MK 2 turntable -120 volts 60 Hz in India.What kind of adaptor should I use. Will the motor be damaged on the long run?
djproaudio
  • 515 Answers
SOURCE: Technics sl-1610 mk 2 turntable
Unfortunately, it does sound like a drive issue. Just so you know, these units are direct drive, so there is no physical motor. It's just a bunch of various circuits which drive the unit, and if any one of them go bad, it will affect your turntable speed. You will need to have this looked at by a service technician to determine which circuit is faulty.
- TWEAK AV LAB
Posted on Dec 02, 2007
djproaudio
  • 515 Answers
SOURCE: How old is my Technics SL 1210 Mk2
Here's some information for you. Since your unit is a SL1210MK2, it may be harder to determine the age of the unit:
It is possible to tell the year (and the month) when the SL-1200 was manufactured from the serial number on the back or bottom of the turntable. SL-1200 serial numbers are in two different formats, depending on the date of manufacture. It isn't exactly possible to determine the decade in which the SL-1200 in question was manufactured, as the serial number contains only the last digit of the year. If the year digit is 8, the turntable may have been manufactured in 1978, 1988 or 1998. If the year digit is 0, the turntable may have been manufactured in 1980, 1990 or 2000. One rule of thumb is that old-format serial numbers belong to SL-1200s manufactured during the 1970s and 1980s, while new-format serial numbers belong to SL-1200s manufactured during the 1990s and beyond.
Old-format serial number: NHOJF20765 (SL-1200 manufactured 1982)
The first digit shows the year when the SL-1200 was manufactured. These serial numbers contain no indication of the month of manufacture. It should be noted that serial numbers in this format contain no letters following digits.
New-format serial number: GE4FB001154 (SL-1200 manufactured June 2004)
The first digit shows the year when the SL-1200 was manufactured, while the month of manufacture is indicated by the letter following it. Months are coded as letters between A and L inclusive; A indicates January, B indicates February, and so on.
In addition to the above, all the SL-1200MK2s from the 70's and early 80's have a 4 inch diameter plate where the RCA and ground wires enter the chassis in the rubber base of the unit. The later models have a smaller hole through which the wires enter the unit.
TWEAK A/V LAB
www.DJPROLAB.com
Posted on Apr 10, 2008
djproaudio
  • 515 Answers
SOURCE: Tecnics SL-1210 MK 2 Spare Parts & Needles
Not sure about Mexico, but you can get them online here:
www.1200s.com
www.turntablelab.com
www.pssl.com
Posted on Jul 02, 2008
SOURCE: Technics SL-23 belt driven turntable (NOT SL-1210 but I had to enter something)
You just need a new belt, they're around 20 bucks. Buy them in pairs, or threes.  They stretch out about every seven years.
Posted on Sep 21, 2008
robotek
  • 1512 Answers
SOURCE: looking for manual for a turntable sl-1700
Hi
You can down load the user manual and the service manual from here
You have to register to download them, but they are for free!! Good luck, happy to answer any questions you may have.
regards robotek
Posted on Jul 08, 2009
Technics Sl-1210 MkII spins backwards
As the turntable was hit hard then an internal inspection should be done to look for signs of phyical damage. It could be anything from broken parts to bad soldering or a crack on the PC board. I rather suspect it should be obvious what got damaged when you look inside.
Feb 28, 2013 | Technics SL-1210 Turntable
I have two 1210s, a mk 2 and a mk 5. When I let go of a record on my mk 2 it seems to take longer to catch speed compared to my mk 5, and feels 'slack'. Any ideas what this is?
Being the older model, the chances are that the drive belt on the Mk2 turntable has got worn and shiny with use. It may also have stretched a bit. If you are using the tables for 'scratching', the fact that you are holding onto the turntable when the motor is running is placing a strain on the belt that it is not really designed for. I would recommend changing the belt - you can easily find spare belts for sale on the internet
Feb 02, 2011 | Technics SL-1210 Turntable
Change euro electrical plug to north american
As long as the mains cable running into the deck has only 120 volts going down and the switch is set to 120, there's no reason why you can't cut off the euro plug and fit a USA type plug.
Feb 14, 2010 | Technics SL-1210 Turntable
A friend stupidly plugged his deck into a 120 volt power supply
More than likely the power supply / power transformer has blown. Although these units have fuses, they will not protect from such a power surge.
Have you lost power, or is the platter rotating abnormally? If there is no power, it's the power supply that needs to be replaced. If it's acting funning, then some components on the main drive PCB are damaged. In either case, professional help is highly recommended.
- OPTiC
Turntable Repair Expert
Digital Analog Therapy
A DJ PRO AUDIO Co.
Nov 24, 2008 | Technics SL-1210 Turntable
1210 mk 2 pitch
Doubt it, ive heard of this problem before, usually people buying them second hand and the answer has always been get them repaired professionally, i dont know the reason for them doing it sorry.
Jun 10, 2008 | Technics SL-1210 Turntable
www.1200s.com
www.pssl.com
May 25, 2008 | Technics SL-1210 Turntable
- TWEAK AV LAB
Nov 26, 2007 | Technics SL-1200MK2 Turntable
Different HZs problem (from 60Hz to 50Hz)
Yes there are frequency converters available but most are relatively over rated (industrial) for your requirement such as MDS Power or VisiComm Industries. What you need is a Low Power Solid State Frequency Converters lower than a
Electrocon Frequency Converters. However, I expect this devices to be rather expensive.
A few other options you may want to consider:
1. Contact the store where you bought if from; swap with an International version (Model SL-1210 Mark II; same price as SL-1200 Mark II); dual voltage switchable on rear of unit: 120 volts/60 Hz (U.S.) or 220 volts/50 Hz (Europe). You hopefully just spend for the cost of shipping + a restocking fee;
2. Contact 3rd party Technics TT specialist like TopDJGear, Quality Electronics, Planet DJ or DJHardware
and inquire if they would supply you the part(s) that you need to convert the 1200 to a 1210; or
3. Offer a swap on eBay.
Hope this be of some idea/help. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 13, 2007 | Technics SL-1200MK2 Turntable
Technic turntable SL-101
http://1200s.com/Store/PARTS-TECHNICS-TURNTABLES/c271_272_278/index.html
These guys are pros.
Nov 07, 2007 | Technics SL-1210 Turntable
Technics SL-1210MK5 Turntable Logo
78 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
