Question about Toshiba Satellite L305-S5911 Notebook PC
Will not work with ac adaptor - Toshiba Satellite L305-S5911 Notebook PC
    President:
  • 524 Answers
Click here to buy toshiba global adaptor for your computer
Please let me know if you have any further questions or concerns.
Thanks.
Posted on May 07, 2010
My remote speaker system works with the batteries but not with the AC adaptor plugged in to the speaker.
I would suggest to check AC outlet first where adaptor is pluged in,if Ok measure output voltage from adaptor to see if there is any (using any voltage multimeter with AC/DC)
Check label on adaptor shold be writen AC or DC output ,and value 3V,6,9,12,24,48 etc...
If adaptor is ok then problem is power jack mounted in to the speaker (cold solder joints' or damage)
Aug 23, 2011 | Audio Players & Recorders
Lenovo laptop(8932) will go into a sleep like mode (you can still see the screen, very dim) when plugged into ac adaptor. Doesn't do it with battery power. Changed system board, power adaptor - no...
Good Day Psmith!
It looks like the AC adaptor is not making the right supply voltage needed for your laptop.
If you have a multi tester, you can test your ac adaptor to see if it has stable 20V voltage output supply needed for the laptop to make it work.
Set your tester to DC range. Plug the ac adaptor to your wall socket. Hold the other end of the ac adaptor (the one you connect to your laptop. Insert the red (positive) lead into the center of the adapter pin, then touch the black (negative) lead to the outside metal part of the pin.
Read the display in your tester. If the adapter is working properly, the meter should read between 19 to 20 volts of the rating. If the adapter is faulty, the meter will read below 18volts.
If that would be the case, I'm afraid you will need to replace your ac adaptor.
You can purchase online a replacement ac adaptor for lenovo 8932.
1. From this site, it costs $34.99 + $8 https://www.ebuybatteries.com/product/models/2_IBM-Lenovo-AC090W008T15_IBM+Lenovo+ThinkPad+R61+8932.htm
2. From this site, it costs $39.95 http://www.eznsmart.com/p-31667-lenovo-thinkpad-r61i-8932-laptop-ac-adapter-replacement-20v-45a-90watt-charger.aspx
Please accept my answer if this is the information you need.
Don't forget to give a four thumbs up rating!
Thank you for asking Fixya.
Jun 23, 2011 | Computers & Internet
My ac adaptor is not working so i want to know wht is the time period of warranty or gurantee of ac adaptors
Hello sir, hi, AC adaptors usually is on warranty with the device they powers. So if your Laptop is one year warranty so as the AC adaptor. to be sure call your dealer for warranty confirmation.
Jun 22, 2010 | Computers & Internet
I have a HP dv7 laptop it does not work with the ac adapter but worked with the battery, whenever it is working with the battery and the ac adapter is connected it shuts down.
Remove the battery and plug the ac adaptor in check wethere the light on the port where you connect the ac adaptor glows or not, if no then check the wethere the ac adaptor is getting warm or not after you plug it in for few minutes if not then ac adaptor has to be replaced.
If the light on the port is glowing then it is likely that the power supply of the notebook has gone bad as it is not able to switch to ac adaptor or the port where you connect the ac adaptor to the notebook has a short circut when the acadaptor pin is connected , better try with a different ac adaptor to be sure wethere the issue is with ac adaptor or the notebook.
My best wishes
Mar 19, 2010 | HP Pavilion dv7-1130us laptop
How do i know if my battery or the charger is the problem causing my camera not to turn on
If the camera works when the AC adaptor is connected its the battery, if dosent work with the AC adaptor, its the AC adaptor.
Jan 22, 2010 | Sony DCR-DVD610 DVD Camcorder
Uploading pictures
Cameras can't upload if low on power. Charge batteries or plug in the ac adaptor to an outlet and try again.
Sep 12, 2009 | Panasonic SDR-H40 HDD Camcorder
Ac Adaptor not working??
as u said that when u plugged in the ac adaptor into the laptop it recognises that the ac adaptor is connected but it does not charge the laptop in this case what u can do is that if have the same charger extra then u can try with the another charger and if the other charger also does the same thing then in this case u need to replace the mmotherboard and if the other charger is working fine in this laptop then definately chage ur aac adaptor.....good luck...
thanks
Jan 25, 2009 | HP Pavilion dv6000z Notebook
Laptop does not work with AC adaptor, does not charge. Mother board issue
You may be able to get a battery charger but its rare.
If you do wish to use the AC adapter, take care with positive and negative. Also the voltage of the battery is actually lower than the AC adapter in order to get charged. I don't know what is going to happen if you do choose to use AC adapter as battery. 75% chance that it will work.
Oct 08, 2008 | Dell Inspiron E1705 Notebook
I bought a targus ac adapter, it worked the first time I charged my Dell 5100 Notebook computor, now a message comes up saying it doesn't recognize the ac adaptor, how can I fix this?
AC adaptor may not be correct. Check label on AC adaptor with label on notebook for voltage (e.g. 19.5V or 20V) and current (e.g. ??A or 90W)
Voltage must be same and current must be same or higher on ac adaptor.
Aug 09, 2008 | Computers & Internet
HP printer AC power adaptor 0950-4399
I want to purchace new HP printer AC power adaptor 0950-4399 from mumbai where shall i contact
Mar 26, 2008 | Office Equipment & Supplies
Toshiba Satellite L305-S5911 Notebook PC Logo
50 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
