Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Water leaking from underneath after washer drains
Water started leaking from underneath the washer. Gradually began leaking more. Seems like the larger loads leak more. Also, does not leak when filling, maybe after draining.
Any suggestions?
  • 2 more comments
  • frnkwht31 Jun 09, 2008
    I have a older model of the kenmore stackable washer/dryer. It has started to leak at bottom but I am having hard time getting back off to see where problem is. Waht is baest way to do this?
  • lslw Jun 25, 2008
    My washer is leaking (drip, drip, drip) while filling the washer almost as soon as the water begins. I can feel it on my fingers. It is dripping about front center, close to the front panel. I turned the dial to spin to eliminate the water in the tube, I felt no water during this time. Is there a hose or clamp in that area that could have come loose? If so, how do I remove the outside of the machine to check it. I cannot see a crack or hole in the tub either.
    thanks for your help in advance.
  • Anonymous Mar 20, 2014
    Washer apparently spraying dark fluid from underneath while in use. Washer working fine,but gradually getting louder during spin cycle for around 5 weeks.
  • Anonymous Mar 28, 2014
    water draining from underneath the washer and black dust everywhere.
I have the same washer and there is a white plastic piece underneath the washer where two hoses go into. It contains the impeller that pumps the water out. Anyway, on my machine this piece was incorrectly injection molded at the factory. The glue bubbled out causing an air bubble -- once the air bubble in the glue can stand the pressure and pops, the leak occurs!!!!! If you are a handyperson, take this piece out and use exopy to fix.
Posted on Mar 30, 2008
    Scholar:
  • 74 Answers
Hiya........... have a good look at the door seal for any visible tears... do it with wet hands... and the electric off!! If you cant see anything... Have a look at the pump couplings.. for any visible signs if leaking!
Get back with the results
regards Faggly
Posted on Mar 27, 2008
Avanti w798-ss e3 error
It seems there is a fault on the main controller unit of the washer. It seems to start and then drain off in mid cycle. Now choose a different program and see if there is any change. Also check individually the inlet valve, the water level sensor and also the drain valve. Also check all the connections to the main panel.
Mar 13, 2012 | Avanti Top Load Washer W797
I have a blue bissell preheat 2x. While shampooing it will start to leak dirty water. When i'm done shampooing my carpets look even more filthy then when I began. Not sure why this is happening besides...
You should drain the dirty water, you should find where it is stock then drain it. If there's some leak, seal it with an epoxy. Thoroughly clean the inside and you will find there's a stock of old shampoo which causes water to become dirt.
I hope my advice help you.
Jul 13, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
WHEN THE WASHER IS IN WASHING CLOTHES THERE IS WATER ON THE GROUND NEAR/UNDERNEATH THE WASHER
Check the hoses on the back and see if there are leaks, there are three hoses, one for hot water, one for cold water and one is a drain. The drain is the big hose. Also check the water drain hose and make sure it is firmly secured to the drain in the wall behind the washer.
Jun 06, 2011 | Washing Machines
I unclogged the GD by removing the pipes underneath and replaced them tightly. GD seems to be working fine now, but water is slowly leaking from underneath the GD! It appears to be leaking from the...
The leak comes from above where water comes out.
Turn off power before touching wet electrical appliance.
Put stopper in disposal.
Fill sink with water.
Check if water is getting through the putty seal at sink connection.
Next, check if water leaks only when dishwasher runs. Dishwasher drains into garbage disposal.
Last, check tailpiece where it attaches to side of garbage disposal. The tailpiece is usually sealed with a rubber washer. When washer is old, it gets deformed, and then it doesn't seal perfectly when put back.
I use rectorseal on all tubular pipe joints under the sink.
Works on both plastic and rubber washers.
It is gooey and sticky.
Brush it all over the washer, use plenty, then assemble pipes.
The rectorseal assures that joint will not leak.
Oct 25, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Leaking underneath
Maybe its not draining completely? Have you tried opening the front panel, pulling out the white plug, putting a bucket under it, unscrewing the front of the plug and checking the filter?
Apr 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a Hoover Washer HNF 1617 that is leaking water underneath.
You may have the threads for that strianer cap crossed or its just loose. First, try tightening it if it still leaks use teflon tape or pipe dope to seal it. there isn't much pressure there...so it is definitly repairable. At worst you may need to replace the drain pump.
Mar 13, 2009 | Hoover Nextra 160 HNWF 3137 Front Load...
Bosch Axxis Washer WFL2060 leaking when filling
yes.you are right.somethin might have cracked.
  • Inspect the water supply connections
  • Inspect the drain hose
  • Inspect the water pump
  • Inspect outer tub for cracks or corrosion
  • Inspect the tub seal
  • Inspect the tub bearing
Dec 12, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Fisher and Paykel Washer leaking water
hi there,
the leak underneath could be from the pump or the drain hose. some washers have a tub to pump boot that sometimes springs a leak.
for a 4-month-old washer, i would certainly hope you pay nothing. F&P appliances come with at least a 2 year warranty. check your user & care guide for warranty information.
Oct 03, 2008 | Washing Machines
Washer leaking water from bottom
looks like you have to replace the RUBBER SEAL thats inside the tub at the center post , try this , remove the panel so you can see inside , put the washer to fill w/ water , and watch closely underneath the tub wheres the transmision is connected , and watch for LEAKS . hope this info helps
Apr 22, 2008 | GE WBSR3140DW Top Load Washer
Maytag Performa Washer
when you put the drain hose on the floor the water will ALWAYS drain out. When the drain is in the proper location (above the height of the tub) and the water is still leaking, if its leaking as it fills you might have a loose hose,or a cracked water inlet valve. If after the water is in the tub and its still leaking you have a bad seal.
Jul 03, 2007 | Maytag Performa PAV2200
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
861 people viewed this question
Dan Webster
Dan Webster
Sal De
