Question about NetGear RangeMax NEXT WNR834B Wireless Router
Internet connection stopped suddenly
Indicator lights:
Power light is off
Blue "I" light is off
Wireless Light is off
1 is steady green
2 is steady green
3 is steady green
4 is steady green
I have tried pressing the reset button and unplugging and plugging the unit
Do I need a new router?
  • 74 Answers
Switch off power to the modem, router and computer. Now switch on the modem first and let all lights on it to be stable.. Then switch on the router and let all lights on the router become stable. Once the lights on router are all stable, switch on the computer and then try to accerss sites.
Posted on May 08, 2010
  • mathur_1 May 08, 2010
    accerss sites.
What is a bonded channel signal
A 'bonded channel' is where the modem combines two or more channels together, for increased bandwidth.
The first light <Power> should be green, indicating power is on.
The second <Receive> light can be green or blue. When it is steady green, no bonding is occurring, (less bandwidth). A steady blue light indicates that the modem is using more than one channel for downloading. That is too say, it is bonding(higher bandwidth). That is the preference.... (If green or blue, and flashing, modem is still setting up....).
The third light <Send> can be green or blue. When it is steady green, no bonding is occurring, (less bandwidth). A steady blue light indicates that the modem is using more than one channel for uploading. That is too say, it is bonding, (higher bandwidth). That is the preference.... (If green or blue, and flashing, modem is still setting up....).
The fourth light <Online> is green, only....
If green and flashing, it is scanning for a connection.....
If green and not flashing, it is finished scanning....
The fifth light is the WiFI indicator of network traffic. (It also is used for WPS pairing, which I doubt you will use. Just stick with the WiFi indicator function...). It should be green, normally..., or non-WPS....
If #2 is blue, and 3# is green, normally...., I suspect that there is too much loss in your in-house system of wiring, and splitters. If that is the case, try putting a 8-12dB 'tap', in series with the whole house. That way, the loss is minimized for your modem to 'send' high bandwidth stuff upstream to the cable guys.... Be sure that the modem is connected to the 'tap' port, the house to the 'out' port, the cable company to the 'in' port of the tap block. I pasted a couple of examples of taps, at the bottom of this, to show the port labels. The tap loss to the rest of the house, is minimal to how well everything else works. I get a +15dB signal from the cable company. But, too many splits, left my modem in low speed upload mode. By-passing the splitters of the house, by adding the tap as only loss to modem uploading, my blue light always stays on. I also added an UPS, to cover power failures, and glitches. That was a well spent $50 special!
a3e73f03-c380-49da-8c63-30f45940ca66.jpg ef068fc8-f053-49ce-a577-d352db809e0b.jpg
Jul 30, 2014 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
A problem has occurred when trying to access the internet. Please check your DSL/Cable connection and verify your internet connection settings. Wtf is this ? Firmware update doesnt helped. .
Cables connection might loosen up. Check cables that runs from the wall jack going into your modem, make sure all cables are tightly plugged in. Also, check indicator light on your device. If DSL light is RED, OFF, flashing red, flashing green. there might be trouble with your Internet provider. DSL light indicator MUST be always on STEADY GREEN. If you see that the DSL light is not on STEADY GREEN status call your Internet service provider.
Oct 27, 2012 | D-Link Dlink Dir-600 Wireless Router...
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Wont stop flashing green and I can not connect to xbox live yet I used to be able to Any Help Thanks, Paul
IF The LIGHT IS FLASHING GREEN then there is something wrong with your wireless network
Check your network settings and Retry connecting
Check the adapter's status light loadTOCNode(2, 'moreinformation'); The adapter's status light can tell you a lot about the state that the adapter is in. Here's what the different lights mean:
  • Steady green light: The adapter is connected to a wireless router, gateway, or access point. The adapter is ready to use.
  • Steady red light: The adapter is not recognized. Try plugging the adapter into a USB port on the front of the Xbox 360 console.
  • Flashing green: The adapter is attempting to connect to a wireless network.
  • Flashing red light: There is a problem. The adapter might be experiencing a hardware failure. Contact Xbox support at http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) .
  • No light: The adapter is not receiving power. Unplug the USB connector and plug it in again. Still no light? Try plugging the adapter into a USB port on the front of the console
Jan 10, 2011 | Microsoft Wireless Network Adapter Xbox...
Cannot connect to wireless Linksys WRT300N router. Power off/on, but only the internet indicator ON, wireless indicator OFF... Router is diagnosed as hardware failure, just want to see if there is...
Hi Friend,
You need to try hard reset of your router. Please follow the steps:
1. Power on the router.
2. Push and hold the reset button for 10 seconds (watch whether the power light blinks or not)
3. Turn off the router for 10 seconds and switch it on.
4.Once the power light is steady then perform the steps 1-3 for 2 more times.
5.If the wireless light still shows off, then kindly get in touch with the Linksys technical support centre.
If the wireless light turns to be good and steady then follow the steps to configure the wireless settings:
* Type 192.168.1.1 in the address bar of the web browser and hit enter.
* Type admin as password and leave the username blank
* Click Wireless and fill the sections as mntioned:
Network Mode: Mixed
Netwrok name: As per your choice
Radio Band: Wide-40mhz
Wide Channel- 6
Standard Channel:1-2.412GHZ
SSID Broadcast: Enabled and click save settings.
* Click Wireless Security and fill the sections as mentioned:
Security Mode: WPA Personal
Encryption: TKIP
Pre-shared key: Any ten digit number and click save settings.
turn the router off for 30 seconds and swithc it on. use the pre-shared key to connect your wireless devices.
I hope this will resolve the issue.
Regards
Chiranjeet
Dec 08, 2010 | Linksys WRT300N Wireless Router
Controller wont hook up with console ?
Is this a new controller?
Are the batteries new/recharged?
This is the sequence summary on where you are going to focus:
Step 1 - Controller
Step 2 - Console
Step 3 - Console
Step 4 - Controller
Step 5 - Both
Assuming your controller is a wireless version, Lets start!
Step 1 | Press and hold the Xbox Guide button until the controller turns on. The Xbox Guide button is the round button with the green "X" near the center of the controller.
Step 2 | Make sure that your Xbox 360 console is turned on. If your Xbox 360 console is not turned on, press the power button. The power button is the large round button on your Xbox 360 console.
Step 3 | On the Xbox 360 console, press and release the Connect button. The Connect button is the small round button on the Xbox 360 console.
Step 4 | On the controller, press and release the Connect button. The Connect button is the small button on the front edge of the controller, between the left bumper button and the charging port.
Step 5 | After the Ring of Light spins and flashes one time on the controller and on the console, the controller is connected. The quadrant on the Ring of Light that remains lit indicates the position in which the controller is connected.
Light indicator on console
Green light in the center- power is on
Green light on one quadrant - controller is connected
Four green lights rotating on four quadrants - ready to connect with controller
Light indicator on wireless controllers
No lights - no batteries
Green steady light on one quadrant - connected
Blinking green lights - its either its ready to connect or the batteries are dying
*Make sure that you have a fully recharged rechargeable batteries
*Make sure that you have a functioning/new non-rechargeable batteries
*If the steps above aren't working use another Xbox360 controller and follow the same steps.
If the new/working controller is connecting with the console this means that the previous controller is faulty - needs replacement.
If the new/working controller is not connecting with the console this may mean that the console is faulty - needs repair.
*NEVER TAMPER WITH ANY OF THE TWO AS TAMPERING WILL VOID EXISTING WARRANTY.
Nov 23, 2009 | Microsoft Xbox 360 Console
How do i set my my motorola h350 into discoverable mode
Plug the Motorola charger into the end of
the headset.
The blue indicator light turns on when the
battery is charging. It may take up to 1
minute for the light to turn on. When the
headset's battery is fully charged (about 2
hours), the blue indicator light turns off.
With the headset power off, press and hold
the Call button for 6 to 10 seconds until the
blue indicator light turns on and remains
steadily lit.
Note: The blue light will flash as you press and hold the Call
button. Continue holding down the Call button until the blue
light is steadily lit.
Note: If you let go of the Call button before the blue light is
on and steady, ensure that your headset is off before trying
again.
Oct 05, 2009 | Motorola Mobility H300 Wireless Headset
My wireless router cannot connect to my new server modem.
Try to power cycle the network.
1. Power OFF the router then modem
2. Wait for 5 minutes
3. Power ON the modem first and wait for the light to be steady.
4. When the lights are steady on the modem, turn on the router.
Jul 14, 2009 | Belkin (F5D8231-4) Wireless Router...
Supertooth one user manual
Charge your Supertooth one via the car charger or by attaching a usb/mini usb cable to your computer usb port. Need to charge for 4-10 hrs. Indicator light glows red (needs charging), orange (charging) or green (charged)
Power on: Press green button for 1 second. Indicator light blinks blue. A beep will be heard
Power off: Press green button for 1 second. Indicator light turns red. A beep will be heard
To pair with your mobile phone:
1. Press green button on Supertooth for 5 secs until indicator light blinks red/blue 2. Access bluetooth menu on your phone. Turn bluetooth on. Execute a bluetooth search. 3. Select ST ONE from list 4. When phone requests password enter 0000 and press OK 5. The handsfree kit is now ready for use 6. Clip Supertooth on sun visor of your car so that the microphone and control buttons are directed towards you.
To make a call: Dial number on phone. Supertooth will automatically connect. Indicator light is steady blue during call
To end a call: Press red button for 1 second
To answer a call: Press green button for 1 second. The bluetooth indicator will turn a steady blue.
To increase/decrease volume. Press volume buttons repeatedly up or down. They are situated between red and green buttons.
Hope this helps.
Nov 22, 2008 | Cell Phones
My HP Pavilion dv6000 the wireless connection stopped working and the light does not go blue to connect to internet. This happened 2 days ago. I can connect using a cable.
Check if it is only a software problem. Usually the blue light indicator functions with the physical slider switch. So even it is disabled in the network properties the indicator still lights when the physical switch is at "on" position.
Sep 25, 2008 | Computers & Internet
NetGear RangeMax  NEXT WNR834B Wireless Router Logo
365 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
