Question about TruTech PM1919BXA1 19 in. LCD TV
I have my dvd connected correctly to my truetech tv but sometimes it won't reconize my dvd player. The Tv shows a blue screen that says "AV s-video" what does that mean.
4 Suggested Answers
  • 10865 Answers
SOURCE: need code to program direct tv for truetech tv
here is a list of all of the direct tv codes. I do not see your TV on the list, which is sometimes the case. Maybe you will find it there. Hope so.
http://2getdtv.com/directv/tv_codes.html
Posted on May 01, 2009
  • 814 Answers
SOURCE: truetech tv/dvd player
You can contact TruTech technical service at these telephone numbers : 1-800-252-6123 and 1-888-252-6252. They should be able to help you with your problem. I hope this helps you with your problem.
Posted on May 17, 2009
panchal643Ja
  • 243 Answers
SOURCE: hooked up dvd player to tv but no picture
Select Source button from your tv remote keep in AV mode than cheked if you have conected with yellow/red/white rca wire
Posted on Jan 21, 2010
BDP5012 Philips bluray dvd player
Hello
You are done the connections right. But look to the socket colours of both the devices, TV & DVD, so match. Yellow, is meant for video, and one among white is for audio. You have to select the input of the tV to [AV], to get the DVD connected to TV. When the input selection comes right, you will see the Logo of the DVD company on the screen of your tV. Some TVs will have AV-1, and AV-2. Try both SV selections. NB: You must power ON the DVD to get its Logo on TV screen. The wire you connected will look like this I assumes.
Feb 27, 2012 | Philips BDP5012 Blu-Ray Player
When playing a DVD, I get sound but not a picture. The message on the screen is no input, check input. I have checked the cables at the DVD and at the TV and both are connected correctly, i.e. red to...
Have you tried using standard RCA AV cables? yellow-red-white - to TV. Or have you tried using an S-Video cable (a 5-pin mini DIN plug) between your DVD player and TV? if your TV has S-Video input, and your player has S-Video output, a cable for this should be easy to obtain and connect. Not expensive either.
Your TV should automatically detect the connection of S-Video (if it has this feature). S-Video is better quality than standard RCA yellow AV cable. (you can leave the existing component video connected)
You can also check your DVD player 'setup' maybe it is incorrect - make sure when using component video (red-green-blue) to set the player's output to progressive (for a TV that supports it) - unless it is already set to this.
If everything in the setup menu checks out OK, go with the cheap and easy S-Video cable suggestion. Radio Shack may sell these.
Apr 04, 2011 | Sony DVP-NS575P DVD Player
No picture
have you connected up correctly, have you selected correct EXTERNAL inputs, you do NOT "tune" a Channel to see picture, you choose external AV input on set. Must connect color to color. 3 for Composite Video AV.Yellow, Video, Red & White Audio. and 5 cables for Component 3 for Video , & 2 for Audio Blue, Green, Red, Also Red & White, Audio.
AV
Mar 18, 2010 | Panasonic DMR-ES10 DVD Recorder
How do you get DVD picture to show up? Power is
You DO NOT use "Channels" to View a DVD player it usually connected to the AV External input. via AV, Yellow, (Video) Red & White, (Audio) or Component Video, Blue, Red & Green. (Video) + Red & White (Audio). These are selected via the External Inputs.
Feb 18, 2010 | Zenith ZDA311 DVD Player
Technically challenged...need DVD to show on TV screen
hey 1st of all you gotta make sure that your son made tha right connections with the av cable (this is the cable with three different coloured pins) from your DVD to your tv. if this doesnt solve your problem then make sure you are using the correct av channel on your tv set that will allow you 2 play your DVD player because sometimes you cant play your DVD on thhe same av cannel you watch normal tv
Jan 01, 2009 | Pioneer DVR-520H DVD Recorder
How to change from tv to dvd mode
the difference between tv and av, is that av has no showers on the screen. if you change to av you will notice a blue screen, connect your yellow on vedio output and white/ red on audio out of tv
note- before connecting to a vedio touch a tip of your vedio cable some lines will show on your screen, if touch your audio tip harming noise will sound on your tv. if this two happens then you know that your cables are okey. hold your channel button on your tv, channel will start runing after all rf channels finish, tv will go to av.
Oct 13, 2008 | Sony DVP-NS50P DVD Player
My philips dvd player has stopped playing CD's and DVD's and on the display screen it shows "root". i have had this DVD player for 16months. Can you help me?? cheers
Usually "ROOT" is an indication that the player has read the DVD.
ROOT means that the DVD is in the main menu screen.
Sounds like the DVD player is ok, but you may have a loose connection somewhere.
Check all of your AV connections between the TV and DVD.
Also make sure that the TV is set to the same AV channel as the connection you are using.
E.G. if you have connected the DVD to the AV 1 socket of the TV, make sure that the TV is set to channel AV 1.
Apr 29, 2008 | Televison & Video
DVD movies do not play
A blue screen means the TV is not receiving a video signal. Check all connections, then try another player, cable, etc. Also, check DVD and TV AV settings.
Dec 10, 2007 | Pioneer VSX-D912 Receiver
Can't connect DVD player
Use your TVs remote and select AV usisng the TV/AV button. Most DVD players use the AV Cables to connect to TVs.Yellow Video Out to Video IN of TV, REd and White Audio Left and Right to Audio L and Audio R IN of TV.
May 23, 2007 | GE 27GT622 27" TV
Power Outage - now DVD will not play through AV
I am having the same issue with mine. I even set everythign back to factory defaults and it still wil not work. Isn't there any tech support palced to find help? See post by Scriptster. Thanks
Jul 21, 2006 | Emerson SpongeBob SquarePants TV
TruTech PM1919BXA1 19 in. LCD TV Logo
18 people viewed this question
Top TruTech Televison & Video Experts
Radames Pagan
Radames Pagan
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
