Question about Dell E172FP 17" LCD Flat Panel Monitor
Dell monitor not working , green light blinks.
I have this thing completely dissembled and i need to know what the caps look like and where are they located on the board also is there a way to check there values .
  • toonsie Mar 28, 2008
    All the caps look fine. I was told that the things I should be checking are the 4 transistors.If they go bad the screen will not come on but the power light will continue to still blink green.Is it possible? I really need to prove to my wife that I can fix things!
  • 286 Answers
Capacitors look like cylinders mounted vertically on the pcb.
If you look at the printing on the board, there should be a label close to the capacitors such as C201, or XC330.
Usually a C in the label will indicate a capacitor.
They will be wrapped in a plastic jacket. The jacket will have writing on it, and usually a stripe down one side. The stripe indicates the negative lead (each cap will have two leads, negative and positive).
If the cap has a rounded top (domed) instead of a flat top, it is likely bad. You may even see that the component has split at the top, into four pie shaped wedges. This is also an indication of a bad cap. Lastly, the jacket is "heat shrunk" onto the metal cylinder. This usually causes the plastic jacket to overlap the top of the cylinder, which will show up as a donut shaped ring around the top of the cylinder. Some times if the cap is leaking, it will heat up causing the ring to shrink further so that the top of the cap will be completely exposed metal, with no plastic ring framing it. This also indicates a bad cap.
You can get the value from reading the print on the side of the cylinder. The values should be printed down the side of the cap, such as: 1000uF 16V, or 470uF 25V.
This is read as one thousand micro Farads at sixteen Volts, or four hundred seventy micro Farads at twenty five Volts (the u will actually be the Greek letter mu).
You will need a solder ****** to remove the solder from the caps on the solder side of the pcb (under $20), a soldering iron and some solder.
**** the solder after heating it with the iron, use the tip of the iron to carefully unbend the legs of the capacitors if needed.
Install the new caps making sure to observe the polarity. There will either be a mark in the board indicating where the negative lead should go, or a small + showing where the positive lead should go. Solder the leads and cut off the excess.
Make sure you get caps that are not larger physically than the originals or you may not be able to fit them into the same spot. (older capacitors are bigger than the same value newer capacitors).
Hopefully, you will only have three to six caps.
The lucky people will find only one bad cap, unlucky people will find up to ten bad caps, some in the power circuit, some in the inverter circuit, and some on the main board.
Caps on the main board can be very tough to remove. I recommend adding some solder to the legs of the caps you are going to remove, then heat one leg as you push the cap to the side to try and pull that leg out of the solder hole. Then heat the other leg and try to pull the cap completely off the pcb. Once done, you can use the solder ****** to clean the old solder out of the holes. This may be necessary because the main board is multilayer and these layers can act as a heat sink, making the solder harder to melt and harder for your solder ****** to remove. It's slightly easier once the capacitor legs have been removed.
Also note. Some manufacturers will use slightly larger caps, and in order to mount them they will bend the legs and glue the cap to the board on its side.
Posted on Mar 28, 2008
  • Mergatroid Jan 22, 2009
    You can check the transistors for shorts using an ohm meter. If you
    find one that is shorted, and if it is surface-mount it will be hard to
    replace without damaging the solder pads on the board.
    I use solder braid and a flux pen. Get all the solder off of the legs
    and the tab at the rear of the transistor. Then heat up the three legs
    using the brain to heat all three legs at once. Use a pair of needle
    nose pliers to carefully wiggle the transistor as you heat up the legs.
    If you're good and careful it will come off without damaging the solder
    It's pretty hard to find surfact-mount parts. You'll have to look into local electronics shops and part suppliers.
    If the transistors are not surface-mount, you can use a soldering iron
    and a solder remover (they're called solder suckers but this site will
    blank out the work ******). You should be able to get these transistors
    from a local parts supplier. Or, they should be able to provide you
    with an NTE or ECG substitute.
    Look for the transistors on the power board/inverter or if they are
    seperate just on the inverter board. They should be mounted close to
    the high voltage output transformers which should be the last component
    before the light connectors.
(montior)on light is blinking on and off NO picture
You can look at my pictures to see what is usually wrong with your DELL monitor:
Most of the time are due to bad caps, bad soldering works, shorted transisotrs, etc.
Replacement board:
May 19, 2010 | Dell E153FP 15" LCD Monitor
Can't get monitor to turn on
Dell has the same problem as BenQ since BenQ makes the monitor for Dell and HP. Please look through the Dell albums so you will know what to look for inside, bad transistors, caps, solder joints.
Apr 25, 2010 | BenQ FP91G+ 19" LCD Monitor
My Dell 1905FP LCD monitor Power light blink on startup
This is a classic symptom of filter capacitor failure on the power supply board. The Dell 1905FP and 1907FP both use the same power supply and this type of failure is very common. You can repair the unit by replacing the filter capacitors on the power supply board. Here is a picture of the board with the problem capacitors circled and below is a link to a repair guide for this series monitor.
I hope this helps,
Nov 14, 2009 | Dell UltraSharp 1905FP 19" LCD Monitor
Rapid green blinking green light on monitor and power & no video
try to acces the menu and to reset the display settings.
try another monitor on your computer to be sure that your video board is working, and if it is change the resolution in 1024X768 and try again your dell display
Oct 27, 2009 | Dell UltraSharp 2001FP 20.1" LCD Monitor
E173FP monitor fix
Depending on when you bought it. There should be at least a one year warranty. If its still under warranty have dell replace it.
Mar 25, 2009 | Dell E151FP 15" Flat Panel LCD Monitor
Dell 17'' flat panel monitor power light is blinking
some transistors on the board have shorted they supply power to the inverter to run the lamps, they power is not cut off intermittently and the protection circuit has stopped the monitor. the fix is here
goo dluck if you want it fixed for you let me know
Mar 22, 2009 | Dell E173FPf 17" TFT LCD Flat Panel...
My Dell Monitor on/off switch blinks green all of the time.
You need to open the monitor and check to se eif any of the capacitors on the power board are bad. Common problem for LCD monitors. The bad caps usually vent at the top (they will look bad compaired to a good capacitor).
If they look bad then they will need to be replaced. I've seen this in Dell monitors, so there's a good chance this will fix the monitor.
Take it apart, get the values on the sides of the bad caps in the power supply pcb. Buy new caps, and de-solder the old ones and replace them with the new ones. Don't forget to trim the leads afterwords.
Jan 01, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
17 in dell monitor
Please disconnect the Monitor Data cable from Computer.
If you see Dell Colored bars, it means, monitor is working fine,
If still black, please ask for replacement, since Monitors have 3 years of warranty if not purchased with the computer.
Now connect the cable back to computer and turn the computer off by holding the power button on computer and turn it back on...
Blinking Green shows that computer is in sleep mode......
Hope this should resolve the issue.
Nov 06, 2008 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Moniter won't turn on/power light blinks green
Yeah, I called Dell yesterday, and they said it was a problem that I could not fix myself. Whether that's true or not, I don't know, but my monitor was still under warranty, so they shipped me a replacement right away. I already got it this morning.
FYI: Their monitors carry a three year warranty.
Oct 28, 2008 | Dell E176FP 17" LCD Monitor
Dell E172FP 17" LCD Flat Panel Monitor Logo
271 people viewed this question
Alun Cox
