Question about Hoover U5450-900 Windtunnel Supreme Bagged Upright Vacuum
Belt replacement cant figure out how to put new belt on...old one broke....
    President:
  • 1,871 Answers
Hello :
1:Unplug your Hoover vacuum. Turn the vacuum up-side-down and place the motor and vacuum portion on a counter top with the handle hanging down toward the floor. This makes it easy to work on the underside of the vacuum portion of the machine.
2:Locate the two plastic release levers near the front wheels of the vacuum. On most machines you will only need to push these levers outward with your thumbs to release the bottom panel of the vacuum. On certain older models, there are two screws that will need to be removed with a screwdriver. Once released, remove the bottom plate.
3:Locate the drive belt. Unless the belt is broken completely, it will be plainly visible. One end of the belt loops around the shaft of the vacuum's motor and the other end wraps around the vacuum's beater bar. The belt is in a modified figure 8. Use your fingers to stretch the belt slightly and remove it from the small shaft of the motor which will be almost dead center under the vacuum.
4:Remove the roller (the beater bar) that is across the front edge of the vacuum. In most models you can remove the bar by simply pushing it forward slightly and then lifting it up out of the U groove that it is held in. In some models you may need to use your screwdriver to push aside two clips that hold the bar in place.
5:Remove the belt (if attached) from the bar and then clean the bar. The bar may have hair and bits of carpet wrapped tightly around it, especially at the ends where the accumulated mess could prevent the bar from spinning freely. Use scissors or a utility knife to carefully clean off all hair and other debris. Make certain that the roller rolls smoothly and easily.
6:Place the new belt around the roller, fitting it into the groove in the middle of the bar. Replace the bar in the machine. In most models, the bar should simply drop down into the U grooves that hold it. Give the belt half a twist (like the figure 8) and then loop the free end around the shaft of the motor.
7:Replace the bottom of the vacuum and push the retaining tabs back in place with your thumbs or screw in the two screws that hold the bottom on. Turn the machine over, plug it in, and it should be working like new.
Things You'll Need: Replacement belt Screwdriver (for some models) Scissors Utility knife
Warning:
1:If your machine makes a screeching noise when you turn it on, then turn it off and unplug it immediately. Turn it over and check to see that the bar is seated properly before turning it back on again.
2:Never work on your vacuum if it is plugged in.
I hope this will help .
please rate !
Posted on May 08, 2010
Why doesn't agitator turn?
Check the belt that spins the brushes. Sounds like it broke.
Apr 11, 2016 | Vacuums
New belt now harder to push than before
the new belt already snapped is what it sounds like try taking it into guarantee vacuum and sewing center
Mar 26, 2014 | Dirt Devil Featherlite Bagless Vacuum...
Vacuum power bar
By the power bar do you mean the roller at the front of the vacuum underneath, if so then what as more then likely happened is the belt has stretched and broke due to the bed sheet putting so much strain on the belt. You will need to replace this by getting a new belt for your make and model and switching off the vacuum and pulling the plug out of the wall first and then undoing all the screws which on most vacuums are underneath the head of the vac. once all the screws are taken out and the top as been taken off lift the roller out put the belt onto the spindle at the back and then place it around the roller and then pull towards the front of the vacuum to hook it back into place. This will be quite hard but it will do it and once on with your fingers push the roller around and few times to let it seat the belt into place and then build it all back up and start using it again. If you cant find out how to undo the head of the vacuum message me and I will try and let you know where each screw is to take out before you can replace the old belt with the new
Feb 02, 2014 | Eureka Vacuums
How do i replace the vacuum belt for a hoover upright, bagged, 18.0
go to manuals.com and put in the model Follow directions in the manuelUsually only requires a screwdriver
Feb 28, 2012 | Hoover Vacuums
Is there a manual for installing new drive belts on my LG Kompressor - we've had it for less than a month and the belt broke. I ordered 2 replacement belts and the new one doesn't work and the brush won't...
You've probably figured this out, but my luv200R had the same problem. The belt broke, I changed it and it still didn't spin the brushes. Turned out, the roller has bearings on either end and one of the bearings was bad and wasn't letting roller roll. So the pulley would spin against the belt and heat up and break it again. I took the bad roller to Sears where they had a new one sent to my house free of charge since it was less than a year old.
Mar 03, 2011 | LG LUV200R Bagless Upright Vacuum
The belt keeps breaking lately. I've had the
Before putting on the new belt make sure the brush turns freely and nothing is wraped around the bearing ends, if it is not turning free and is clean try a little grease or vasaline on the bearing ends. dont get any on the belt though. check the motor shaft also it should be clean and no residue from the old belts on it. it can be cleaned with rubbing alcohol and a rag, if really caked try a scotch pad .
Oct 24, 2009 | Kenmore Vacuums
The belt broke and after putting on new belt I dicscovered the cylinder with the brushes attached wasn't turning. After I finally got the cylinder to turn it makes a very very loud noise and also now it...
Check the cylinder with brushes does not have hair or carpet fibers causing it to bind. With the belt removed the brush should turn freely and fairly easy. The original belt probably broke because of this. You may have to fully dis-assemble the head of the vacuum to clean the entire brush assembly.
Sep 19, 2009 | Dirt Devil Vacuums
I cant get the power brush to work is there a reset button? the vacuum is only 2 months old dirt devil 12amp bagless featherlite
can you turn the brush by hand? if it turns real freely the belt is broke or the brush siezed up make sure there isn't any carpet strans wrapped around the ends of the brush otherwise the brush won't turn.if its the belt make sure you clean the motor shaft before you put on the new belt,the old rubber from the old belt will make the new belt run unevevly and break again..good luck
Apr 06, 2009 | Dirt Devil M085850 Featherlite Bagless...
MY VACUUM IS NOT PICKING UP
Hi This is quite complicated but I'll try and simplify this for you:
If this is a Panasonic upright then there are two drive belts as you know. Once you take off the sole plate (where the beater bar is) by undoing screws and the beater bar is looking at you, you would have to take off the smaller belt motor pulley first before putting on a new larger drive belt. If the smaller belt is still intact and you only need to replace the larger belt, you'll still have to take off both belts to put on the new drive belt.
Motor pulley belt has to be taken off first then the old drive belt, then grasp the beater and slide on new larger drive belt before having to attach the motor pulley belt and then the larger belt onto the motor pulley. Once all belts have been attached ensure that the beater bar is pushed in correctly before you screw the sole plate back on.
Apr 03, 2009 | Panasonic Vacuums
Dirt Devil Swivel Glide
look on the underside where the brush roller is and unplug it first then try to turn the brush roller by hand,if it turns real freely the belt is broke.you might have a clog at your intake hose at the bottom its the clear looking hose that goes from the bottom and comes up the back.if the belt is broke before you put a new one on clean the motor shaft there might be some old belt rubber on it ,otherwise the new belt won't last
Jan 03, 2009 | Dirt Devil Featherlight Bagless Upright...
Hoover U5450-900 Windtunnel Supreme Bagged Upright Vacuum Logo
468 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
