I have Acrobat 5.0 and an attachment in an email cannot be downloaded. I keep getting the message that the file is damaged. What can I do?
    Brigadier General:
  • 4,090 Answers
Firstly update acrobat to the latest version It may be that it does not recognise this file because it was written on an UPline version.
Also make sure you are not trying to load the new DIGITAL Acrobat file in the standard Acrobat.
The file may also be damaged from its source so try redownloading it again and reading it on another PC thyat has an uo tgo date reader
please rate my help++++Thanks for using FIXYA
Posted on May 07, 2010
Adobe acrobat reader
Try to download the file again or if it was sent to you via email, have the sender verify they can open the file & resend it. There are tools you can use to try to fix problems in PDF files, but they should be used as a last resort since they cannot fix all errors without data loss or corruption.
Sep 03, 2014 | Computers & Internet
Tip
Error "the application is being terminated because of memory corruption"
When you exit Acrobat 7, Acrobat returns the error message,"the application is being terminated because of memory corruption."
Solutions
Do one of the following solutions:
Solution 1: Install the Acrobat 7.0.8 update.
If you have Acrobat 7.0, choose Help > Check For Updates Now to install the update. Alternately, you can download the update from the Adobe website at www.adobe.com/downloads/ .
Solution 2: Remove the files from theAcrobat Organizer folder.
When you remove files from the Acrobat Organizer folder, you force Acrobat to rebuild the Organizer database. This process replaces any damaged files in the Organizer that may be causing the error message.
To remove the files from the Acrobat Organizer folder:
1.Choose Start > Run.
2.In the Open text box, type:%UserProfile%\Application Data\Adobe\Acrobat\7.0\Organizer70.
3.Delete or move all filesfrom this directory.
Solution3: Remove the files from the Updaterfolder.
You may receive this error message after a failed update, indicating that the files in the Updater folder are corrupted.
To remove the files from the Updater folder:
1. Choose Start > Run.
2. In the Open text box, type:%UserProfile%\Application Data\Adobe\Acrobat\7.0\Updater.
3. Delete or move all the files fromthis directory.
on Mar 20, 2010 | Adobe Acrobat 7.0 Professional
Why won't attachments open
There are a few reasons why the attachment might not open and appear correctly:
* You might have problems viewing an attachment if your browser is not properly configured to view that type of file. Usually, the easiest solution is to upgrade your browser to the most recent version:
Download the Firefox browser at:
http://www.mozilla.com/firefox/
Download the Internet Explorer browser at:
http://www.microsoft.com/windows/ie/down...
* If you're having trouble reading an Adobe PDF file, you'll need to install the Adobe Acrobat Reader, which allows you to open and read these types of files. For more information, visit:
http://www.adobe.com/products/acrobat
* You might also have problems viewing an attachment if it was sent in an unreadable "encoding type." When a message is sent, the sender might be able to choose an encoding type. If possible, the sender should use MIME encoding.
Nov 24, 2010 | Yahoo Mail
Adobe Reader could not open 'filename.pdf'" because it is either not a supported file type or because the file has been corrupted (for example, it was sent as an email attachment and wasn't correctly...
Help with PDF Documents Some documents on Maine.gov are provided in PDF format. In order to view or print PDF documents, you need the free Adobe Reader. Generally, you will find an alternative format is also provided for the document, such as Microsoft Word, HTML, or plain text. If you cannot access a document in PDF format and there is no alternative version, please contact the agency or contact the Maine.gov webmaster for assistance.
Adobe PDF-to-HTML Online Conversion Tool
We've provided solutions for some common PDF issues below.
General Tips: Problem 1: Blank Page in Browser You have selected to download a file and you receive a blank page with a "Done" message at the bottom of the browser. This may be because you do not have enough space in your temporary internet file folder to complete the download.
Solution: Internet Explorer: Tools> Internet Options> Temporary Internet Files> select Delete Files
Netscape: Edit> Preferences> Under Category on the left Advanced> Cache> click Clear Memory Cache
Problem 2: Blank Page "%PDF" You received an error message containing "% PDF" or you have received a blank page while trying to download. This is due to a problem with your web browser not opening .pdf documents correctly.
Solution: Adobe Acrobat Reader 5.0: Edit> Preferences> General> Options> Web Browser Options> make sure the Display PDF in Browser box is not checked.
Adobe Acrobat Reader 6.0 and newer: Edit > Preferences > Internet > make sure the Display PDF in Browser box is not checked.
Problem 3: "Error Locating Object Handler" You receive an error message that says "Error Locating Object Handler" while trying to download a document. This is because there is a dependency with a plug-in for Adobe Acrobat while using Internet Explorer.
Solution: Please go to the following website for detailed instructions: http://support.microsoft.com/default.aspx?scid=kb;EN-US;q262213
Problem 4: Unable to Print You have successfully downloaded the pdf, can view it on your computer screen but are unable to print. This is due to a post script error with your printer.
Solution: In any Acrobat Reader program: File > Print > check the Print As Image box > OK
Problem 5: "Adobe Reader could not open file" You received the error message "Adobe Reader could not open 'filename.pdf'" because it is either not a supported file type or because the file has been corrupted (for example, it was sent as an email attachment and wasn't correctly decoded).
Solution: Adobe Acrobat Reader 6.0: Edit> Preferences> Internet> make sure the Display PDF in Browser box is not checked.
Aug 26, 2010 | Computers & Internet
Is there any way to open an Acrobat 9 file with Adobe Reader 5?
Download the Adobe Reader 9 software. It's free from Adobe.
Mar 01, 2009 | Adobe Acrobat 6.0 for PC
I have Windows EX, and Lexmark All -In-One 2300. I have tried various ways and followed help suggestions but I am unable to make attachments. I cannot attach from SCAN or from File. Everything OK until...
It sounds like you are combining too problems into one. You can attach any file to an email. However if that file is a type that your computer is not aware of (ie. you don't have software that uses that kind of file) you will get a application association error.
Computers use the last three letters of the file name after the "." to determine the file type....it's also called an extension. This comes from the old DOS days and is still in effect today, (sort of). It's getting increasingly difficult to see the extension of a particular file in Vista for instance.
In any case if you want to scan an image and attach it to an email you must first get the scanned image in a file format that most computers can understand, for instance a .jpg format (JPEG) or .pdf (Adobe Acrobat). You can usually change the file type in your scanning software as an option. Perhaps a "Save As" function exists under a file menu?
Once you get the file in a folder (ie. "My Documents") you can then open your email software, create a new message and use the attach file button, select the file and it should attach.
Hope that was helpful,
Chris
Water Ionizers
Nov 29, 2008 | Lexmark Office Equipment & Supplies
Adobe Reader
It could be that you have an older version of Adobe Reader. You can download the latest version: CLICK HERE.
Jun 05, 2008 | Adobe Acrobat 6.0 for PC
Reading files
hi,uou can download the latest version of acrobat reader from this link
http://www.adobe.com/products/acrobat/readstep2.html
if you want the adobe 5 click this link
www.brothersoft.com/downloads/adobe-acrobat-reader-5.html
Dec 17, 2007 | Adobe Acrobat 6.0 Professional for PC
Opening downloads on emails
all you need to know is the file extension of the file you downloaded. there are some common file extensions when attaching to the email . pdf , doc, if pictures the JPG,PNG, BMP, and many more. however if u have an office application program (Microsoft office,open office) all office files will be opened but if the file extension is PDF you must download and install the PDF reader. you can download it here http://www.adobe.com/products/acrobat/readstep2.html.
Take note! Any other files which you don't whose the sender and the extension files is not on office application program not pdf or picture files maybe can harm your system so be sure to know the files.
Dec 11, 2007 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
