Question about Sloan M-101526-F42 Flushmate?® Complete Replacement System for FM IV 504
Sloan Unit. Water from supply line does not come into the unit.The tank never fills up. Is it clogged. How do I check it?
  • 349 Answers
Http://www.flushmaterepairparts.com/troubleshooting#b
Check this web site out for removing parts.
Posted on Jun 11, 2010
Ice machine won't fill with water
Make water supply is on if you have a water filter in place it may be clogged or if unit has a float valve youmay has trash in the line clogging it up
Apr 02, 2014 | Ice-O-Matic ICEU220HA Undercounter Ice...
We are an info Center for a community. The pool company came out yesterday & cleaned the pool using most of the water pressure. since they left the toilet will not flush. is there an easy fix to...
Believe it when I say the pool is not connected to the toilet.
You are not clear as to what actually happened, I presume the pool company came in and attached a hi-pressure cleaning device to your water supply. As such, they were definitely using your fresh water supply which should not have made much difference on the pressure. You say it did, ok. When the pressure went down in your water line, there is that possibility that the toilet would not fill as fast as when full pressure is available but that should only be a matter of minutes not hours, particularly if your toilet is a tank type.
You say you are in a community center, I must presume you have at least a one inch water line into your building and probably much larger, you may have a tankless toilet with a meter valve ("Sloan") on it - meaning you have enough water in your water system to support a direct flush and do not require a tank.
It could be that scale inside your pipes was disturbed by the high flow of water and the scale found its way to your "Sloan" valve, blocking the flow of water. To check this, turn off the water supply to the toilet, remove the top of the valve and clean it. Reassemble and turn the water back on.
I hope this works for you ... thanks for your quesiton @ FixYa.com
Mar 23, 2011 | Toto MS950CG01 Cotton Neorest One-Piece...
Water comes in but will not go out
If I understand correctly, you opened the drain valve on water heater and saw that drain valve has water flow just like turning on a water spigot.
http://waterheatertimer.org/Water-heater-will-not-drain.html
Take apart the hot water pipe on top of heater and inspect outlet nipple for sediment clog.
You may have to replace hot water nipple or other pipes above water heater.
You can take apart pipes and test pressure using pressure gauge:
http://waterheatertimer.org/images/Pressure-gauge.jpg
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 10, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
I have a Maytag side by side w/ ice and water dispencer. Have been having intermittent problems with unit not dispencing water and not making ice(water not filling in to ice tray)unit is now making ice but...
YOU COULD HAVE A BAD WATER VALVE OR YOUR TANK IS CLOGGED UP AND STOPPING THE WATER FLOW THROUGH THE LINES. MOST MODELS HAVE A TANK IN THE BACK OF THE SHELVES ON THE REFRIGERATOR SIDE DOWN AT THE BOTTOM. IT WILL BE LOCATED BEHIND A PANEL YOU WOULD HAVE TO REMOVE SHELVES AND SCREWS TO GET TO IT BUT FIRST CHECK VALVE SOME SYSTEMS HAVE MULTI VALVES WHERE ON CONTROLS THE ICE MAKER AND THE OTHER ON THE DISPENSER.
Dec 17, 2010 | Maytag MSD2756G Side by Side Refrigerator
No water will enter the dishwasher, There is no problem with the water supply or the supply line. The water flows from the supply line to the dishwasher connector but does not enter the dishwasher.
The water-inlet valve lets water enter the machine. Make sure it's not clogged. There is a screen on the inside of the valve, this sometimes gets clogged up with debris. Check to see if you get power to valve when unit is put into operation may take a couple minutes to start a fill. If you have power and it's not clogged up replace the valve .If you have no power to the water inlet valve check float switch. This can be done by checking the continuity. Here is a video checking the water inlet valve and the float switch. It may be a different model but the testing procedure will be the same. You can also enter your model # for diagrams and illustrations for most models. All parts come with installation instructions.
Nov 23, 2010 | KitchenAid Dishwashers
Water slowly coming out of dispenser
Is this a new Unit or a second hand unit? If it is not new... most likely there is debris in the water valve inlet or the actual saddle valve / faucett connection to the refrigerator water supply line is partially blocked.
Without a Model number to ensure the exact parts inside the unit for you to check is a bit of a problem.
Most of the water valves are the same and an example of yours would be item 10 of this link: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5132635&diagram_id=945271#d945271
detailed view: http://www.appliancepartspros.com/part_details.aspx?part_id=3160649
- What I recommend you do is disconnect the water supply line on the back of the unit and check 16 oz. of water flow at the end of the supply line. Water OFF before disconnecting the supply line.
- IF the water flow is the same as through the door you will need to find out why there is not enough flow from the water supply source.
- Additionally IF you have a water filter installed external to the unit... it can be clogged or full of sediment and need to be changed.
- If you discover that the water supply is of good quantity and pressure there is also the possibility of a pinched or kinked plastic water line some where inside the refrigerator.
- Sometimes the hose that passes through the door hinge flattens out and restricts water flow.
Thanks for using FixYa.
Kelly
Jul 10, 2010 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
Sloan Flushmate M-101526-F3-Constant Filling
There is a lifetime warranty on the tank and a ten year warranty on parts. Call flushmate and ask. they will not tell you otherwise.
If you use any chemicals in the tank it will void the warranty.
Sep 25, 2009 | Sloan M-101526-F42 Flushmate?® Complete...
WATER LEAKING FROM UNDER THE WASHING MACHINE
follow the hose from where it connects into the washer.. take off that panel and pinpoint leak. more than likely a hose is unattached
Apr 15, 2009 | GE WWSE5200B Top Load Washer
Ruud UBHC17J11NFA: Condensate pan filling up - condensate pump works fine
blow out the drain line from the coil to the pump the clog is there causing the pan to fill up and trip off
Apr 28, 2008 | Ruud UBHC Air Conditioner
Sloan M-101526-F42 Flushmate?® Complete Replacement System for FM IV 504 Logo
195 people viewed this question
Top Sloan Home Experts
richochet
Andrew Taylor
Andrew Taylor
frankdanfelt
Are you a Sloan Home Expert? Answer questions, earn points and help others
