Question about Sony KP-51HW40 51" Rear Projection Television
I have a sony projection tv kds-55a3000 the green light blinks with 2 short buzzes and the tv dont turn on but the fan starts to run.
    Brigadier General:
  • 4,090 Answers
Straightv from the SONY service manual
  • 2 times, Diagnosis: B overcurrent (OCP). Possible causes: H. OUT (Q8024) is shorted. (D board), +B PWM (Q8035, 8038) is shorted. (D board) Symptoms of the problem: Power does not come on, Load on power line is shorted.
  • This is not DIY stuff and is dangerous to play around with. I suggest you get a tech to fix it rather than opening it up and doing it yourself. Also dont keep turning it on in the hope it will start. It is more likely to start a fire if it begins to overheat from being constantly started and left plugged in.UNPLUG it
    Please rate my help++++Thanks for using FIXYA
    Posted on May 07, 2010
    Sony kds 55a3000 sound but no picture
    I hate to say it but maybe the new lamp is bad.
    Dec 07, 2012 | Sony KDS-55A3000 55" HDTV
    Green power light blinks, and TV comes on, and goes out, and power light goes red
    Sounds like a problem with the power supply. After it shuts off do any other lights blink, apart from power LED turning red? Please provide this info as it is a self-diagnostic code that will help identify the problem.
    Sep 16, 2011 | Sony KDS-55A3000 55" HDTV
    Sony Bravia KDS-55A3000 while watching last night screen went black as if someone turned the TV off when attempting to turn it back on the the power indicator light flashes green repeatedly stops then a...
    It sounds like the lamp has failed. It is advisable to use a genuine Sony lamp. The part number for is XL-5200. It will cost around 180.00. That should fix you problem. If you cannot find the lamp local to you can order it form Sony at.
    1800-222-SONY
    I hope this help,
    Skyassoc
    Dec 15, 2010 | Sony KDS-55A3000 55" HDTV
    When I turn on the TV the green start up light blinks green and the TV comes on with picture and sound for about 2 seconds, then turns itself off and the code light blinks 4 times, pauses then blinks 4...
    4 times blinking means Fan stopped, power is not supplied on Fan 1, Fan 2 Fan 3 and at Fan 4. Or Fan connector is not attached securely. Cleaning these fans by using a vacuum cleaner can also solve your problem. Sometimes these fans are clogged by dust.
    Oct 24, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
    Power button goes from green to red then lamp button blinks no picture or sound
    Lamp in tv is dead and need to be replaced to get tv back in action.
    Lamp replacement procedure is easy and would be written in user manual.
    Please buy Sony original lamp to get bright picture in tv.
    Thanks.
    Jul 08, 2010 | Sony KDS-55A3000 55" HDTV
    TV doesn't turn on
    If it does not give a picture at all not even for a moment, i would suspect a bad power supply, the circuit has quite a few components and either one of those could be giving you trouble.
    Sep 24, 2009 | Sony KDS-55A3000 55" HDTV
    Sony kds-r50xbr1 turns itself off and then green light blinks 52
    I too have a Sony KDS-R60XBR1 tv and the issue that you are experiencing is due to one of your fans in the rear of the tv is not working.  The tv automatically shuts off in protective mode.  Make sure the POWER/STANDBY light is blinking and not the lamp light below it.  Is the power/standby blinking 4 times in red? If, yes then its a fan that needs to be replaced.  If its the lamp light blinking then you need to replace the lamp.  The lamp is easy to replace by ordering the lamp either from Sony for $250 or find it cheaper for approx. $150 from other DLP sources and replace youself by following your manual.  I hope this helps you.
    Apr 22, 2009 | Sony KDS-R50XBR1 50" HDTV
    KDS-R60XBR1 Sony Projection SXRD Power Issue?
    how many times does it blink pause then blink again?
    Dec 01, 2007 | Sony KP-41T65 41" Rear Projection...
    Sony KP-51HW40 51" Rear Projection Television Logo
    52 people viewed this question
    Top Sony Televison & Video Experts
    Jerry Greenberg
    Jerry Greenberg
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
