Question about GE GSH25JSTSS Stainless Steel Side by Side Refrigerator
GE GSH25JSTASS water and ice maker not working
I have a GE GSH25JSTASS and the water is not working and it is not making ice. The green light on the icemaker is blinking. I have checked the line and water is is going into the fri. I tried turning the icc maker off and then back on, but no joy.
  • 797 Answers
I had the same problem.
I found that the inlet tube was frozen over as was the drain on the reservoir that fills the ice tray. Clearing the ice build up did not fix the problem. I also noticed that the ice maker seemed to be half filled.
I found that the valve is working by wiring a line cord directly to the valve. This caused the ice maker to fill (overfill actually since there was no sensor to turn it off).
Allowing the ice maker to cycle now that if was filled has solved the problem. The only thing I can think of was a power failure or manually turning off the ice maker while it was filling.
If you are capable of manually testing the inlet valve as above and it does not fill the ice maker, then the valve is defective. Cost is below $50 as this posting. Part number is AP3192626.
If the valve works and it is not a partial fill problem as was mine, then the problem is with the main circuit board on the back of the fridge. The part number is AP4436216 and ranges from $122to $140 as of this posting date.
Posted on May 01, 2011
I have GE Monogram Side by Side. Purchased back in August 2006. It has been pretty good except for the ice maker. After the first year a leak ruined our new wood floors. Recently the ice maker has...
The green light flashing is a fault code, usually for a no, or long fill situation, GE has nixed this electronic ice maker and returned to one that looks similar but is non electronic, while your ice maker is probably at fault you may actually have a separate issue causing the ice maker to display a fault code, such as a spent water filter, or low water pressure, or even a bad water valve on the fridge it's self. IM6 is the current replacement ice maker kit for previous ice makers. Pleazer Appliance...
Apr 17, 2014 | GE Monogram Side by Side Refrigerator
No water to the ice maker
Check that the pipe that fills the ice maker is not iced up. Also check that the solenoid on the back (where the waterline hooks up) is making a humming noise when the ice maker calls for water.
Apr 30, 2010 | GE GSH22SGRSS Side by Side Refrigerator
Ice maker in our GE profile refrigerator is not working
Ice maker Diagnostic Test:
- Remove the ice bucket
-Turn the ice maker off, wait 15 seconds than turn it back on
-Press the ice paddle three times, this will begin diagnostic test.
-PLEASE DO NOT TOUCH ICE MAKER DURING DIAGNOSTICS
-In 3 minutes you should see the rack inside turn 360 degrees
-AND the ice maker bowl should fill with water
-IF either DID NOT work, call 1-800-GE-CARES for ice maker replacement. A service call is approx $80. The $80 will be deducted from the part/labor if you choose to purchase/install parts from the service technician. If not, you will pay for the service call. Good luck.
Nov 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker will not make ice
Make sure the ice maker is turned on ( green light ?) . Pour about 2/3 cup of water into ice maker . If it freezes and dumps the cubes , but doesn't fill with water , replace the dual water inlet valve ( one coil for water dispensor , the other is for the ice maker ) . If it does not dump the frozen cubes , then replace the ice maker .
Sep 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
No Water to Ice Dispenser
Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker. Also make sure the coils are clean of dust , lint , etc...
Aug 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker not working
you need to check the inlet screen on the solenoid down below for blockage, also make sure that the freexer is cold enough
Dec 26, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
GE Refrigerator, model PSS26MGPBBB, stop making ice. Water dispensor works fine. Green light on ice maker is blinking. Have tried recycling power to ice maker no change. Have check to see if...
PROBLEM IS ASSOCIATED WITH THE TEMP SENSOR INSIDE ICE MAKER. I HAVE TRIED TO FIND THE PART, BUT WITH NO LUCK. IT LOOKS LIKE WE WILL HAVE TO PURCHASE A NEW ICE MAKER.
Aug 25, 2008 | Refrigerators
Ice Maker Problem
my ice maker stopped making ice. Green light is on. Drinking water is ok
Feb 17, 2008 | GE GSS20IEP Side by Side Refrigerator
GE GSS25LGM Ice maker
one of the valves could be open circuit. ice build up where the pipe enters the cabinet or sadly if not that then the complete ice maker. hope this helps
Feb 11, 2008 | GE GSS25LGM Side by Side Refrigerator
GE GSH25JSTSS Stainless Steel Side by Side Refrigerator Logo
495 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
