Question about Kwikset Powerbolt/Electronic Deadbolt- Polished Brass
How do you delete existing codes to put in a new code?
    Brigadier General:
  • 4,090 Answers
You dont need to delete them they are replaced whern you enter a new code.
SET ..BTN and object TV1 or VCR1 etc light becomes steady on remote Enter code eg: 291 light goes out PRESS SET and try.
Please rate my help++++Thanks for using FIXYA
Posted on May 07, 2010
My craftsman garage door opener learn receiver will no longer record codes for remotes or keypad.the LED by the learn button flashes slowly all the time
I would suggest deleting all existing codes and trying to reprogram. If all remotes were previously working and stopped at the same time, your circuit board is probably broken.
To delete all existing codes hold the learn button on the opener, you will see that blinking light go solid, continue to hold it until the light disappears and all of the existing codes will be deleted.
If you are still unable to program your remotes if your opener is less then 10 years old, it might be worth replacing the circuit board. But if its any older it might be more beneficial to move to a new opener.
Feb 26, 2018 | Building Materials
Mother just past away,luckily safe was open at time,but dont know combo to keypad or we haven't found a key,how do i reset code to sentry10 gunsafe
To reset the combination on a Sentry safe, open the door of the safe, delete the existing codes, press the PROG or P key and enter the factory code. Finally, enter a new five-digit number as per individual preference, which is the new user combination.
It is always prudent to reset the combination on a Sentry safe when the door is open because it prevents the user from being locked out. To open the Sentry safe door, type the five-digit factory code given in the owner's manual. This factory code cannot be altered.
To delete the existing codes on newer models of the safe as of 2015, press the P button. Then, type the factory code and follow it up by inputting "00000" into the safe. On older models of the Sentry safe, press the PROG button and type the factory code two times.
After deleting the existing codes, press the PROG or P key and then enter the factory code once again. Within five seconds, type a new five-digit number, which is the new user code. To verify if the user code is working, retype it and then close the door of the safe. The user code is the primary code for opening the safe, and users can reset it as often as they want too
Mar 21, 2017 | We Home Security
Why is my activation code not being accepted by mcafee. due for renewal
the code you are trying to put in should be only for the new program
old codes will not work for new programs
next , with most security programs you have to uninstall the existing program then install the new one and then put in the code
call mcfee help desk for assistance
May 08, 2016 | Mcafee 2009 Internet Security - 3 User...
Activation code
Ithe messages come through & I can send txts okay just can't find where to delete txts
Dec 27, 2013 | Cell Phones
I have a Defiant Electronic deadbolt from home Depot. model G1X2D01. ive lost the manual and i need to delete some old codes from it.
Snap off the back cover (opposite where you punch the numbers) by pinching the sides and pulling off. Do not press a pen or anything into the small light, you do not need too. Just pinch and yank off cover. You will see a small light and beside it is a small SET button by the batteries, it is labelled.. Press this Set button for 2 seconds. The red LED will light on the front code side and beep twice to indicate you are in programming mode. Enter your current code that you want to change (factory set is 12345) and then press the button that looks like a little lock on the keypad. Enter the digits "10" and press the lock button again. Enter the new code (must be six digits) and then press the lock button again. The red light should go on continously for 10 seconds. The code should be effective.
Note: if you have problems like we did, you can also remove one battery and press the "set" button simulataneously when you reinsert the battery. This resets the factory code of 12345. Then you can start over. For some reason our old code was only 4 digits, but it would not let us reprogram a 4 digit code. It didn't work until we did a 6 digit new code.
Apr 15, 2012 | Locks & Locksmithing
Security code
the default security code for nokia phones must be 12345. u need to enter the default code first to change it to new code.
Dec 01, 2011 | Nokia C3 Cell Phone
How do I clear (erase) all codes from my Weiser Powerbolt 1000 in order to start with fresh entries? Adding new codes does NOT override/delete old existing codes as page 7 of my manual indicates. I now...
How do I change the access code (and delete my old code) on my Powerbolt 1000?
The steps below are to change your access code to a new code. This will also remove any previous codes stored in the Powerbolt's memory.
  1. Manually put the bolt in the extended (lock) position. Press the PROGRAM button once, enter your new 4 - 8 digit code and then press the LOCK button.
  2. Press the PROGRAM button twice, enter the same new code and then press the LOCK button once.
  3. Press the PROGRAM button three times, enter the same new code and then press LOCK once.
If your old code still remains in the unit, you will need to perform a hard reset of the unit. To perform a hard reset of the unit, remove all four batteries and leave them out for 1 hour. After the hour has passed, you may re-enter the batteries.
United States of America Customer Service Contact Information
Call Us Toll Free: 800-422-4278 (Mon-Fri, 6:00am - 4:30pm PST)
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
Good luck, Elizabeth!
Jul 26, 2011 | Weiser Lock Powerbolt 1000 Lock
Code for nokia 6303i / parrot ck3100
code is 1234 but you may need to delete any existing devices from the settings menu on the parrot before it will allow new connections.
Jun 19, 2010 | Parrot SA Parrot Ck3100 Lcd Handsfree...
Panasonic KX-T7633 - cannot change time
It has a password and it does exist. One that absolutely works is **1234. You could try those same digits in your login, but there's no guarantee. It also is only good at the phone wired to jack one unless the installer set it up in class of service.
Carl
Mar 24, 2009 | Panasonic KX-T7633 Corded Phone
Kwikset Powerbolt/Electronic Deadbolt- Polished Brass Logo
270 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
Steve Masymas
Level 1 Expert
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
