Have an f35 error code - Washing Machines
  • shnchome May 09, 2010
    all of those things have been done, I cant say whether or not it is plugged on the tub side of the hose but the hose itself is clear.
    where is the airtrap?
    President:
  • 949 Answers
Here is what the manufacture says about F35 followed by my comments:
ANALOG PRESSURE SENSOR FAILURE
If this failure is displayed, the Central Control Unit has detected a malfunction of the analog pressure sensor.
Possible Causes/Procedure
1. Check if pressure hose is fixed correctly and without holes or damage.
2. Make sure that the airtrap is not blocked.
3. Make sure that the hose is not blocked and no water
is inside.
If you are using the wrong type of soap or too much and see lots of suds in the washer you can get this error.
The pressure switch tubing that this is talking about is accessible from the top and back, the pressure switch is mounted just under the top near the right rear corner, it is round with a black hose attached. Make sure that hose is clear and not kinked.
Posted on May 07, 2010
  • Philip May 09, 2010
    The air trap is at bottom end of the pressure switch tubing (black hose)
What is the solution of error35 in w455h washing machine
Hi! If you mean error F35, this error code indicates an analog pressure sensor error. This sensor is the component that detects water level in the washer tub.
F35 error code can be caused by a problem with the air pressure tube between the bottom of the washer tub and the analog pressure sensor.
Apr 27, 2017 | Washing Machines
What is an F35 code?
The F35 error code is indicating the analog pressure sensor switch is either bad or blocked. Go to managemylife.com and put in F35 error code to see location and description of part.
Feb 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Code F35
hello
what The F35 error code indicates that the water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F)
The f35 error shows you and indication that ice maker sensor readings are out of normal range.
then what you need to do to fix up the problem is to bale out the water from it then clean up all form of water ant dry you can see from the screen
Please before you can carry out this instruction you will have to put OFF all source of power supply .
thank you and good luck.
Jun 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Code f35 and sud on washer machine/whirlpool duet front loader
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^^^^
May 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code washing is delayed wil wash half the clothes
Mar 06, 2010 | Whirlpool GHW9300 Duet Washer
F35 message, will not run through cycle. Starts to and then the F35 starts flashing and eventually shuts off.
Check between door boot seal and drain hose in basket. If this is clogged with lint or sock, towel it will code f35 or sud
Oct 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Steam washer
HELLO.F35 IS A ERROR CODE WHICH NEEDS THE ASSISTANCE OF A WHILPOOL SERVICE AGENT.THE CONTROL BOARD MIGHT NEED TO BE REPROGRAMED BEFOR YOU CONSIDER REPLACING IT.GOODLUCK.MOHAMED
Sep 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Error code f35
konica f 35 eror code
Aug 06, 2008 | Office Equipment & Supplies
Washing Machines Logo
Top Washing Machines Experts
