Question about Philips 60PP9352 60" Rear Projection Television
60pp9352 convergence ic replaced multi points corrected but image squeezed
Hi
I have a 60pp9352 I replaced the convergence ic chips didn't see any resistors blown. fixed multi points but now colors are fine but the image is squeezed on the screen like a bowing on all four sides..
  • 6 more comments
  • gore308 Mar 27, 2008
    thank you I'll check them out
  • gore308 Mar 28, 2008
    Hi
    I checked the resistors around the board with the Ic chips. the the 6.8 ohm resistors were ALL giving me a reading of 2 ohm on my multimeter I had it set to X10 I did't take a leg out of the circuit I touched the probes to opposit sides if the resistors. do you think I shoudl change all of them?
    seem like alot work to check . do you recomend a good place to start example the ones cloest to the IC chip?
    also do you know the volts on these?
    thank you
    thanks again I appreicate it.
  • gore308 Mar 29, 2008
    Ok
    it is the 30 ohm's that are bad they only sell 33ohm in my area
    Can I use those instead?
    2 15 ohm ?is that just tieing them togeather or do I have make asome type of bridge.
    thanks again
  • Anonymous Mar 20, 2014
    need a video to see how to replace part
  • Philips Master
  • 8,617 Answers
One of the resistors must be open, you cant always tell by looking if theyre open you have to remove one leg out of circuit then test them for resistance they can only be 5% out of tolerance, any more than that and they must be replaced.
Posted on Mar 27, 2008
  • 3 more comments
  • Sonny Berry
    Sonny Berry Mar 27, 2008
    Let me know if you need any further assistance with your set.
  • Sonny Berry
    Sonny Berry Mar 28, 2008
    you will have to remove 1 leg of the resistor out of circuit to check them so you are not getting a reading from the resistance in the circuit. Cause even a blown resistor can register resistance in circuit.
  • Sonny Berry
    Just check the 6.8 ohm resistors next to the ICs those are the ones that will affect the convergence.
  • Sonny Berry
    Sonny Berry Mar 29, 2008
    No use only a 30ohm resistor, However if you cant find a 30ohm you can use 2 15ohm and hook them together in series. or 3 10 ohms in series any combination to arrive at 30 ohm. A 33 ohm will only burn another componnent .
  • Sonny Berry
    they have to be hooked in series to add up the values. Just hook them end to end in line like a string.
Double image, red is 2 inches off main image. convergance ic amp?
Yes, your Convergence ICs have failed. Replace the STK chips, check fuses and the resistors next to the STK chips. Replace as necessary and re-align via the service menu.
Feb 20, 2011 | Hitachi 43UWX10B 43" Rear Projection...
I have a panasonic PT-47wxc43 projection tv. I have green and purple halos coming up from the bottom. The screen has purple and green double images which are worse from the bottom up.
This problem is due to convergence output ICs failure and both chips will be replaced to fix the issue.
There are two big black ICs installed with aluminum heat sink on deflection board, these are convergence output ICs and will be replaced to correct the problem, it is common problem of rear projection tv.
Below image of deflection shows ICs (marked in red) that are need to be replaced.
IC number is STK392-110 and available with Part Store for $32 each.
Click above link to see an image of IC.
If you are handy with electronics stuff repair and can replace parts in tv circuit board then can replace these parts yourself or ask local tech to help you.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
May 25, 2010 | Panasonic PT-47WXC43 47" Rear Projection...
Multi- color bands - twisting wave pattern cross the middle of screen and can not get image to lock -flickers both horizonal andf vertical. Would this be the same 2 IC chips- last time i had this problem...
Ur tv have convergence problems,it dead.U must have soldering tools,solders and know how to solders to fix convergence problems.U must replaced 2 STk convergence ICS,and some or all it resistors.Tries websites Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost U $300-$350 for parts and labors.
May 11, 2010 | Toshiba 50H72 50" Rear Projection...
Color blur
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Feb 11, 2009 | Philips 60PP9352 60" Rear Projection...
60PP9352-17-Philips Magnavox Problem-PLEASE HELP! Hello, We are going to as explanatory as possible... Model: Philips-Magnavox (60PP9352-17 / DPTV310) Problem: HDTV turns on and you can watch it, however,...
Start with replacing Both of your convergence ICs they are big black ics STK will have Part # on them this should solve your problems, Parts call 1-800-223-3205 www.electronix.com You can also order on CD Service Manual #7621 and 7541 Call 1-800-221-5681. Thank You and Have A Nice Day.
Jan 03, 2009 | Philips 60PP9352 60" Rear Projection...
51MP392H/17 Blue convergence wont move not IC chip
You could have some opened resistors low ohms that are bad go back and ck them around convergence ics.
Nov 20, 2008 | Akai PT4298HD Rear Projection Television
Convergence problem with Philips 60PP9352
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when when using the convergence menu.
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself. Its an easy fix.
Oct 01, 2008 | Philips 60PP9352 60" Rear Projection...
60PP9352 60 in. Rear - Blue convergence issue
Replacing only the ICs MAY solve the problem, however, many people have also had blown resistors requiring replacement. Also the convergence board should be checked for cracked solder. If you replace the ICs and the resistors are shot, the ICs may blow again almost immediately, meaning you may have to do the repair twice.
You do not have to replace any transistors to fix this convergence failure.
May 28, 2008 | Philips 60PP9352 60" Rear Projection...
Picture crooked. skewed torwards bottom right corner.
replace convergance IC
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Dec 11, 2007 | Philips 60PP9352 60" Rear Projection...
Philips 60PP9352 60" Rear Projection Television Logo
90 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
