I have a Philips DVD player and am trying to run the cable for the tv through that is that possible?All I have on the back in a av plug for the coax (my coax for my cable is just the normal kind that screws on)
    Brigadier General:
  • 4,090 Answers
You can buy a converter for this or have it cut off and replaced with the correct plug to suit your player
please rate my help++++Thanks for using FIXYA
Posted on May 07, 2010
Combo VCR/DVD player has no cable connection on back> How do I hook it up, through adigital box, to an older TV with one set of white, yellow and red connections?
What outputs are available on the digital box? If you have composite out (AV), then you connect the yellow (video), red and white (audio) to the VCR composite IN on the DVD player. Then connect the composite out from the DVD player to the TV. You will need an extra RCA composite cable. If you need one, they can be found in most stores. (try an online shop that specializes in cables to avoid an outrageous price). The VCR In is to the Right of the DVD/VCR Out.
If the incoming cable is only available with a coax connection, you will need a set top box and a coax splitter. Connect the incoming coax to the input of the splitter. Then connect one coax cable to the TV antenna/cable in. Connect the other to the set top box and then connect the composite output of the set top box to the VCR composite IN.
The manual and the quick start guide are available as PDFs here: http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?slg=en&scy=us&ctn=DVP3345VB/F7 . For diagrams of the connection to a cable or other set top box see the FAQs on the right hand side of the page.
If your cable box has some other output, you will need an appropriate converter to go from component to composite video for example.
I hope this helps.
Apr 22, 2011 | Philips DVP3345VB/F7 DVD Player/VCR
How do i hook up a dvd player to my tv if i have cox cable? I dont know what channel to put my tv on. I know there has to be a way to watch a dvd without unhiiking the cable
Most DVD players have a coax input and output on them. But some newer ones don't. Assuming your does then you can run your DVD player to your TV with a coax cable you bet. Either on the back of the DVD player there will be a little switch or in the menu settings it will give you an option for channel 3 or channel 4. The same channel you select on the DVD player will be the same channel you will want to put your TV on. For the coax install run it from the output on your DVD player to the coax input on your TV. If you use a coax for cable too then just run you coax from the output on your cable box to the input on your DVD player.
Mar 20, 2011 | Samsung Televison & Video
Hooking a magnavox vcr dvd player to a tv
You need what they call an "RF Modulator". They are about 25$. Here is a link to one...
http://www.radioshack.com/product/index.jsp?productId=2103095
Jul 08, 2010 | Philips Magnavox DVD/VCR Dual Player
I got a free tv from a hotel, it has no remote. Can I use a universal remote to add channels to the tv? It only goes to channel 69. Also, can I plug in a dvd player? I can't find anywhere on the tv to plug...
Often these commercial TV's are just vanilla types catering for TV alone. The43 cable channel is possibly the only other alternative that is a money maker for the motel/hotel. They try and prevent people from connecting their own DVD players to their equipment so they are the ones who make the $$.
It is possible to use a Universal remote providing it is capable of being controlled by a remote.
Philips code is 0054 , you can only try!
Please rate my help++++Thanks for using FIXYA
Nov 21, 2009 | Philips Magnavox 27MS343S 27" TV
Have magnavox dvd recorder record direcTV DVR programs w/ hdtv
I am unfamiliar with this unit.
If you have scart connecters on both, connect av2 on the tv to av in on the recorder. set the recorder to record from av source.
You should now record a program, I think the static is the fact that composite is out from the dvd only, not an input, and in on the tv, not an output.
Sep 04, 2009 | Philips Magnavox MWR10D6 DVD Recorder
There has got to be a way
I have this model..was trying to hook it up to a directv hughes receiver. After a day of trying and many curse words I found that using this hookup works . Hook up your satellite connection to you tv as usual...Now plug rca cables(red, yellow white) into the corresponding holes on the BACK of the Directv receiver ..now plug the rca cables into the FRONT of the Magnavox player...you will only use find holes for the white and yellow(that's ok) Now hook up up the dvd player to the tv using the rca connection back of dvd/vcr player..or if your tv only has a coax connection you will need a rf modulator available at walmart etc. You will run the dvd/vcr on L2. The key is the connections to the FRONT of the dvd/vcr player..I hope this helps..:)
Aug 03, 2009 | Philips Magnavox DVD/VCR Dual Player
Connect older analog Tv to new AV DVD player
buy an rf modulator it converts the av to coax.
Jan 31, 2009 | Televison & Video
Connecting the dvd player and the vcr to the tv
On the DVD player you hook the red/white and yellow cords from the DVD to one of the inputs on the back of the TV colored the same. Provided you have another RCA jack input on the tv you can connect this the same way. If not and you have a cable connection or satellite just run the coax into the input on the VCR and run a coax off the output on the VCR and run the other end into the TV. I hope this is of assistance to you.
Oct 20, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Cable/ant. hook-up
If you have a yellow/white jack on your DVD/VCR unit you can connect it to the TV using composite cables. If you only have the coax output on the DVD player you can buy an RF modulator that will convert the coax to composite also. But if you have two ports on thhe DVD player as most combos do the top is usually an input source such as cable and the bottom is the output that goes to the back of the tv. You could also buy a "splitter" and attach the cable and dvd coaxs to each of the out ports(they will be side by side) and on the opposite end, which is the in run a coax from that port to the tv coax port.
I hope this helps you out. If you need assistance you can visit me on the chat portion of this website.
Sep 09, 2008 | Philips Magnavox DVD/VCR Dual Player
Philips dvdr3575h/37 Initial setup
Do you have two cable inputs going into your player?
May 01, 2008 | Philips DVDR3575H/37
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Electro Med Services...
