Question about Denon AVR-1804 Receiver
Denon avr 1804 you turn it on and in seconds it turns off the stand by light is blinking
2 Suggested Answers
SOURCE: Denon avr-1804 its turns back after 5 sec
Disconnect all speaker wires on back and then turn on. If it happens again, it's most likely a power supply problem. If it doesn't happen again, it was probably crossed speaker wires.
Posted on Dec 28, 2009
Denon avr-1804 no power
Mr Paul.. Thanks ur valuable information . I got a unit and it had one power transistor gone. even after replace not work but I follow ur instruction done. Appriciate.
Apr 04, 2014 | Denon AVR-1804 Receiver
Zone 2 on my Denon AVR 1804 only works with an analog input. Apparently it was designed that way. WHY?
Because in order to use a digital input, the unit would have to completely power on. Zone 2 is designed so that it can be used with the main power off.
Sep 27, 2013 | Denon AVR-1804 Receiver
How to connect Denon avr 1804 connecting to roku hd
I connected by Roku to a Denon 1804 Receiver this way:- I plugged the cable that came with the Roku into VCR2 input jack of the Denon. (I used VCR2 because it was available).- Using the remote from the Denon, I made sure the slide switch was on "Audio." (See page 20 of Denon Manual).- I pressed pressed the System Setup button- *System Setup appears in display of Denon- Using the cursor buttons I scrolled to menu Digital in Assignment- I set Menu item 16 Coaxial to VCR2 since that was the input jack I used for the Roku. - After making the selection press the CH Select Enter button to save- To exit the System Setup press the System Setup button again- When using the Roku, select the input source as VCR2 (or whatever jack you used). You should now have sound through the Denon.The most important step is to read the Denon manual starting on page 20
Dec 08, 2012 | Denon AVR-1804 Receiver
My Denon AVR-1804/884 standby light stays on but the receiver wil not power up
ok my denon avr 1804 was jamming and it shut off on standby red light flashing comes on then goes back off what is wrong ?????
Feb 27, 2011 | Audio Players & Recorders
I have a Denon Surround receiver, model AVR-1804 which manages our home surround sound system (6 speakers including a sub-woofer). When the TV (Visio HDTV) is turned off, but the receiver is still on, we...
Some kind of ground potential difference between the TV and the AVR or perhaps it's a badly shielded cable.
Considering the multitude of variations you may have connecting the TV video and audio to the receiver it's hard to pin it down, but try removing all cabling between them and that should silence the hum. Add any cable and see if it comes back. Disconnect it. Test each cable the same way. At some point a single cable might be implicated. Replace it.
Also consider routing of any analog audio cable near power cables, the TV or other sources of high voltage and magnetic fields. I have a known problem when my overhead dimmer-controlled track lighting is on. Food for thought.
Feb 19, 2011 | Denon AVR-1804 Receiver
DENON -AVR-1905 when power on display appears " 1 FRONT LARGE " and nothing happens no button does not respond.what could be the problem ?
Dear friend. That means you have to use Large Front speakers with correct impedance The other four speakers are for rear and surround effects and they do not need to be large (or floor standing). Most effects will come from Front speakers. I suppose that this is the problem.
Good`Luck.
Flavio/BRAZIL
Jul 21, 2010 | Denon AVR-1804 Receiver
Denon AVR 1804
You need to get the manual and do some reading first. I couldn't find the AVR-1804 but the AVR-1803 is avaiable. It should be close enough to get you through connection and setup.
Register with retrevo.com and download it for free.
Feb 23, 2010 | Denon AVR-1804 Receiver
Dec 28, 2009 | Denon AVR-1804 Receiver
Denon AVR older receiver but worked fine; now
Did you try to reset the unit? Resetting the unit has fixed every problem I have ever had......turn off unit.....hold down A+B at the same time then turn the unit back on...hold buttons for roughly 3 seconds....Let me know if it works.
Aug 20, 2009 | Denon AVR-1908
No display; No power
Your unit has a hard short in it. This is usually a power supply problem. Most likely the rectifier has failed. This should be a relatively simple and inexpensive repair. Figure on $10 for parts plus the local labor rate.
Dan
Jul 16, 2008 | Denon AVR-1804 Receiver
Denon AVR-1804 Receiver Logo
396 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
