Question about Sceptre X32BV-Naga 32 in. LCD TV
My T.V. starts to flicker then it turns completly off
How do i solve a problem with a Lenovo G555.
try connecting the laptop to an external screen if you can not get a picture then the motherboard is faulty
May 11, 2014 | Lenovo G555 Laptop
Had oil change, so why does 'change oil' message still show?
On most models, you have to reset the "change oil" light after completing...Your owners manual might tell you how...if not...try turning your key to "on"...(not start) then depress the gas pedal 3 times...the light will flicker and go off if completed correctly. Hope this helps.
Feb 16, 2014 | 2000 Cadillac Seville
Led lights flickering
It has nothing to do with the microwave. Unfortunately, it sounds like the LED bulbs are defective and should be replaced.
May 15, 2017 | Microwave Ovens
My Mitsubishi WD-65638 turns on then flickers and turns off?
Flickering must be due to the fault to lamp itself. If you wish to get more details, check this link.
Mar 03, 2013 | Mitsubishi WD-65638 65" DLP HDTV
Why does my dashboard lights keep flickering when the car is off in my 2001 bmw 525i?
sounds like your having a problem with the ignition. its not shutting power off completly.
Feb 16, 2012 | BMW Cars & Trucks
The screen on my dell inspiron nootbook started flickering last month, two weeks ago it started to turn completely dark at times and today 3 min after i turned it on a blue screen popped up and it told me...
windows dose not control any flickering unless the driver is being updated if thats not the case your flourecent bulb might be getting old inside the lcd!
Aug 29, 2009 | Dell Inspiron 1525 Laptop
BB screen is flickering on & off then turned black after in water
If your BlackBerry gets covered in water, act fast and rationally, and you may be able to save your device.
1. DO NOT TRY TO TURN IT ON
2. Pull out the battery.
3. Please your device and battery into a bowl of uncooked rice to absorb any moisture.
4. Please it in a warm, dry place where it can receive direct sunlight.
5. Be patient. It is recommended that you leave it in there for at least 48 hours.
6. After 48 hours, put the battery back in and power on.
Jun 12, 2009 | RIM BlackBerry Pearl 8100
Flickering display panel Boschwfe 2021
It may be the door interlock that is faulty. This is the cheaper solution however it maybe the the electonic board. In any case it needs the attention of a bosch Technician. Cross your fingers its the door interlock.
0417362396 Melbourne metro Area
Regards Sam
Jan 05, 2009 | Bosch WFE 2021 Front Load All-in-One...
Sceptre X32BV-Naga 32 in. LCD TV Logo
14 people viewed this question
Top Sceptre Televison & Video Experts
Henry  Thomas
Henry Thomas
Are you a Sceptre Televison and Video Expert? Answer questions, earn points and help others
