Question about Frigidaire GLTF2940ES Front Load Washer
The machine vibrates badly no matter what we do
This machine vibrates badly no matter what we do. We have braced up the floor and leveled the machine and it still vibrates to the point of not being safe to use.
    Brigadier General:
  • 4,090 Answers
Check in the cabinet to see if one of the support springs is broken or rusted through.
Please rate my help++++Thanks for using FIXYA
Posted on May 07, 2010
Stacking washer and dryer still vibrating and walking during spin cycle even though stacking kit is attached
Assuming that you've installed the stack kit according to instructions, you should check the following:
1. The dryer should be securely attached to the washer and not wiggle or move. The washer must always go on the bottom of the stack.
2. Washer should be level and have all four level legs making solid contact with the floor, no wobbling.
3. Make sure the drain hose is not pinched or restricted (or there is not debris in the drain pump) as a slow pump out will accentuate vibration problems.
4. Make certain you've removed all of the washer packing bolts before using the machine (see owners manual for description.)
5. The floor must be solid with no "springy" or "spongy" feel. No matter what you do to the laundry set it will vibrate on a less than solid floor. This occurs on upstairs installations or other wooden floors, especially in an older home. Sometime the floor can be braced to stiffen it. Also, vibration pads are sold that might help minimize the vibration. The walking is a symptom of vibration.
Experience shows that most problems of this sort result from incorrect installation and/or flooring issues, not the laundry. You should not attach it to the wall. It is possible the washer has a problem in which case a technician would need to check the unit. They can check the suspension and drive system for proper operation.
Aug 24, 2014 | Samsung Front-Load Washer and Dryer stack...
Washer bouncing while spinning
Make sure the unit is leveled and on a solid surface. You may have to brace the floor up under the washer if the floor is too flexible. To test this place a glass of water on the floor in front of the washer. if the water vibrates and ripples in the cup the floor is weak. Manufacturer's came up with this test.
Jan 22, 2014 | Dryers
Spin cycle massive vibration everytime. Size of load doesn't matter?
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 14, 2010 | Maytag Neptune MAH5500B Front Load Washer
The inner washing machine tub seems to vibrate in spin cycle only.
you could have a bad balance ring or if the machine is on a floor that is not very sturdy it could cause the machine to vibrate or "walk". if the tub is loose it may need to be tightened which usually isnt the case. most vibration i notice is from the floor or the machine not being level.
Sep 17, 2009 | Kenmore 98702 Stacked Washer/Dryer
Maytag front loader MAH-3 vibrates. Level & on concrete floor.
THERE ARE SHOCK ABSORBERS IN THIS UNIT,SOUNDS LIKE ONE OF THEM IS BROKEN.HOPE THIS HELPS
Nov 16, 2008 | Maytag EPIC MFW9700S Front Load Washer
Vibrates badly
did you remove the shipping braces when you installed it you can find their location in your owners manuel under installation
Mar 28, 2008 | LG WM-2277HW Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
60 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
