Question about Toshiba DKT2010SD Phone
Need to fix date and time onToshiba DKT2020-SD
How do I program correct date and time?
    President:
  • Toshiba Master
  • 860 Answers
Depending on the type of system you have powering the 2010,this should take care of it.
Leave the handset on hook, press intercom # 6 5 2, then enter the time of a 24 hour clock, entering 2 digits for the hour, 2 digits for the minutes, and 2 digits for the seconds – enter a leading 0 for any single digit entered,
press Redial,
press Speaker.
This must be done at extension 200 – usually the receptionist phone.
For example, if the time is 2:15 P.M., press intercom # 6 5 2, 1 4 1 5 0 0, Redial Speaker
Posted on May 08, 2010
Toshiba dkt2020 sd
If there is a Dnd butto programmed, it will be located on the top right hand side. By pressing the do not disturb button the ring wil be abbreviated. otherwise it you will have to go into the phone system programming to make that phone not ring.
Oct 01, 2013 | Toshiba DKT-2020 Corded Phone
How do I set a release button for a Toshiba DKT2020-SD?
This is done in program 39 in the system programming. It must be performed on ext 205 or port 005. Your manual can be found here.
http://guides.idacomusa.com/
Aug 18, 2009 | Toshiba DKT-2020 Corded Phone
Need to Change Time on My Phone
1. Press [DN] + #652 with the handset onhook.
2. Enter the time (HHMMSS) in the 24-hour clock format.
3. Press redial
4. Press speaker.
This can only be done from the programming phone (usually reception).
Dec 05, 2008 | Toshiba DKT2020SD Phone
Change Time on LCD for Toshiba DKT2020
Hello:
I had the same problem Yesterday.
The way uoi change it, is you have to find the phone with the lowest extension, either 0, 10, 100, 200 etc....
Once you find that phone, leave the handset on the base.
Press Intercome, you should hear the speakerhone activate.
Press #,652
You will see it say ENTER TIME
It's on a 24 hour clock. HHMMSS Format, so it it is 2:05P.M., you would time 1405XX (XX means seconds, obviously not at critical as the touror minute.
Then press REDIAL to submit the change.
Nov 04, 2008 | Toshiba DKT-2020-SD telephone
Toshiba DKT2010-SD Phone
OK, model on bottom of phone is DKT2010-SD, but I found a little cheat card in a file for a STRATA DK8 & DK16 so I used a combination of things. First pick up handset and then hit intercom button, # 652 (for time or #651 for date) and enter time in HHMMSS (hour, minute, second) format, once complete hit the redial button.
Nov 03, 2008 | Toshiba DKT-2010 Corded Phone
NEED TO CHANGE TIME
On the main phone (ext 200 or 10) dial intercom #652 and enter HHMMSS then press redial. Your manuals and guides are here
Jun 25, 2008 | Toshiba DKT2020SD Phone
Toshiba DKT2020-SD 20 Button Display Speaker Digital Telephone
To change the time, go to extension 10, while keeping the handset on hook, push intercom, then dial # 6 5 2, enter the new time ie. 102510 (hour, min, seconds), then push the redial key to save. That should do it. to set the day use the intercom # 653 code (1=Sun, 2=Mon, ect). To change the date use the intercom # 651 code (ie. 080510). If that does not do it, you may have a different model key service unit, and you will need to notate which system your using.
May 09, 2008 | Lands Phones
Toshiba DKT2010SD Phone Logo
246 people viewed this question
Top Toshiba Lands Phones Experts
Oloyede Monsuru
JP Services
JP Services
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
