Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Gear skipping noise while washing - Whirlpool Ultimate Care II LSQ9564J Top Load Washer
  • 141 Answers
If the noise is more you are suppose to change the mechanism of the unit immediately may be rusted or damaged due to usage otherwise if you are well worst in replacing the bearing and the water seal you can replace and solve the problem if not call the technicians and replace the spare
Posted on May 08, 2010
Hp 4345 has error code 13.20.00 paper jam in tray 2 and also has a grinding noise by the fuser how can i fix it
The printer may need a "swing plate" replaced to solve the fuser noise. Remove the fuser and look at the black gear inside the printer on the left side. Do the teeth on that gear look worn ? If so that gear (swing plate) needs to be replaced. Its a hard job to do. Can you turn the fuser gears with it out of the machine without them skipping ? The tray 2 jam may just be worn rollers in tray 2 or a stuck sensor. Good luck !
Aug 06, 2013 | HP LaserJet M4345 MultiFunction Printer
Loud clacking noise like gears skipping over each other when I turn it on.
There is probably a gear cracked or partially broken causing the teeth to be out of mesh and the noise is when the gears jump back in to mesh until the faulty gear comes around again.. If it is a dewalt there are spares available.
Mar 24, 2013 | Dewalt 12" Beveling Sliding Compound Miter...
How do you make sure gears are synchronized
properly inserted,knots should be tights,and the gear pins are intact and well furnished to avoid skipping and expected noise...
Jun 05, 2011 | Yamaha ARN 50 Motorcycles
When my washer is in the wash cycle, it makes a loud clicking noise. It sounds like a maybe a gear is skipping through some teeth. It is loud and at a regular interval, although the rate at which the noise...
its most likely a bra wire caught in there as the bowl spins around it is hitting the plastic tank therefore making the clicking sound. its super hard to get em out and if it has put a hole in the plastic tank its really expensive to fix call your appliance service asap to have one of them take a look. this is a very common problem from a front load washing machine
Jan 09, 2011 | Maytag Neptune MAH5500B Front Load Washer
Throwout bearing?? When pressing on the clutch pedal, make a scraping metal sound, like it is skipping , (not solid straight sound) skipping. Goes in gear fine, runs fine in gear, just the noise -only...
Sounds like it may be the throw out bearing, as it is what all of the pressure rides on. To replace it, you will need to remove the transmision. Take a good look to see if there is a a place to look inside, you may be able to see the problem.
Nov 24, 2009 | 1989 Jeep Cherokee
Teac PD-D880 5-CD changer Disc Skip
The belt for the carousel has snapped and the noise is the gears continously turning and not being caught by the belt.
Oct 27, 2009 | Teac Audio Players & Recorders
Ive got the same problem with my xs650 1977...
the second gear is piting from rust[so the noise]the stuck is of the gear change ankor or damage spring
Jul 07, 2009 | 1979 Yamaha XS 650 SF
Bicycle chain skips a cog
You may have a bent or worn gear on the rear. Take a good luck at the teeth on your gears -- if any are bent or worn down, replace the gear set. Also, does your derailleur need adjusting? THis will produce a chattering or scraping noise in soem gears. If it's not centering the chain over the gear in each gear, the sideways force can pull it off for a moment.
Jun 04, 2009 | Cycling
Making a clanking noise when printing
Could be a fuser gear is broken or a Toner gear is about to break. Needs TLC by a Authorized Tech.
Feb 11, 2009 | Brother MFC8440 Remanufactured Laser...
Grinding noise
my suggestion is replace the fusing gear and the rachet gear.
Mar 22, 2008 | Sharp AL-1642CS Copier
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
66 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
