PC Start up
This message has started to appear each time I start up, what is this? I can debug ok and it goes but it is just annoying. Can I cure it? this is what appears:- The instruction at"0x67574ba2" referenced memory at "0x85f08bff". The memory could not be "read" Click ok to terminate the program. Click on cancel to debug the program.
There are no programs running apart from my AVG protection.
Please can you advise, thank you.
    Guru:
  • 377 Answers
Hi dear
choose safe mode with pressing F5 button
try to fix your start up program, uninstalling your relation software
or try anti spy
or hijack
reset your computer
and try to normal login
oke
Posted on Mar 27, 2008
"Stack overflow at line 0"
b> A stack is a section of memory where a program stores its variables, calculations, option states and program parameters. When started, a program is allocated some memory to use for the stack; a stack overflow happens when a program exceeds its allocation. The offending program may attempt to write into adjacent memory sections, causing conflicts with other programs. Stack overflows are common with Java, C++, Perl and other runtime environments, which assist in running programs. A stack overflow at line 0 indicates that the offending program tripped up from the start; however, stack overflows can occur on any line number.
Click "Start," "Control Panel, then "Internet Options." Click on the "Advanced" tab. Check "Disable Script Debugging (IE)" and "Disable Script Debugging (Other)" under the "Browsing" options. Uncheck "Display a notification about every script error." Check "Enable Automatic Crash recovery." Click "OK." Download and install a Java update from the Java website. http://www.java.com/en/download/manual.jsp Download and install a Windows update. Hope this helps.
Dec 24, 2012 | Microsoft Windows XP Professional
After clicking user name on Windows XP welcome screen error message appears: C:\Windows\System32\command.com parameter is incorrect. Clicking OK does not close the error message. Desktop does not appear,...
Try starting up in safe mode keep tapping f8 untill the advanced start menu comes up
login as administrator
press start -> run -> type in the run menu: msconfig and press enter
in msconfig open the startup tab and click disable all, apply and ok, restart normal mode. should work fine.
Aug 11, 2008 | Computers & Internet
Getting an error message
Go to start button then run write there ''msconfig''
a box will be open and there select startup tab then uncheck the required file press ok and reboot your pc. hopefully it will not show any message again at startup
Apr 04, 2009 | Computers & Internet
DeBug appears whenever
what IE are you using?
the debug will appear when you using IE6. the reason is that most of th web site have activex. IE6 can't handle it. you need to install IE7 sp1.
Mar 27, 2009 | Microsoft Windows 2000 for PC
Unable to access my personnal settings using XP
This sounds like a virus. Probably try running a virus scan with your virus removal software, if you dont have one download AVG - http://free.avg.com/ this is a free version of the software. Hope I helped.
iSpearz.
Jan 10, 2009 | Acer Aspire 5500 5570-2609 Laptop
EMACHINES PROBLEM. IT WONT START UP HELP IMMEDIATELY!
Try some of these solutions if you have XP:
http://articles.techrepublic.com.com/5100-10878_11-6031733.html
If you have Vista then do you have the Vista installation disk?
Jul 27, 2008 | E-Machines eMachines Desktop PC
My internet explorer is out. When I try to bring it up I get the following message " internet explorer has encountered a problem and needs to close "
Please see Mircosoft Artical on this: http://support.microsoft.com/kb/293623
Known issue - it is because of "script de-bugging" - here is how to disable it:
Manual steps to disable script debugging in Internet Explorer loadTOCNode(2, 'workaround'); To work around this problem, disable script debugging in Internet Explorer. To manually disable script debugging, follow these steps: 1. Start Internet Explorer. 2. On the Tools menu, click Internet Options. 3. On the Advanced tab, click to select the Disable Script Debugging check box in the Browsing section. 4. Click OK, and then restart Windows.
Jul 17, 2008 | Gateway Computers & Internet
I have a HP DeskjetF380 All In One Printer, scanner,copier which has been working OK & still does, but am receiveing continual message on my computer which interferes with my computing etc & is an...
Try going into control panel, add and remove programs and finding the HP update program. Uninstall this and you should nto get any more update messages
Fred
Jul 17, 2008 | HP Office Equipment & Supplies
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
